carlostam Samba Member
Joined: September 16, 2009 Posts: 414 Location: Pembroke Pines,FL
Posted: Sun Nov 27, 2011 8:34 am Post subject: |
ALB wrote: |
carlostam wrote: |
Ok so I have another question.... The oil plug under just under the distributor is not flush with the case. Its snug in there, and it was finger started. So my questions are how tight can I torque and how many threads inside the case is enough?
Thanks |
With some sort of thread sealer I would think that a couple full threads would be enough. I'm guessing you're thinking it should be tapped a little deeper but now the short block is together? Some grease on the tap will catch the chips if you're careful. Take it slow and clean the chips out as you go. I wouldn't tighten it more than about 8 or 10 lbs. Any one with more experience?
I couldn't help but notice....before you mount the sheet metal underneath the pulley, if you take a file and round off the brass full flow return fitting it will be way easier to bash said sheet metal to clear.... |
Thanks alb, yea I checked the tin with the pulley in place and I was able to get good clearance after a bit of modification. |
Posted: Wed Dec 14, 2011 4:15 pm Post subject: |
Ok well, I'm back just received my Heads and they look great.......
Ok guys help me out here, I just mocked it up and I foresee a problem with the stud not having enough threads and this is only with the barrel shims I still have to place the copper shims. What to do help please....
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Wed Dec 14, 2011 4:34 pm Post subject: |
carlostam wrote: |
those look great...who did them?
and get longer studs _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Wed Dec 14, 2011 6:07 pm Post subject: |
Help from the samba world....Ok been breaking my head over this. If you look at the studs in front of the intake you'll notice that its longer then its suppose to be. Then the studs in the second picture it's to short. Now I have been trying to figure if I place the studs in a wrong pattern but it seems to me this is the only way they can go. Your help and experience will be highly appreciated.
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Wed Dec 14, 2011 6:43 pm Post subject: |
A DP type-1 uses THREE lengths of studs. longest on the bottom, medium on the top outside, and the shortest in the top middle
Is it possible your studs are from a singleport? |
Posted: Wed Dec 14, 2011 6:50 pm Post subject: |
modok wrote: |
Modok did not recognize you without your avatar.
Modok I'm trying to figure out if it was a single port but if I recall correctly it was a dual port. How can I figure this out modok. If you look at the pictures there not much of a difference from one in the middle to the one on the outside..
Thanks man |
mark tucker Samba Member
Posted: Wed Dec 14, 2011 6:59 pm Post subject: |
try swapen the studs. |
modok Samba Member
I guess we have to measure some normal vw studs to determine what is normal, and then you can try to figure out what's going on with yours
Off hand I don't remember how long they are, believe it or not
I'll measure mine, and you measure yours, and lets meet back here in 20 minutes |
Posted: Wed Dec 14, 2011 7:02 pm Post subject: |
mark tucker wrote: |
Mark, yea I tried that well I measured the stud sizes and It would not work any other way so, modok hit it on the nail, it must have been a single port. Now I hope that I can find some dual port studs to replace the ones that don't fit instead of buying a complete kit...
thanks mark |
Posted: Wed Dec 14, 2011 7:04 pm Post subject: |
modok wrote: |
Hell in 20 mins I'll have start over every three minutes |
modok Samba Member
Posted: Wed Dec 14, 2011 7:17 pm Post subject: |
As luck would have it I have a box of studs right here next to the computer, but I had to go in the bathroom and get a tape measure from next to the fish tank
The long ones are about 9 3/8"
The medium ones are just under 8" |
Posted: Wed Dec 14, 2011 7:21 pm Post subject: |
modok wrote: |
Ummm....and why would there be a tape measure in the bathroom? _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Posted: Wed Dec 14, 2011 7:23 pm Post subject: |
Is that odd? |
Posted: Wed Dec 14, 2011 7:24 pm Post subject: |
modok wrote: |
I'm not even going to ask why the tape measure in the bathroom
Yea, I'm going to have to change up, they are from a single port. Dam start over again.
Ok modok let me pick your brain again. So how many of what length will I need to convert?
Or will I need to change all of them? |
Posted: Wed Dec 14, 2011 7:26 pm Post subject: |
Guess not.....if you're building a new counter or some shelves......tried to make a joke.....it didn't turn out too well.... _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Wed Dec 14, 2011 7:28 pm Post subject: |
Dude....you're snake bit.....nah...just kidding....but seriously, I get to see all these hidden problems by the guys already at the build point.......it'll work out fine soon enough... _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Posted: Wed Dec 14, 2011 7:33 pm Post subject: |
The funny thing is you didn't ask why there is a fish tank in there..............
If the case has the deep stud mod, you will need an extra long one, otherwise it is like I said above. Check to see if the lengths I listed will work, they should unless your engine is really wide or something.
i'll go and fine a short one to measure, none in this box |
Posted: Wed Dec 14, 2011 7:36 pm Post subject: |
Fish tanks are normal in the bathroom.......they help you to relax while you soak achy joints because you're out of advil.. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Wed Dec 14, 2011 7:46 pm Post subject: |
modok wrote: |
I figured the fish tank was your toilet..... |
Bill271 Samba Member
Posted: Wed Dec 14, 2011 7:54 pm Post subject: |
Brown trout! |
