ccb_dan Samba Member
Joined: August 03, 2009 Posts: 321 Location: Cocoa Beach, FL
Posted: Mon Mar 11, 2013 11:30 am Post subject: |
Thanks for the tip on welding from the inside...makes perfect sense.
I'm a total newbie so all the advice helps a ton! |
RockyGun Samba Member
Posted: Fri Jun 06, 2014 11:49 pm Post subject: inner rocker |
anyone have any info on how far foward the inner rocker goes? i had rust in my b pillar on the right side so i cut it out to the floor... my jack point looks a little crooked and I noticed my front outrigger is a little brittle so im just replacing it all... but how far forward does the inner rocker go? and does it sit flush with the frame bars and top hats? new to all this.. I can weld just fine just want to make sure everything is where its suppose to be before I start setting it all back in perm. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Tue Jun 17, 2014 6:20 pm Post subject: |
Holy crap...you can weld through Gerson's funky green? I've been removing it all the time. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
Posted: Tue Jun 17, 2014 8:44 pm Post subject: |
Oh... In the video it looked like you hadn't removed it. _________________ Looking for a correct 1967 rear seat
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Thu Jun 19, 2014 6:45 am Post subject: |
This is the only shot I have of the rocker on my bus, someone mashed it up pretty good before I bought it. I was looking at it yesterday and noticed that the belly pan looks welded to the back side of the rockers lower flange. Would I need to remove the pan to replace this rocker or just drill out the spot welds and re weld in the same plug welds?? I would like to try and replace this myself if I don't have to remove the pan. Thanks
Posted: Thu Jun 19, 2014 6:50 am Post subject: |
If it's not rusted, and it's that much trouble, I'd consider pulling out the dents. _________________ Looking for a correct 1967 rear seat
Posted: Thu Jun 19, 2014 6:58 am Post subject: |
Luckily I dont think it is rusty . The front dent would not be too bad to pull but that rear one is really caved in. Something a "real body man" could do. But an option, thanks Ken. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Jun 19, 2014 6:59 am Post subject: |
the dog seems to be happy with how it looks, don't upset the dog _________________ regards
Uli
Posted: Thu Jun 19, 2014 9:06 am Post subject: |
Yeah he pretty much runs the house anyway. |
Posted: Tue Jul 08, 2014 5:21 pm Post subject: |
glideking wrote: |
Yes remove the funky green. It makes for a funky weld. Easily cleans off with lacquer thinner and steel wool.
Kurt |
Kurt,
I soooooooo appreciate that video and wanted to thank you. Started repairing the right side floor, B pillar, etc. and wouldn't have gotten the B pillar are right without your video.
Posted: Tue Jul 22, 2014 5:22 pm Post subject: |
glideking wrote: |
Here is the page of my thread that shows that. The inner rocker is exactly the same on buses and trucks, outer rocker is a little different.
http://www.thesamba.com/vw/forum/viewtopic.php?
One of the tabs at the end of your new inner rocker needs to be bent back out flat to go between the top hat flange and the A pillar close in piece. The end of the video shows the correct way that they should all line up.
This is a tricky little area. Post some pictures we will help.
Kurt |
Make that "B" pillar. _________________ Looking for a correct 1967 rear seat
Posted: Thu Jul 24, 2014 1:03 pm Post subject: |
glideking wrote: |
Kurt |
Kurt (or anybody else with the knowledge)...trying to install my inner rocker. The tab on the end...the one you bent outward to make that three piece sandwich? Mine extends beyond the tab on the top hat by about 1/4". Was that what you had? I was kinda expecting them to meet edge to edge, but I can't shove the rocker rearward any more to make that happen...its flush up against the inner whee well in back.
Also, when the outer rocker is installed, does it sit on the same exact plane as the inner...everything flush with the tophats, beams, etc? All level?
And finally, the securing bars on the cargo doors...(the ones that go into the roof edge and floor to hold the doors shut), well, mine are a little too far apart. Guess that's to be expected on something this old. Can the doors be adjusted to be closer together, bringing the bars in tighter as well? _________________ Looking for a correct 1967 rear seat
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Thu Jul 24, 2014 6:44 pm Post subject: |
I'll do that tomorrow. So... Is the outer rocker level with the inner? _________________ Looking for a correct 1967 rear seat
Posted: Thu Jul 24, 2014 7:54 pm Post subject: |
brettsvw wrote: |
Ken, Post some pic of your cargo doors in the closed position.
show close ups of the gaps on top and bottom.
Clamp the rocker on with good pics of the areas you are concerned about. |
Measurements say more than pictures...The gap between the "B" pillar and the forward cargo door is 3mm at the top and narrows to 2mm at the bottom. The gap between the two cargo doors is 4mm at the top and widens to 8mm at the bottom (the reason why my locks just about miss the slots in the rocker). The gap between the rear most cargo door and the "C" pillar is 3mm at the top and narrows to 1.2mm at the bottom.
Interestingly enough it seems I have a total of about 10mm total gap at the top and the bottom, meaning to me that the bus hasn't sagged. Seems like the bottoms of both doors need to come toward the center line, giving a straighter gap at the "B" & "C" pillars over all, and closing the gaping gap at the bottom of the doors in the center.
How does one do that? The cargo doors were replaced at one time. _________________ Looking for a correct 1967 rear seat
Posted: Thu Jul 24, 2014 10:56 pm Post subject: |
On of my videos shows me using a stack of washers to bend a door to open a gap. Think along those lines. We need pictures. No the outer rocker is not coplanar with the inner rocker. It is higher depending on what brand of floor you are using. You need to check the striker plate clearance and gap for your doors with the hight of the outer rocker. Use lots of clamps or screws to mock it up and make whiteness marks.
I did grind the rocker sandwich flush before edge welding it all together. The small square flange on the inner rocker that is bent down must be coplanar with the close in piece.
Kurt _________________ "The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639 |
