Posted: Thu Jul 11, 2002 10:34 am Post subject: Need help with identification |
I have a 67 campmobile (possible late production)and I'm trying to figure out what colors were originally painted on the exterior. The M-Code plate lists the following:
523907
I can't seem to match these numbers with the chart. Does anyone know what they are?
Also, I have complete Westfalia camping equipment that appears to be original, but the plate reads SO-67 ... 1969. My M-Code plate includes the code 108 (Westie SO-42 kit). Do I have the original kit, or did someone put another kit in the bus?
Thanks! |
UZI Platinum FUBU
Joined: February 08, 2002 Posts: 12855 Location: phila-DELFT-ia
Posted: Thu Jul 11, 2002 2:51 pm Post subject: Need help with identification |
| post the entire plate. once you've figured one out it's easy. some numbers haven't been deciphered. others are good guesses. |
Posted: Thu Jul 11, 2002 3:50 pm Post subject: Need help with identification |
Here's the entire M-code plate:
03 0
425 A42 025 108 139
UK 2312 523907 7036852 |
Posted: Thu Jul 11, 2002 4:12 pm Post subject: Need help with identification |
The plate on the camper kit reads:
WESTFALIA-WERKE ...
SO[67] 15195 19[69] |
Hella Bro Samba Member
Posted: Fri Jul 12, 2002 4:21 am Post subject: Need help with identification |
Corina,
Good questions.
I think Westies have a different M plate readings. Where the code for the paint and upholstery usually are,Westys have there
camper code,,yours reads 523907 instead of the paint numbers.
The Westy kit you have is from a 69 camper.
They were SO-67.
Look inside door panels and engine compartment for orig. paint clues. |
UZI Platinum FUBU
Posted: Fri Jul 12, 2002 6:39 am Post subject: Need help with identification |
425 seat belts
A42 so42 camping iterior
025 us spec bumpers
108 camping equip
139 sealed beam headlamps/red taillights
uk usa unknown
231(2) kombi w/ nitro laquer finish
those other number, somebody else may have to jump in. |
UZI Platinum FUBU
Posted: Fri Jul 12, 2002 6:46 am Post subject: Need help with identification |
| 907 is lotus white |
Posted: Fri Jul 12, 2002 11:50 am Post subject: Need help with identification |
| Thanks all for the helpful information! |
Posted: Fri Jul 12, 2002 11:56 am Post subject: Need help with identification |
| One more question. What about the date on the M-Code plate? Does it stand for October 3rd? |
58Type2 Samba Member
Joined: June 15, 2002 Posts: 636 Location: Hell's Soup Kitchen
Posted: Sat Jul 13, 2002 3:10 am Post subject: Need help with identification |
523907 should be upper body color (52), lower body color (39) and interior color (07). Not sure what the colors are at this time. Will look around.
And by dropgates.com articles, the last set of #'s should be the VIN, but there is no 7 for a first number. If it was a 1, as would be the case by their site, it would make your bus to have been made in Oct. 1962
Here, will just give their link for the M-Code plate ID:
http://dropgates.com/identity/mplate.html
Jax |
Posted: Sat Jul 13, 2002 5:22 am Post subject: Need help with identification |
earlyman3,
I thought lotus white is L282/42 and would appear as 42 on the M plate. 424283 for top and bottom colors and upholstery since its not a deluxe. Please let me know what source or book you have,Id like to pick up a copy
for my references. Thanks |
UZI Platinum FUBU
Posted: Sun Jul 14, 2002 7:17 pm Post subject: Need help with identification |
| i found that on vintagebus registry. those numbers were wacky and didn't read like they should. since i didn't have the VIN i used one of my own (not a lotus white bus) that the way it came out. that set of numbers describes the exterior color(s) and interior pattern or color. it's easier when you have the bus nearby so you can compare notes and say "oh, yeah...." |
UZI Platinum FUBU
Posted: Sun Jul 14, 2002 7:18 pm Post subject: Need help with identification |
| "the original VW bus" by laurence meredith is great, NEATO is also putting one out soon authored by david eccles, i forgot the name tho' |
das nut Samba Member
Posted: Tue Jul 16, 2002 7:11 am Post subject: Need help with identification |
that'll be
VW Transporter & Microbus Specification Guide 1950 - 1967
buy it from www.vwbooks.co.uk! |
Posted: Thu Aug 08, 2002 5:36 pm Post subject: Need help with identification |
I was just looking through the Split Bus literature and found the Campmobile color codes. On the 1966 Campmobile page, the first page of text lists the following:
Exterior Colors
523 506 dove blue
523 642 velvet green
523 907 pearl white |
