SpeedVagon.. NOT
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
reluctantartist
reluctantartist is offline
PostPosted: Wed Oct 05, 2011 10:06 am    Post subject: Reply with quote
Make sure it is a good shop .... it sounds like you have an exhaust leak plus all the other vacuum leaks in the usual locations. This will never run right until all of that is taken care of and potentially trash the engine from running lean. You might also want to make sure the temp 2 sensor is checked. These vehicles are old there is not a single 30 year old vehicle that does not need maintenance on the vacuum system if it has all of the original hoses. The rubber vacuum hoses do not last that long so even a low mileage vehicle will have issues. Don't let your shop get away with doing a hatchet job on the vacuum system by misadjusting the Air fuel mixture to make up for a vacuum leak. Also if you are going to keep this you really need to get the shop manual and start learning to do some work unless you have deep pockets to pay another mechanic. The air cooled is simpler to work on than the wbxr but is less forgiving if something is not correct. After you get it running the next thing would be to make sure your engine compartment is properly air tight. Of course I assume you have replaced the fuel lines.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
Andrew A. Libby
Andrew A. Libby is offline
PostPosted: Wed Oct 05, 2011 11:20 am    Post subject: Reply with quote
That is just not at all true. There is nothing simpler about it. The cooling and heating system of the air-cooled is more complicated than that of the WBX (and also much less effective...) and makes almost every task more difficult. The only exception I can think of is actually bleeding the system, which is unnecessary on the air-cooled.
reluctantartist
PostPosted: Wed Oct 05, 2011 11:38 am    Post subject: Reply with quote
I disagree but to each his /her own choice.
The main point is in order for a vanagon to be economical to own the owner needs to be willing to get to know how the vehicle works. And lets keep this thread on the topic.
a1fa
a1fa is offline
PostPosted: Wed Oct 05, 2011 12:04 pm    Post subject: Reply with quote
I'm ordering a manual. Does anyone sell an all inclusive vacuum replacement kit? That would be nice.
Learn to ride. Ride to learn.
a1fa
a1fa is offline
PostPosted: Wed Oct 05, 2011 7:34 pm    Post subject: Reply with quote
Vagon is back from the shop. Plugged up fuel filter. I guess I was getting low to EMPTY and it sucked all that junk in. That means it may happen again since I don't have a working fuel gauge to keep it at least on half talk always. May have to go by miles. I got approximately 14.2 mpg, city driving, and some hills.. about ~ 200 miles to 14 gallons.
Tonight I made my own EGR block-off plate (but I did not disconnect the EGR valve from the throttle), restarted the EGR counter, and officially rolled over my odometer. Now its back to 0, as if it is brand new (bought it at 99.8k, and put 200 miles in 7 days). Vagon idles slightly better. I ziptied a few more vacuum lines. I can still hear hissing from somewhere around the airbox boot... wtf.
a1fa
a1fa is offline
PostPosted: Wed Oct 05, 2011 7:59 pm    Post subject: Reply with quote
New video, EGR blocked off, 1 exhaust leak fixed (1 to go), some vacuum hoses addressed.. can anyone tell me what is that "hissing" sound.
http://www.youtube.com/watch?v=7iJRNjMn3RA
Andrew A. Libby
PostPosted: Wed Oct 05, 2011 9:34 pm    Post subject: Reply with quote
I'll follow your lead on that...
You sound like you've only owned air-cooleds.
Andrew A. Libby
PostPosted: Wed Oct 05, 2011 9:39 pm    Post subject: Reply with quote
a1fa, that sounds like a vacuum leak. Sometimes you can locate vacuum leaks by squirting starting fluid at connections. When the idle raises, you've found a vacuum leak.
reluctantartist
PostPosted: Thu Oct 06, 2011 7:47 am    Post subject: Reply with quote
Unfortunately, as far as I know there is not a vacuum hose kit for the air-cooled vanagon. Looking at your picture all of the braided hose needs to be replaced ad well as the rubber pieces that are involved in the connections. A temp fix for the rubber pieces is to take them of squeeze them to find cracks and fill the cracks with shoe goo. That will fix the big intake boot too until you by a new one.
Go to airhead parts or bus depot or bus boys these are the numbers for the rubber parts:
022-133-083 rubber y
071-129-967 intake elbow
022-129-637 aar elbow
022-133-073 throttle body gasket
039-133-241 intake manifold sleeves (4)
You can use silicon heater hose for some of the larger vacuum hose at your FLAPS or the places I listed have the hose available. I do not like the braided hose myself.
