Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4094 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Fri Jun 15, 2012 10:44 am Post subject: |
| notchboy wrote: |
| BTW I like my hydo lifters in the 77 |
Yup, I'll second that emotion. Hydro issues are symptomatic of bigger / other problems. Mine are great. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
curtis4085 Samba Member
Posted: Fri Jun 15, 2012 11:32 am Post subject: |
| notchboy wrote: |
Matt - send it off like Dan said. Especialy since you got the $ back from the other guy! Just make sure they do a complete check again of components BEFORE they assemble.
BTW I like my hydo lifters in the 77 but dont mind the solids in the 74 at all. I think you should make a choice based on practicality. And a practical man would continue the path he chose already
Or you can be that stupid flip floppy guy with more $ than franken cents  |
thanks for the input.. not flip floppy at all and definetly dont have more money than sense. I just finished watching the bug me video and the amount of damage to the hydro cam was amazing, exspecially the number one lobe. and the fact of the matter is i have to replace the cam any ways so since i have to buy new cam and lifters the only other thing to get is pushrod tubes to make the swithch right? so not much cost at all considering.
Whats everyones take on reusing the cam gear? talking with Adrain he likes to replace them with USA made new ones when replacing the cam shaft. only asking as i have heard changing this gear could add unwanted noise. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
71 Pastel White Panel Van current restoration
73 Westfalia (sold)
73 Westfalia (accident)
73 Kombi (Sold)
75 Panel Van
79 Sage Green Westfalia fully restored
http://www.thesamba.com/vw/forum/viewtopic.php?t=479199&postdays=0&postorder=asc&start=0 |
Posted: Fri Jun 15, 2012 11:47 am Post subject: |
| curtis4085 wrote: |
| notchboy wrote: |
the amount of damage to the hydro cam was amazing, exspecially the number one lobe. and the fact of the matter is i have to replace the cam any ways so since i have to buy new cam and lifters the only other thing to get is pushrod tubes to make the swithch right? |
Don't you need to get the heads re-worked as well?
Would you not have had the exact same problem if you had used solids, given that the lifter bore seems to be the issue?
My 33 year old cam was totally to spec, and showed no signs of wear. Just the faintest sign of metal on metal in the places that it should have been. I am sure that regular use of synthetic oil didn't hurt. Your issues were not about hydros vs solids. You gotta do what you gotta do, but make sure there is a method to the madness, as it were.  _________________ *****************
germansupplyscott Samba Member
Posted: Fri Jun 15, 2012 12:28 pm Post subject: |
| Westfabulous wrote: |
| My 33 year old cam was totally to spec, and showed no signs of wear. |
do you have photos of your camshaft?
i have never seen a hydraulic cam with any significant mileage on it that was not worn, i'd like to see one. _________________ scott lyons
http://www.germansupply.com
VW Bus-Centric Online Parts Source |
Posted: Fri Jun 15, 2012 12:37 pm Post subject: |
| germansupplyscott wrote: |
i have never seen a hydraulic cam with any significant mileage on it that was not worn, i'd like to see one. |
I don't have any pictures handy, but Busdaddy has seen it and could probably weigh in, and give his thoughts. As I recall, he felt that it looked pretty much as new, and certainly didn't need any remedial work. Keep in mind that my bus is a low mileage unit, but even so, its not like it has no miles on it. _________________ *****************
busdaddy Samba Member
Joined: February 12, 2004 Posts: 24141 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Fri Jun 15, 2012 12:50 pm Post subject: |
I don't have any pictures handy, but Busdaddy has seen it and could probably weigh in, and give his thoughts. As I recall, he felt that it looked pretty much as new, and certainly didn't need any remedial work. Keep in mind that my bus is a low mileage unit, but even so, its not like it has no miles on it. |
I don't have pics handy but I'll try to find one, it was a remarkably clean cam, not brand new but nothing scary either, nicely broken in you could say  _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
Posted: Fri Jun 15, 2012 1:01 pm Post subject: |
how many miles on it? _________________ scott lyons
Posted: Fri Jun 15, 2012 1:06 pm Post subject: |
| curtis4085 wrote: |
| notchboy wrote: |
My 33 year old cam was totally to spec, and showed no signs of wear. Just the faintest sign of metal on metal in the places that it should have been. I am sure that regular use of synthetic oil didn't hurt. Your issues were not about hydros vs solids. You gotta do what you gotta do, but make sure there is a method to the madness, as it were.  |
len said he would rework heads for $50 plus shipping. Cost more to ship than rework. If there are any issues with the heads he will take care of it then.
