SpeedVagon.. NOT
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
a1fa
a1fa is offline
PostPosted: Tue Nov 22, 2011 7:50 am    Post subject: Reply with quote
bueller? bueller? bump.. love talking to myself. Cool
Learn to ride. Ride to learn.
j_dirge Premium Member
j_dirge is offline
PostPosted: Tue Nov 22, 2011 8:21 am    Post subject: Reply with quote
a1fa wrote:
Mad shox.. gowesty is out of fuel tank sealing kits.... what is the next best alternative?
http://www.van-cafe.com/home/van_1321933454737/smartlist_743/fuel_tank_reseal_parts.html
89 GL Westy, orig 2.1L WBXR.. Will it ever blow?
Well.. yes. It blew.. a big hole in the case. Time for a new engine.
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
a1fa
a1fa is offline
PostPosted: Tue Nov 22, 2011 8:23 am    Post subject: Reply with quote
What's the quality on those?
j_dirge is offline
PostPosted: Tue Nov 22, 2011 8:27 am    Post subject: Reply with quote
Haven't done the job myself... But Van Cafe's parts selections are usually very good quality.
Have spent several thousand dollars there. My preferred source over GW.
If you do a search "fuel tank reseal" (or some combination thereof, on this forum, you'll find several threads on resealing.
And many opinions, of course.
a1fa
a1fa is offline
PostPosted: Tue Nov 22, 2011 8:59 am    Post subject: Reply with quote
thank you.. now, on my fuel injection thing.. i am thinking about disconnecting an o2 sensor from one of my motorcycles, and putting an extension pipe onto the exhaust tip as a makeshift o2 sensor to tune the FI. any objections? its either that or pay someone $100 to do it... i still would not be satisfied.. i think.. Shocked
reluctantartist
reluctantartist is offline
PostPosted: Tue Nov 22, 2011 9:11 am    Post subject: Reply with quote
There should be a shop somewhere that would do it at a reasonable cost.
Oh.and check bus depot for parts too.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
a1fa
a1fa is offline
PostPosted: Tue Nov 22, 2011 9:19 am    Post subject: Reply with quote
I'd be looking at at least $110+ with the labor rates.. they get you with "$65/diagnostic, ~$50 hands, $5 hazard".. etc..
a1fa
a1fa is offline
PostPosted: Fri Dec 02, 2011 2:46 pm    Post subject: Reply with quote
I am frustrated. I bought a new exhaust from busdepot, and it does not fit on my bus.. I even banged on heater intake to get it to fit.. its close, but still not there... the top heat shield is in the way.
veloandy
veloandy is offline
PostPosted: Fri Dec 02, 2011 3:38 pm    Post subject: Reply with quote
Or even worse, do what I did: Pay this twice to two different mechanics to only have it still not set correctly...and then stare down paying it again if you make any big changes.
I ended up doing what I should have done in the first place: Paid an exhaust shop $15 to weld in an O2 sensor bung and bought a 2-wire Bosch O2 sensor at a FLAPS for $25. Now I just set the richness at idle and at speed using a volt meter attached to the O2 sensor's leads. The O2 sensor puts out just under 0.5v when hot if the mixture is set correctly. More if rich, less if lean. The reading is noisy (with occasional weird spikes/valleys) and switches between + and - volts...but it is definitely do-able...For Example:
Readings like: -.756, .853, .655, -.834, .430,... Mean rich
Readings like: .543, -.430, .487, .630, -.440,... Mean right on
Readings like: .114, -.220, .137, -.800, .107,... Mean lean
Got me past CO emissions eventually
Good Luck,
-Andy
a1fa
a1fa is offline
PostPosted: Mon Dec 05, 2011 3:52 pm    Post subject: Reply with quote
bump
reluctantartist
PostPosted: Tue Dec 06, 2011 8:59 am    Post subject: Reply with quote
German supply has the adapters you need. Or you have to dent the muffler to make it fit. I would get the adapters from German supply.
