which 944 front brakes will fit fuchs direct?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
pupjoint
pupjoint is offline
PostPosted: Tue Jan 10, 2012 7:50 am    Post subject: which 944 front brakes will fit fuchs direct? Reply with quote
thinking of getting a pair of front 944 brakes to put on my ball joint Bug. will use brackets to mount on the spindles. so i can bolt my fuchs on direct.
which model i should be looking for?
either this or i will just fit stock front discs, rotors redrilled and put in studs for 5 x 130 of course...
whichever comes first
mrbigmax
mrbigmax is offline
PostPosted: Sat Jan 14, 2012 7:58 am    Post subject: Reply with quote
These are on my list of upgrades when I hit the lotto:
1. Here's a guy who put some 4 piston brakes from a 944 turbo on his ball joint ghia. Elsewhere on his site he says it increases the width about 15mm.
http://www.t-34.co.uk/index.php?id=4&page=tech
2. Also came across a real good video of fitting 944 rear disks to the Bug's IRS rear. Apparently the 944 and the IRS bug rear trailing arm share the same trailing arm assemblies. I also heard that the later 944 arms were aluminum instead of steel. Adds about 7/8" width per side.
http://www.youtube.com/watch?v=T9VkS3SWuH4
3. And if you want to take it one step further, you can even bolt in a 944 master cylinder. That gives you a larger master cylinder too.
http://www.airsouls.com/how-tos/master_cylinder.htm
The 944 has the standard Porsche 5x130 pattern.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