As for damage to cam, all you need to do is watch the bug me video of the tear down of a 200k engine. the cam looked horrible. I plan to only drive the bus maybe 6k a year so is hydros really all that warranted. the cost to change is nominal considering I want to eliminate any possible weird noise problem. I know I am speaking out of frustration but I need fixes bad... _________________ Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
Posted: Fri Jun 15, 2012 2:10 pm Post subject: |
| how many miles on it? |
About 45,000. I was running Mobil 1 TDT 5w40 synthetic, which is renowned for its protective properties in relation to heavy duty diesel cams with unit injectors, like my Passat TDI. These diesel cams take a thrashing like nobody's business. The wear studies on this oil are unmatched. A while back I did a pile of internet research on oil for my cars, and it led to the Mobil product. I am now using it in everything. _________________ *****************
Last edited by Westfabulous on Sun Jun 17, 2012 12:59 pm; edited 6 times in total |
Posted: Fri Jun 15, 2012 2:15 pm Post subject: |
| curtis4085 wrote: |
| curtis4085 wrote: |
| notchboy wrote: |
As for damage to cam, all you need to do is watch the bug me video of the tear down of a 200k engine. the cam looked horrible. I plan to only drive the bus maybe 6k a year so is hydros really all that warranted. the cost to change is nominal considering I want to eliminate any possible weird noise problem. I know I am speaking out of frustration but I need fixes bad... |
200,000! That's a lotta miles.....more than 8 times around the world in fact. I wonder how a solid cam would look with that kind of mileage? Anyway, you have to be happy in the end, so carry on, and good luck brother. _________________ *****************
Opossum Samba Member
Joined: February 26, 2005 Posts: 609 Location: Islets of Langerhans
Posted: Fri Jun 15, 2012 5:46 pm Post subject: |
| curtis4085 wrote: |
| As for damage to cam, all you need to do is watch the bug me video of the tear down of a 200k engine. |
Is that the "Bug Me" video where Jake Raby shows how to rebuild a Type IV engine? _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 5573 Location: Edmonds, WA.
Posted: Fri Jun 15, 2012 5:54 pm Post subject: |
| Opossum wrote: |
| curtis4085 wrote: |
Is that the "Bug Me" video where Jake Raby shows how to rebuild a Type IV engine? |
yep...iv seen it.
and that cam is HELLAAAA shot...lol about a 1/4 inch gouge if i remember right... _________________ MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.” |
Posted: Sun Jun 17, 2012 12:53 pm Post subject: |
Found one, I'll keep digging for close ups but overall the inside of the engine was as clean as the bus.
babysnakes Samba Member
Joined: August 19, 2008 Posts: 3877 Location: West Boca Raton, Fla.
Posted: Sun Jun 17, 2012 1:06 pm Post subject: |
That is a nice looking chunk of metal! _________________ '69 SC under resto
'72 deluxe daily
'78 Westy
'71 super vert
Luftwagens
“If you end up with a boring miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on television telling you how to do your shit, then you deserve it.” FZ |
liquidboots Samba Member
Posted: Thu Jul 05, 2012 2:14 pm Post subject: Re: Carpet is here! |
I looked on this website and could not find the green westy carpet kit for sale ... thoughts?
Thanks
1
Chris
| curtis4085 wrote: |
Well after a discussion with the boss I was told that i could go ahead and get the replacement carpet from Kieft and Klok in Germany http://www.kieftenklok.nl/uk/index.php . I ordered and it arrived within two weeks. I must say these gentlemen stand behind there products. Quality looks great, color is awsome. I am very pleased with my purchase. It is pricey I know but worth it if you want the closest match to color out there. Should check em out.
and it came with cool calendar, and stickers.. |
Posted: Thu Jul 05, 2012 3:13 pm Post subject: Re: Carpet is here! |
| liquidboots wrote: |
Thanks
1
Chris
| curtis4085 wrote: |
What website did you go to? I cannot remember the spelling and do not have time to thumb back threw the tread. Keifter Something? They only had limited supply as it was a NOS carpet role they were reproducing it from. I have and extra cargo area piece but not sure if I would part with it. Currently I'm running new NOS cargo area Carpet, rubber in walk thru area and rubber up front. Mostly to keep the carpet clean.
If you have the correct website maybe you could email them and ask if they still have the carpet. Keep in mind they did not have all the colors. _________________ Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1325 Location: Arizona
Posted: Fri Jul 06, 2012 12:48 am Post subject: |
Carpet is still there.
http://www.kieftenklok.net/component/page,shop.pro...8/lang,en/
And you're still going to pay dearly for it.
Really nice quality though. Buy quality, and only cry once.  _________________ 1978 Sage Green Westfalia
1969 Delta Green/Cloud White Transporter
1977 Senegal Red/Atlas White Transporter
Life is short. Can I have some of yours? |
Posted: Mon Jul 09, 2012 7:04 pm Post subject: |
My carpet from them looks great and worth the cost to have that OG look. The bad thing is it does not come with a rubber backing on it. I was considering taking the pieces to my local carpet shop and having them add a backing to it for added protection. _________________ Special Thanks to:
73 Westfalia (sold)
73 Kombi (Sold)
75 Panel Van
