Sliding Door Adjustment
RussellK
RussellK is offline
PostPosted: Fri Sep 23, 2011 8:14 am    Post subject: Sliding Door Adjustment Reply with quote
Is there an adjustment that pulls in the lower rear corner of the sliding door? I get a nice even fit everywhere but there. The rubber is about a year old. I'm tempted to trim some of the seal away and see if the door pulls in but then I've got a screwed up seal.
-Russ
'77 Westphalia
'68 Standard
SGKent Premium Member
SGKent is offline
PostPosted: Fri Sep 23, 2011 8:36 am    Post subject: Reply with quote
the door could be tweaked or you may need to set the top adjustment. That corner is usually the one spot that is off a little. Take a photo and post it if you haven't already.
It is a 40 to 50 year old car that has been abused by at least one of the prior owners. Many parts are no longer available, and like BusDaddy says - rust never sleeps. Better get used to it. If you can't then be prepared to get out your wallet, and your tools.
waggoner
waggoner is offline
PostPosted: Fri Sep 23, 2011 11:10 am    Post subject: Reply with quote
just came across this. I need to adjust the top rear of my slider. SGKent: where are the adjustments located for the top?
thanks
aeromech
aeromech is online now
PostPosted: Fri Sep 23, 2011 12:01 pm    Post subject: Reply with quote
I've had several doors off various years of buses. Other than the door latch rod I can't think of any adjustments that can be made. The big issue with the doors is the rollers and the nylon block. The block wears out and can be replaced. There is a grooved roller that runs on a track and that roller sometimes breaks in half. They are replaceable. On the front top and bottom of the door are simple rollers that can be cleaned and lubed. The tracks can also be cleaned and lightly lubed. I think that as long as all the components are in good shape the door should open and close easily and fair well when closed. I'm sure that the Bentley must have info on this.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent is offline
PostPosted: Fri Sep 23, 2011 12:10 pm    Post subject: Reply with quote
yes - if you haven't replaced the nylon block you need to do this first.
RussellK
RussellK is offline
PostPosted: Fri Sep 23, 2011 1:21 pm    Post subject: Reply with quote
I replaced the nylon block. The door moves very smoothly on the track. Latches correctly etc. I looked at it some more and I'm leaning toward the seal being the culprit. I have a show on Sunday so I don't want to do anything drastic before then but after that I might trim the seal a little and see what that does. If the door pulls in correctly in that corner then I'll put in a new seal. So. Since oeveedub is gone who's my source for quality seals?
-Russ
'77 Westphalia
'68 Standard
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Fri Sep 23, 2011 1:25 pm    Post subject: Reply with quote
Busdepot! Wolfsburg West! BugHaus!
-Tony
1978 Champagne Edition II (Mar)
1978 Champagne Edition II (Feb)
1978 Champagne Edition II (Jan - sold)
1978 Westfalia Auto Deluxe (sold)
78Kombi wrote:
dude but im a nigerian prince
SGKent is offline
PostPosted: Fri Sep 23, 2011 1:32 pm    Post subject: Reply with quote
We used a seal from a major supplier and it is a commonly sold one. The door would barely close. I called Wolfsburg West to see what they had as Richard was out of sotock on his good ones. This was about 2 years ago. WW sent me one they said was original. It still had VW part numbers on it and looked and felt the same as the old one. Was gray instead of black from the talc VW put on it. Works awesome. Even so the lower left is always a little loose but it seals up. I played with the slider adjustments a little and it looks pretty good. Think of the whole door not just the lower left. If the lower left is out, is the top right in? Is the whole left side out etc.
