My 70 Bus!!
Goto page Previous  1, 2, 3 ... 12, 13, 14 ... 16, 17, 18  Next
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Mon May 21, 2012 10:53 pm    Post subject: Reply with quote
lookin good!
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
justcruzin
justcruzin is offline
PostPosted: Sun May 27, 2012 8:28 pm    Post subject: Reply with quote
Today we took the bus to the Bugorama!
Here is what I brought home!
In the wheel barrow is an air boot for my carb to air cleaner, a sink vent, a single port dual carb manifold with a Holley carb, a piece called the stove pipe, a shifter coupler, (found those last 2 in the freebie pile), some heater tubes, and and air vents.
In the back of the bus is a car that hubby bought, a back pad with less holes then my current one, and also a buddy seat pad with less holes then mine!
Here is my air vent before,
I found that the air vents for the back of passenger buses are in a lot better shape then the dash one's! Very Happy So if you are looking for good vents, look for the ones for the back of the bus! Very Happy
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
justcruzin
PostPosted: Mon Jun 04, 2012 11:38 am    Post subject: Reply with quote
Another little update! Very Happy
Over the weekend I had planned to install my axle boots. That didn't happen but I managed to install my seat stand mats instead! Very Happy
Before,
After,
Much cleaner now!! Very Happy
I also found me a flower at a yard sale! Very Happy It is solar powered. LOL You should be able to click on the pic and it will take you to my photobucket site and play the short video of it in action! Very Happy
That's it for now. Very Happy
Kim
Sacramento, CA
justcruzin
PostPosted: Fri Jun 15, 2012 9:17 pm    Post subject: Reply with quote
Today I went shopping for my Bus! Very Happy Well actually I went to the guy's house that I bought my bug from to pick up a few parts he found that went with my bug. He asked me if I wanted to buy a tent for my bus. After a little negotiating, I cam home with this!!
I have yet to stand it up, but from what I can see of it, it looks to be in good shape. As far as I know I am missing one pole and one corner connecter. He used a part for a regular pop up for the missing corner piece. I will eventually try to find the correct pole and piece.
Tomorrow I will set it up and see what it looks like!! Very Happy
Kim
Sacramento, CA
justcruzin
PostPosted: Sat Jun 16, 2012 5:39 pm    Post subject: Reply with quote
I put my tent up today! It is in pretty much excellent condition. Only thing I could see that was not in great shape was it has about an inch to inch and a half rip on the rubber piece that attaches to the bus's rain gutter. Other then that there are no rips or tears.
I am missing the rear middle piece referred to as the "red middle piece" in the manual.
I'm also missing one of the legs that extend. In the manual they are referred to as pole 8 and 9. That and one of my poles is missing the little springy thing that pops out and goes in the hole of the other pole.
Springy thing that one pole is missing,
I will most likely be putting a WTB in the Classifieds later. But if anyone has any of these things and doesn't want to ask an arm and leg for them, feel free to PM me!! Very Happy
I wish I could have set it up and got pics with it next to the bus, but it was 100+ today so I put it up in the air conditioned garage! LOL
Kim
Sacramento, CA
justcruzin
PostPosted: Sat Jun 23, 2012 2:50 pm    Post subject: Reply with quote
Thanks to a friend on "earlybay.com" this week I was able to make me some shelves for my bus! Sarah made her a set and I liked them so I asked if she would send me a pattern. She did! Very Happy I made mine a bit different though! Very Happy So here is what I started out with.
I made me a jig to make an outline of where I wanted my ledge.
Here's the passenger side.
Driver side. I took a broken VW rearview mirror to make a outline for one of me cubby's!
All cut out and stained.
Before I could install them I had to do some rearranging in the bus.
I raised my fuse panel up and then relocated the fire extinguisher. This is just temporary till I find a better place for it. I want it to be easy to get too, but durring the winter months I need that spot for my Buddy Heater so eventually it will be moved again.
I installed a bar to clamp my fan too under the shelf.
Passenger side has a cup holder. I will eventually try to find something to put under the hole so one can put a can in there too. For now it is only for cups that have a bigger top then bottom! LOL
Driver side has an option for a cup holder but I left it as a cubby for now. I like the cup holder I have in between the seats better but figured I would at least make a spot for one, that and it makes it match the passenger side a bit better. Very Happy
I also installed a 3 way power adaptor. I liked it because of the on off switches and also the lights. I did mess up one light durring the install though. Sad The power part of it still works though. Only thing I didn't like about it was I had thought I could leave it's power point plugged in and just use the switches, but the power point has a light also. So I still have to pull it out a bit. I may try to remove the light later though.
The finished product. All ready in use!! Very Happy
Kim
Sacramento, CA
justcruzin
PostPosted: Sun Jul 01, 2012 9:33 pm    Post subject: Reply with quote
Even though I put pics in the "What did you do to your bay" thread, I wanted to add to my thread too.
Well, for the last week I have been working on a fix to my pop top.
Here is before,
That was a pic from when I first got the bus. I actually got a bit to excited to try on my home made fix, that I forgot to take more current pics of it. It now has areas that I have tried to sew up to keep it from completely falling apart.
Here is what I started with for the fix. Two white sheets sewn together. Drew half the VW emblem on.
