Rust Repair, 74 Super Convertible
Goto page Previous  1, 2, 3 ... 8, 9, 10 ... 13, 14, 15  Next
jesse09
jesse09 is offline
PostPosted: Sat Nov 19, 2011 7:48 pm    Post subject: Reply with quote
Car looks good man! I'm new to the Samba and just caught your thread. It's funny because I am on the east coast and have been painting my car the same way you are. This weather has not been good for us!
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Sun Nov 20, 2011 8:05 am    Post subject: Reply with quote
You only have three ways to close the gap
(1) Shim body mounts
(2) Pull the gap together hydraulically from the top
(3) Push the gap apart hydraulically at the bottom
(4) Bend the hinges
It would be my suggestion that you might apply all three
Jerry
Experience always triumphs over hearsay and You get to select which theory to believe
mnussbau
mnussbau is offline
PostPosted: Sun Nov 20, 2011 8:53 am    Post subject: Reply with quote
(4) Bend the hinges
Jerry
Uhh...that would be four ways... Laughing
Mike
A nice pair (of '74s)
Parts...
djkeev
djkeev is offline
PostPosted: Sun Nov 20, 2011 9:01 am    Post subject: Reply with quote
(4) Bend the hinges
Jerry
Maybe Jerry had too much Tequila last night??? Sick
(o\ ! /o) (o)=l=(o)
1974 Super Convertible
http://www.thesamba.com/vw/forum/viewtopic.php?t=482968&highlight=rust+repair
Creating a 69 1/2 Ghia Convertible out of a 69 Coupe and a 70 Convertible
And the newest arrival!....... 86 Vanagon Westy!
JerryMCarter1
PostPosted: Sun Nov 20, 2011 9:06 am    Post subject: Reply with quote
Maybe the gap is caused by the empty frigde below
djkeev
djkeev is offline
PostPosted: Sun Nov 20, 2011 9:33 am    Post subject: Reply with quote
Fridge ain't empty no more!!!! Laughing
(o\ ! /o) (o)=l=(o)
djkeev
djkeev is offline
PostPosted: Sun Nov 20, 2011 12:17 pm    Post subject: Reply with quote
Front Door crack darn near perfect now!! Amazing what a few intelligently placed shims can do to correct a problem.
How gap was......
Gap Now......
It was curious, the Convertible frame bolt under the rear seat, was only partially in, you could see exposed threads above the torsion bar!!??!!
Here's the bolt, at the end of the screw driver
see the threads exposed within the red circle...
Turns out this convertible body bolt was also bent and too long as well. The bolt bottomed out on the casting for the rear support members. I used a shorter bolt, ran a tap through the threads, anti-seized everything and reassembled it tight.
For the bolt on the inner fender I jacked up the rear bumper mount, pulled out the rotten spacers and installed metal spacers (for the time being until the new rubber ones arrive) and now all fits just fine!
It is obvious some PO has been in there doing something at some point!! Grrrrr!
I'm fairly certain and this door gap was like this all along, I just didn't take notice beforehand... Live and Learn....Next time I'll be aware of such things....if I remember!!
Dave
(o\ ! /o) (o)=l=(o)
djkeev
djkeev is offline
PostPosted: Mon Nov 21, 2011 8:52 am    Post subject: Reply with quote
Well, it's not raining so I took the VW out of the garage for a bit of airing out. Actually under the VW looked like a dirty horse stall so a good sweeping was in order!!
Photo Op outside, Right side is mostly reassembled, awaiting rubber bits for the lights and doors from Chuck's Convertible. Figured I'd turn it around and work on the left for awhile.
Now, I readjusted the rear torsion bars, by my reckoning about 1.6 degrees up. I feel the car sits better now but the front is still high. Then again, the car is lacking seats, all glass, front hood, Top etc. The gas tank is about 3/4 full and the spare in in. I think once these items are re-installed that the car will sit almost perfect!
Here's a view of the front wheels tucked under from lack of curb weight.
(Yes, that's an Oregon Ducks blanket I'm using to repair and repaint the car. We were Oregonians back in the 70's.)
Here's a photo of the suspension before and then after the torsion bar adjustment.
