Sigeats Samba Member
Joined: November 10, 2008 Posts: 161 Location: San Diego
Posted: Mon Oct 10, 2011 2:15 pm Post subject: another temp light problem |
Start engine and temp light blinks until my radiator fan kicks on, then it goes out. After that everything seams to work fine.
Thoughts? _________________ '84 Westfalia |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Mon Oct 10, 2011 2:24 pm Post subject: |
Have you verified that the pressure tank (this one)...
...is full when the light is blinking?
How soon does your fan kick on (mine takes a long time idling or a steep mountain road to get to that point)? |
Posted: Mon Oct 10, 2011 2:32 pm Post subject: |
yes, pressure tank is full. Fan doesn't kick on until I let the Van idle in the driveway for about 30 minutes. The temp needle needs to climb to about the top end of the light before the fan kicks on. I have a new temp switch on the radiator, and my mechanic tested the switch with one of those temperature sensor gun things, and the fan kicked on exactly when it should.
I figure it must be a bad connection or something since the light stops blinking the second the fan kicks on. When the fan turns off again . . . usually about ten or twenty seconds after it initially kicks on, the light remains off as is should. _________________ '84 Westfalia |
Posted: Mon Oct 10, 2011 4:08 pm Post subject: |
on second thought . . . the switch is not new. Maybe I have a bad switch on the radiator. Is that hard to replace? Do you just unscrew it quickly and try to get the new one in before to much coolant escapes? I guess I could replace the temp sensor in the pressure tank while I'm at it. _________________ '84 Westfalia |
Posted: Mon Oct 10, 2011 4:23 pm Post subject: |
New or old -- sounds like your radiator switch is performing normally.
That sensor in the pressure tank is not a temp sensor, just checks that the coolant level is nearly full (simple completion of a circuit when the tip of the sensor is immersed).
You can get that sensor out of the circuit by unplugging the plug to it and jumping those connections -- a paper clip should do it. If doing that resolves the problem then likely that sensor is bad.
Could be that it is failing (they can get corroded/contaminated) and only functioning when the coolant is very hot. |
Posted: Mon Oct 10, 2011 4:30 pm Post subject: |
When I unplug the wire connected to the sensor in the pressure tank, with the engine running, the needle on the temp gauge shoots up as if the temperature was crazy hot . . . is that normal? _________________ '84 Westfalia |
Posted: Mon Oct 10, 2011 4:34 pm Post subject: |
. . . also, the light starts blinking again with the wire on the pressure tank unplugged . . . sounds like that part is working as it should.
Maybe just old corroded sensors like you said. _________________ '84 Westfalia |
Posted: Mon Oct 10, 2011 5:04 pm Post subject: |
Normal... now jumper the plug to see if that settles the needle & gauge down. |
Posted: Mon Oct 10, 2011 5:06 pm Post subject: |
Will do . . . thanks for all your help!
I'll post the verdict when I get a chance to test it. _________________ '84 Westfalia |