Then tied it up,
Then I did this,
And the final product was this,
It's not a permanent fix, but it is something that I can use till I can afford the correct canvas! At least now I can pop the top and not be embarrassed about my ugly canvas! Very Happy
Kim
Sacramento, CA
kitcarson
kitcarson is offline
PostPosted: Mon Jul 02, 2012 3:45 am    Post subject: Reply with quote
skid wrote:
justcruzin wrote:
Awesome. This one is my fave.
OMG, I am in the same exact boat...literally. I have a 70 bay westy (white), a bug, and a split window standard bus. Same colors too......and in the same rebuild stages too. I havent reached the end of this thread, so dont know how this story ends but learning a TON with your pics and posts.......thanks.
justcruzin
PostPosted: Mon Jul 02, 2012 10:49 am    Post subject: Reply with quote
kitcarson wrote:
That is amazing! LOL You will have to park them together and take a pic! Very Happy
Kim
Sacramento, CA
secretsubmariner
secretsubmariner is offline
PostPosted: Mon Jul 02, 2012 11:06 am    Post subject: Reply with quote
Great work on those parcel trays! I love them!
-Tony
1978 Champagne- "Lord Puber"- first love.
1978 Champagne- "Scuttlebutt"
1978 Deluxe Auto Westfalia- "Samsquantch"
Amskeptic wrote:
Anybody dissing any year air-cooled Volkswagen is not on board.
germansupplyscott wrote:
i like auto transmissions in buses. it's a lot easier to roll a joint while driving with an automatic.
Javyd
Javyd is offline
PostPosted: Wed Jul 25, 2012 6:45 pm    Post subject: Reply with quote
Nice job on the resto so far!!! I followed your link from when you replied to my post about plywood. I do like those trays too! i'm going to attempt to trace a pattern like yours out tomorrow. If i can't get it i might have to ask you to send me a copy of the pattern too! Very Happy
73 Campmobile
06 GTI
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Wed Jul 25, 2012 7:42 pm    Post subject: Reply with quote
Good work Kim. I love your passion for the hobby.
"I will gladly pay you Tuesday for a hamburger today."
Busdriver79
Busdriver79 is offline
PostPosted: Thu Jul 26, 2012 6:51 am    Post subject: Reply with quote
Looking very nice...You did a great job bringing the old girl back from the brink. Very Happy
justcruzin
PostPosted: Thu Jul 26, 2012 2:47 pm    Post subject: Reply with quote
Thank you! I've enjoyed every minute of it too! Very Happy I love this bus. Very Happy
Kim
Sacramento, CA
Stuartzickefoose
Samba Post Whore
PostPosted: Sun Aug 19, 2012 9:04 am    Post subject: Reply with quote
updates? Smile
stuco
stuco is offline
PostPosted: Sun Aug 19, 2012 11:21 am    Post subject: Reply with quote
Great work so far, your bus is sweet! So are you driving the bay or the split more these days? That's a decision I wouldn't mind having to make every morning!
justcruzin
PostPosted: Sun Aug 19, 2012 7:57 pm    Post subject: Reply with quote
Yes, driving the Bay over the split. I really love my Westy! I still like my 64 though.
Kim
Sacramento, CA
justcruzin
PostPosted: Sun Aug 19, 2012 8:19 pm    Post subject: Reply with quote
Stuartzickefoose wrote:
updates? Smile
Actually yes, I do have an update! LOL
After only about 2 months of replacing my old (still good) cable, my new one looks like this.
Needless to say I replaced it on Friday. I got a new one for free and they are sending the old one to the place they get them from. Faulty cable.
This weekend we also worked on my roof rack. We got a Yakima rack off of a Toyota, but after hubby looked at it for a while, he just wasn't happy. He decided to build his own.
So here is what we started with.
The bike rack I got from Rack and Road. I went in to buy a new one and the guy helping me told me about this one. 20 bucks isn't bad for what I will be using it for. Very Happy
Doing some measuring.
Starting to look like something,
All painted. Yes, I tried tie dyeing with paint. LOL
Drilling the holes,
Finally, have a bike up there. Very Happy
I learned that with just one bike up there, I'm not able to lift the top by myself. Yah, that is my thumb up in the corner. LOL Still haven't learned to move it out of the way. Laughing
My original plan was to have 2 small Schwinns and a surfboard on there. Just for shows though. At the show I wanted to raise the top up with all of that on there. I think the top would be ok, but I will definitely need some help pushing it up.
I still need to find another bike rack for the other side, then I can put the center eye hooks in. Also need to figure out how to attach the surfboard in the middle of it all. LOL I still haven't driven it with the bike up there, so I can't say if I will like it or not. I may end up with just the surfboard. Oh, I also found out I will need to figure out a way to put the bikes up there by myself. May have to invest in a hoist for the garage. LOL
Kim
Sacramento, CA
Stuartzickefoose
Samba Post Whore
PostPosted: Mon Aug 20, 2012 9:50 pm    Post subject: Reply with quote
im looking into adding a gas strut to assist lifting the heavy top...ill let ya know what i find Smile
KSAVVY
KSAVVY is offline
PostPosted: Sat Aug 25, 2012 8:31 am    Post subject: Woah Reply with quote
Your restore is totally inspiring! I just bought my first VW. Its a 71 Westy. You have given me so many ideas! Thanks for sharing and keep on keeping on!!!! Very Happy
Page 13 of 18
