mhisel Samba Member
Joined: October 03, 2007 Posts: 249 Location: Los Angeles metro
Posted: Thu Jan 23, 2014 9:52 pm Post subject: |
I finished matching the chambers. I tried to make the best of what i have. Now I am going to match the manifolds.
mhisel Samba Member
Posted: Sat Jan 25, 2014 6:43 pm Post subject: |
I started swirling the intakes. This will help with atomization.
I have been talking about upping my carbs from 44IDF (sell them) and step up to 48's also selling these heads (40x35.5) and going with 42x37.5 |
bdub475 Samba Member
Joined: April 05, 2009 Posts: 577 Location: Los Lunas, New Mexico
Posted: Sat Jan 25, 2014 7:30 pm Post subject: |
I'm Iinterested in the 44's. Pm me with a price. |
mhisel Samba Member
Posted: Thu Mar 27, 2014 10:33 pm Post subject: |
I started working on the heads I just finished intakes and exhaust ports on one of the heads. The valve size are 44x37.5
Very excited and motivated to finishing this build. It has been a long time coming. |
mark tucker Samba Member
Posted: Fri Mar 28, 2014 10:21 am Post subject: |
I would of just added biger valves to those heads. 42x37 should fit those seats. a little too much bowel on the ex side for my likes (might of used a reverse dome piston instead)but intake side looks good. I like a 60 grit finish on the intake side.(chamber&port) nice work.getter done&have fun |
mhisel Samba Member
Posted: Sat Mar 29, 2014 10:19 am Post subject: |
mark tucker wrote: |
The picture above are not the heads I am using. In the image, those heads are 40x35.5.
I am starting over and using 44x37.5. Although, I do appreciate the feedback. |
mhisel Samba Member
Posted: Fri Apr 04, 2014 1:30 pm Post subject: |
Almost finished with my heads. Only a few more hours of work. Then send them back to the head shop so they they can do a valve job, install valve guides and the rest of the assembly. My goal is be at about 10.75:1 static compression. |
mhisel Samba Member
mhisel Samba Member
Posted: Tue Apr 08, 2014 1:33 pm Post subject: |
After a few more hours... I still only have a few more hours of work on the heads. To all you guys/gals who have never done your own head work and have snickered at the high prices of this type of craftsmanship, I urge you to try it yourself, then reconsider the prices $$$$ presented to us by the shops. At this point I have about 22 hours into my cylinder heads. |
Posted: Tue Apr 08, 2014 2:10 pm Post subject: |
yeah but your time is free right? LOL
High end cylinder heads have never been less expensive than right now. I remember paying $1500/pr in 1984 for a good set. That was a LOT of scratch back then..... _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed Apr 09, 2014 8:48 am Post subject: |
22 hours?? thats not that much. but .....your work looks great.I think if the rest of the motor is up to this attn you will be happy with the outcome.(I would ceramic the chambers&exhaust ports&piston tops before finall assembly to keep the heat where it should be and going out the exhaust) |
mhisel Samba Member
Posted: Sat Apr 19, 2014 7:17 pm Post subject: |
Well, my heads are back from getting a valve job. And now I need to CC them. Hopefully they are close in CC's. I need to do some final touches b/c they do not quite meet the status quo. since I sent them off. the heads have a minimum 25 hours and still not finished. More polishing to come. |
mhisel Samba Member
Posted: Wed Apr 23, 2014 8:35 pm Post subject: |
I CC'ed the the chambers they came out pretty close. the smallest is 55cc and the largest is 56.5 |
Posted: Wed Apr 23, 2014 9:37 pm Post subject: |
polish from the sparking bolt to the header.60 grit from the sparking bolt to the carbs.and be sure to knock off any sharp edge between the seats& also the sparking bolt threads edges.and get your darn camera back out!! I seem to remember my 044's were 62cc for 9.5 cr on my 2332.(it will be uped a good bit if I ever getaround to finishing the roller cam mods&returning back to service. too much other stuff in the way) |
mhisel Samba Member
Posted: Thu Apr 24, 2014 10:20 pm Post subject: |
Posted: Fri Apr 25, 2014 7:39 am Post subject: |
wow after all that nice work the chambers are cracked all to hell!! just be sure you dont use toomuch greezzee & keep the plate up witch adds some cc.I use a thin line around the edge applied with a syringe. hmm I was thinken....I should send you my superflows& have you open them up a bit..... |
AlteWagen Troll
mhisel Samba Member
Posted: Fri Apr 25, 2014 12:49 pm Post subject: |
The cracked looked is the vaseline. I used vaseline to seal the chamber when I measured it.
Not sure about the ports. I tried to do the best i could
I still have a lot of work to do to them. I am going to measure and measure and measure then maybe measure one more time. For example, I am going to measure the chambers again just to make sure. I am learning tons |
mhisel Samba Member
Posted: Tue Apr 29, 2014 12:51 pm Post subject: |
Some updated/cleaned up pictures, but still not the final product.
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue Apr 29, 2014 12:58 pm Post subject: |
Now break the polish with a 180 cartridge roll for proper texture. |