http://www.germansupply.com/home/customer/product.php?productid=17477&cat=332&page=1
a1fa
a1fa is offline
PostPosted: Tue Dec 06, 2011 3:54 pm    Post subject: Reply with quote
reluctantartist you are a gem! I'm in UK at the moment and traveling to Poland on Saturday, and was wondering if I should stock up on parts... Wink
reluctantartist
PostPosted: Tue Dec 06, 2011 6:52 pm    Post subject: Reply with quote
Unfortunately as far as the engine, I think the 1600 cc was more popular. But if I were you and had a chance to get stuff, yes definitely stock up.
a1fa
a1fa is offline
PostPosted: Fri Jan 13, 2012 7:21 am    Post subject: Reply with quote
Crying or Very sad It has been a while since last post. Yesterday we had close to freezing temperatures. Day before yesterday I added a quart of Lucas oil treatment into 10W30, to help with what appears to be a rod knock. I also tested the battery to make sure she will crank in the morning. 385/485A, a bit low, but would do. Drove it home, and parked it. The next day I tried to start it, she barely turns over, and no start. Should have left it in the driveway. I tried to roll it down the hill and bump it, but its a no go... so roll it down the street and park it on the side of the road. When I came back home, someone left me a nice tire mark and a long ass scratch on the side of my van. Evil or Very Mad Twisted Evil Shocked Crying or Very sad Crying or Very sad Crying or Very sad
A friend came by with one of those new Tundras to give me a jump... it was no go. it would barely turn over.
Couple of things I can think off:
-- Battery is dead. This one is guaranteed,
-- The oil is way too thick now with Lucas in there. Possible.
-- Starter is weak. Plausible.
-- Grounds have finally decided to take a hike.
Shocked
oreana123
oreana123 is offline
PostPosted: Fri Jan 13, 2012 12:22 pm    Post subject: Reply with quote
Hi. 81 aircooled Vanagon 2wd
I have read your posts with interest because I have had a lot of the same problems. Starting with the "knock" you hear, I can't help but think about your hyd lifters. All of your oil changes and additives will help to loosen up your valve train and perhaps cure the knock. My lifters were knocking until the 2nd oil change, they have since quited considerably. Because I live where it is cold, I run synthetic multigrade but I will change to straight 30w when it warms up.
My van was a $500 CL special, and had been stripped of many parts, including FI components. This situation forced me to learn the FI system and in the course of returning my engine to running condition, I cleaned every part and replaced any rubber possible. I too had a leak in the intake boot and replaced it from the junk yard.
My van is a passenger model. I have added a Westy bed but I try not to load up the van with anything like you have to carry around. I just weighed my van for a total of 3550 lbs with full fuel and me sitting in it. The low weight factor allows me to cruise at 70 mph easily on the freeway.
I would recommend an oil temp gauge install if you do not have one already. In the hottest weather here in Idaho, my driving is limited by my oil temp gauge. It tells me when to get my foot out of it. I have spent a lot of time closing up the engine compartment to aid the cooling system.
As far as your charging and starting problems go, know that batterys generally die whenever they are exposed to temp extremes- whether heat or cold. I also have reservations about using the body sheet metal for a ground return- I plan on fabricating a separate ground run to the engine block just to completely cure any possible ground resistance.
I just received a set of rear shocks I'd like to install but it is in the mid 20s outside (I know I am a whiner! Very Happy ). Do not lose heart, when your van comes together you will have a real jewel.
a1fa
a1fa is offline
PostPosted: Fri Jan 13, 2012 12:27 pm    Post subject: Reply with quote
Here is the damage:
oreana123
PostPosted: Fri Jan 13, 2012 1:42 pm    Post subject: Reply with quote
Ah what the heck- I just put on the rear shocks in about 15 minutes- remove the wheels and it is easy.
oreana123
PostPosted: Fri Jan 13, 2012 1:43 pm    Post subject: Reply with quote
Oh man that is so FU- any way to find out who?
a1fa
a1fa is offline
PostPosted: Fri Jan 13, 2012 1:51 pm    Post subject: Reply with quote
I'll be walking my dogs around the neighborhood.. I'll be sure they sniff around every car. I'll find the perp....
reluctantartist
PostPosted: Sat Jan 14, 2012 11:40 am    Post subject: Reply with quote
My camper will run the battery low if left to sit for a long time. There are a lot of things that provide a slow drain on it. I am running 0w30 oil in mine during the winter. It may be grounds if the jump did not work.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 7 of 9
