Trailing arms and ball joints rubbing on my rims?
ffastr6
ffastr6 is offline
PostPosted: Tue Feb 07, 2012 8:53 am    Post subject: Trailing arms and ball joints rubbing on my rims? Reply with quote
I have Porsche Fuchs and a 4" narrowed beam on my 66 beetle. My trailing arms and ball joints are rubbing like hell. I've tried grinding the arms and ball joints but I'm not sure when enough is enough. If I raise my car the problem is corrected, however, I want my car slammed!!! Any suggestions or assistance with my dilemma? And please don't tell me to raise my car....There has to be another option...lol Very Happy
tripicana
tripicana is offline
PostPosted: Tue Feb 07, 2012 10:33 am    Post subject: Reply with quote
wheel spacer
foam cowboy hats aren't good helmets.
Miklo
¡Chale!
Miklo is offline
PostPosted: Tue Feb 07, 2012 10:57 am    Post subject: Reply with quote
How bad is it?
I've never seen it so bad that you cant just grind off a little material on the arms/balljoint.
Have any pics?
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
vdubnut58
vdubnut58 is offline
PostPosted: Tue Feb 07, 2012 1:11 pm    Post subject: Reply with quote
Add dropped spindals
Miklo
¡Chale!
Miklo is offline
PostPosted: Tue Feb 07, 2012 1:28 pm    Post subject: Reply with quote
He probably already does, adding dropped spindles makes it worse.
Miklo
'55 Type1 "Ozma"
Longrifle
Longrifle is offline
PostPosted: Tue Feb 07, 2012 1:35 pm    Post subject: Reply with quote
Stupid question, but did you adjust the steering stop bolts on the bottom of the steering box ? That will limit the turning radius and hopefully stop the rubbing...just a thought before you go spending more money!
Longrifle
67’ sedan
66’ SO-42
hybridvw
hybridvw is offline
PostPosted: Tue Feb 07, 2012 2:30 pm    Post subject: Reply with quote
I have 1" spacers to keep tires from rubbing spring-plate. What I need is good studs and lug nut or ??? I am using stock rims so I need the round style. Where can I buy?
Thanks in advance...
~~ LEDs for VW Porsche Gauges ~~
drscope
drscope is offline
PostPosted: Tue Feb 07, 2012 3:48 pm    Post subject: Reply with quote
Here;
http://www.bildon.com/catalog/results.cfm?category...amp;Nav=10
They ain't cheap, but you will be hard pressed to find better stuff.
drscope
drscope is offline
PostPosted: Tue Feb 07, 2012 3:50 pm    Post subject: Reply with quote
I don't think I would be grinding on the ball joints that are already operating way past their design specs!
You need to space the wheel out.
The problem is you are trying to run modified parts that were never meant to work together.
hybridvw
hybridvw is offline
PostPosted: Tue Feb 07, 2012 6:31 pm    Post subject: Reply with quote
Ordered!!! Thanks for the info.
ffastr6
ffastr6 is offline
PostPosted: Wed Feb 08, 2012 5:01 pm    Post subject: Reply with quote
Gonna grind a little bit more and if that doesn't work i'll go with the wheel spacers. I'll lose a little tuck but at least i'll roll without rubbing Evil or Very Mad
ffastr6
ffastr6 is offline
PostPosted: Wed Feb 08, 2012 5:03 pm    Post subject: Reply with quote
VeeDubDoug wrote:
How bad is it?
Have any pics?
With the adjusters all the way down my car won't roll because the trailing arms are sitting on my rims
Goshen
Goshen is offline
PostPosted: Wed Jul 11, 2012 11:32 am    Post subject: Reply with quote
VeeDubDoug wrote:
How bad is it?
Have any pics?
I found this pic from another post:
tacky
tacky is offline
PostPosted: Wed Jul 11, 2012 7:08 pm    Post subject: Reply with quote
you can make the lower ball joint stem seat deeper into the spindle.
cut the stem off of a ball joint, weld it to a piece of straight steel rod, put the rod end into place in a drill as you would a bit.
use your new tool with some lapping compound on the ball joint stem to open up the spindle so the ball joint stem seats deeper.
"Everyone reading this is a PO."