Dave
(o\ ! /o) (o)=l=(o)
JerryMCarter1
PostPosted: Mon Nov 21, 2011 8:56 am    Post subject: Reply with quote
YOur going the wrong way
Jerry
djkeev
djkeev is offline
PostPosted: Mon Nov 21, 2011 9:03 am    Post subject: Reply with quote
Jerry
Matter of Opinion. I like the stock ride height, always have, probably always will. I was never into suspension mods even when I was in automobiles full time. Just doesn't interest me at all, I don't care for a lot of the extreme lowering that is done. Some of the more mild lowering does look good though.
I know I probably stand somewhat alone with this stock ride height mindset, but the next owner can lower it, slam it, bag it, or whatever "it" that they desire to do.
Dave
(o\ ! /o) (o)=l=(o)
JerryMCarter1
PostPosted: Mon Nov 21, 2011 9:28 am    Post subject: Reply with quote
the car is not at stock height
sorry
Jerry
Q-Dog
Q-Dog is offline
PostPosted: Mon Nov 21, 2011 10:15 am    Post subject: Reply with quote
Dave, your car does seem to be higher than stock.
Brian
'69 Dune Buggy, http://www.thesamba.com/vw/forum/viewtopic.php?t=419624
'69 Beetle Convertible
'70 Beetle, http://www.thesamba.com/vw/forum/viewtopic.php?t=544918
djkeev
djkeev is offline
PostPosted: Mon Nov 21, 2011 10:40 am    Post subject: Reply with quote
Keep in mind that is has NO......
Interior
Glass
Top
Front lid
After it's all back together, If I need to adjust it I will. Currently the front end is sitting 1 3/4 " higher than the rear.
Thanks for your comments and advice, we'll see what it looks like in a week or two or three when most of this stuff is back on the car.
Dave
(o\ ! /o) (o)=l=(o)
60ragtop Premium Member
60ragtop is offline
PostPosted: Mon Nov 21, 2011 10:49 am    Post subject: Reply with quote
this is why you are spinning your wheels till you get it altogether Wink
Good thing your time is free.
Stock height now Laughing
JerryMCarter1
PostPosted: Mon Nov 21, 2011 11:08 am    Post subject: Reply with quote
We get that Dave !
But from your original pic the car is sitting to high in the front - unusually high - ( some shock problem ) and the rear was a small amount to high
What is your tire size ?
Jerry
djkeev
djkeev is offline
PostPosted: Mon Nov 21, 2011 12:16 pm    Post subject: Reply with quote
Hmmmmmmm, you guys are probably right.....that would make me....um, er, ahh...... wrong?? Embarassed Embarassed
I'm running 165 R 15 Tires.
Here is a picture from the 74 brochures..... Except for finding out what kind of front shocks I have, I'll leave well enough alone until it's all put back together!!
Dave
(o\ ! /o) (o)=l=(o)
mnussbau
mnussbau is offline
PostPosted: Mon Nov 21, 2011 3:45 pm    Post subject: Reply with quote
Your front end does seem too high. It's hard to imagine the front coming down THAT much even after installing those parts.
Maybe tough to see from this angle, this is stock. I do think the rear has sagged slightly.
This is the front after installing 185/65R15 tires.
Mike
Parts...
JerryMCarter1
PostPosted: Mon Nov 21, 2011 4:00 pm    Post subject: Reply with quote
my stock 73 super vert with 47,000 miles on it with a new set of 165's is exactly 9 inches to the bottom of the running board - about 9 1/4 on the front
djkeev
djkeev is offline
PostPosted: Mon Nov 21, 2011 6:31 pm    Post subject: Reply with quote
Thanks Jerry, mine are a bit higher than yours.
Supers are a new animal to me, I cut my teeth of Ovals and early 60's units. I swore that I'd NEVER own a Super!!! As the saying goes.....NEVER say NEVER!!!! Laughing
Question for someone running a stock set up such as mnussbau is, could you take measurements when sitting at rest on a level surface to the upper fender opening as indicated by the green lines on the photo below?
I've been unable to find factory dimensions for ride height. I've easily located factory angle setting for the torsion bar. I've found that there were three strengths of front springs installed as well.
Mnussbau, your's looks about where I'd like mine to sit.
Thanks for your time and efforts to anyone who takes the time to go out and measure for me!!
Dave
(o\ ! /o) (o)=l=(o)
flyboat Premium Member
flyboat is offline
PostPosted: Mon Nov 21, 2011 6:46 pm    Post subject: Reply with quote
Dave, once the car is complete, if you want to readjust, you can place the rear suspension back like it was and run rear shocks with springs. This will boost the rear from the low position that is was. the springs act as helper springs.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Z06 Vette
Page 9 of 15