And here is a discussion on blocking off the EGR.
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 8:01 am    Post subject: Reply with quote
I am going to order all those parts, and a new exhaust, and maybe a new gas tank with new hoses. There was bunch of junk in my fuel filter, not sure if the tank is peeling. Will not know until I drop 'er down. Embarassed
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 8:06 am    Post subject: Reply with quote
Where can I get the braided vacuum hoses? Someone suggested some braided hose from Lowes/Home Depot... anything else? How about the small vacuum lines? Mad
Jake de Villiers
Jake de Villiers is offline
PostPosted: Thu Oct 06, 2011 8:43 am    Post subject: Reply with quote
You can get the braided hose from Van Cafe or Bus Depot - you'll find the smaller vacuum hose at the local car parts store - Schuck's, O'Reilly, NAPA. Stay away from the lumberyard for car parts - the materials aren't designed to deal with the heat levels in an engine compartment.
'84 Vanagon GL 1.9 WBX
www.crescentbeachguitar.com
www.thebassspa.com
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 11:27 am    Post subject: Reply with quote
Thank you. I lubricated the shift assembly at lunch hour.. it needed it.. i am wondering if there is an height adjustment inside the assembly. It's a bit easier to add it into reverse now. Sometimes you can accidentally drop into into reverse.. Guess the push-down travel is a bit shorter now. =)
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 3:31 pm    Post subject: Reply with quote
Couple of little loose ends left to wrap:
- Leaky windshield wiper reservoir / JB Weld to the rescue.
- Bouncy speedometer Question
- Incorrect fuel gauge.. It's sporadic. It shows half tank on full Question
ftp2leta
ftp2leta is offline
PostPosted: Thu Oct 06, 2011 3:59 pm    Post subject: Reply with quote
Hi and welcome.
I can hear the knock, knock and acceleration is not a good thing, it's mostly a loose rod problem, could be at the bigger end OR small end.
Take the engine compression. If compression is low have a leak down test done.
Aircool engine produce a fair amount of air displacement so it's sometime very difficult to pin point an air leak.
The 2.0L is also known to drop valve seat so that is why you need la leak down test.
Your air leak sound like it's coming from the Acceleration valve and not the cold start air valve. but again, if it's running rich on idle the cold start valve must be dead... they are all dead even on 1.9L (same valve).
this is dropped valve seat (engine was still running):
2.0L with a strange knocking sound:
Worn cam bearing and cam also make a very strange noise:
Ben
Working with rust, grease, dirt and dust is a sad truth.
Engine and FI part for sale CHECK MY ADS HERE!.
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 6:39 pm    Post subject: Reply with quote
Yikes.. you been there, and done that... ouch.
dhaavers
dhaavers is offline
PostPosted: Thu Oct 06, 2011 7:35 pm    Post subject: Reply with quote
Replace the sender while you have the tank down...
86 White Westy Weekender
"The WonderVan"
reluctantartist
PostPosted: Thu Oct 06, 2011 7:36 pm    Post subject: Reply with quote
Ben knows how to give nightmares.
a1fa
a1fa is offline
PostPosted: Thu Oct 06, 2011 7:47 pm    Post subject: Reply with quote
Hopefully my engine is just knocking for attention.. Embarassed
ftp2leta
ftp2leta is offline
PostPosted: Thu Oct 06, 2011 8:25 pm    Post subject: Reply with quote
Sorry for that but that is all I see. Let's call it reality... for some.
My conclusion: The 2.0L pancake engine was not design for the heavy vanagon. It was under cooled. To have a OK running 2.0L that won't let you down you need to keep it clean and cool.
The ultimate air cool cooling picture:
Yep, clean you cooling duck once every 2 years. What kill those engine is heat, to much of it.
I was able to run my 79 at 350F on each head for 1000' of miles but never on a vanagon. Of course my engine was on 2 carbs well jetted, the Ljet FI was running to lean for fuel economy (NOT) and low emission shit.
To have a great running air cool pancake you need that:
Been there done that. I have converted air cool Vanagaon and bus's to twin card and never had problem. Even the single Progressive Weber is better that that stupid L-Jet injection.
I know a guy who as a prefect running 81 Vanagon, engine was built by Boston Bob, FI was clean and running perfectly (tested), engine was kept clean and well maintain... Still running good today.
Owner is very careful and knowledgeable about his machine, not like the average owner.
High maintenance van and engine... WW1 era design.
Enough of that.
Ben
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 3 of 9
