obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
Posted: Tue Oct 08, 2002 6:36 pm Post subject: Sunroof installation |
how hard is this do? i need to put a new cover on my 21 window bus. i have the pages that show it kind of taken apart but what do you guys suggest? not many old school vw upholstery shops here in NJ. or can any upholstery shop do it? i have the cover already. Aslo, is this a good time to do the headliner as well or can i wait til i get some $cratch?
Updated tutorial later in this thread |
Joined: August 01, 2002 Posts: 67 Location: Anglesey Wales UK
Posted: Wed Oct 09, 2002 4:06 pm Post subject: sunroof installation |
Check out some of the pages at vintagebus.com they have some copies of original instructions for removing & refitting a sunroof. pics are not too bad. Go www.vintagebus.com/howto/sunroof.htmlo |
highdesertdeluxe Samba Member
Joined: July 14, 2002 Posts: 103 Location: L.A. @ 2665'above sea level
Posted: Wed Oct 09, 2002 7:24 pm Post subject: sunroof installation |
i put on my cover, not hard. measure twice...
pop riveted the front mechanism last, don't do this. do it first & tension to the rear retainer. save your cash & find the og slider blocks. the new plastic crap broke on mine after 2-3 openings. a pro shop is recommended for the headliner. too many potential problems for the novice to make. it is expensive ($800 labor) but you'll appreciate the quality work later! good luck! |
obus Samba Member
Posted: Wed Oct 09, 2002 7:42 pm Post subject: sunroof installation |
are the slider blocks the same for beetle and bus or strictly bus? i have never seen these at shows. i guess i would have to buy a whole clip? Ugh!! and 800 bucks for the headliner labor?? |
CheapBusForSale Samba Member
Posted: Tue Sep 29, 2009 2:58 pm Post subject: How-to? |
I am thinking about doing the same thing. All my blocks are in pretty good shape and the thing slides pretty well. but the problem I'm having is that when I got my bus the top was completely gone, with only little bits of the original top left which makes it just about impossible for me to figure out how the top should installed. And I can see that the rear part of the fabric goes under the screwed down metal band and that the front goes under the rivets (which I'm guessing that I will need to pop the rivets and install new ones) but what I'm really confused about is how the canvas is supposed to fit on the sliders? Does anyone know of a how-to manual that might explain it all in detail? _________________ Looking for Groovy Bumper Stickers? Check out my Ads! |
Kelly Samba Member
Joined: November 25, 2003 Posts: 2437 Location: Olympia, WA
Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Wed Sep 30, 2009 7:09 am Post subject: |
There are a couple of threads in the Split Bus FAQ that may help. Look under "Interior/Seats/Seal". If you don't see what you need I would post in one of those threads with what you need. |
Stanw3 Samba Member
Posted: Wed Sep 30, 2009 8:26 am Post subject: Re: How-to? |
CheapBusForSale wrote: |
but what I'm really confused about is how the canvas is supposed to fit on the sliders? Does anyone know of a how-to manual that might explain it all in detail? |
The canvas is screwed to the ends of the bows with finish washers. Be certain the bows are all in their correct place BEFORE you poke holes in the canvas and attch it with the screws. The rear part of the bow (round tube that flattens at the ends needs) to be fitted into the pockets on each side. You will need to make a small slit in the canvas for this piece to slide into. This helps hold the canvas in place when sliding the top back.
Canvas attached at rear tack strip:
3 finish washers/screws:
Slit marked in canvas pocket:
Bow inserted in pocket slit: (Looking from side, canvas edge lifted up)
_________________ Sanborn7
www.facebook.com/Sanborn7
Stanw3 Samba Member
Posted: Wed Sep 30, 2009 8:34 am Post subject: |
Finish washers: Underside is rolled so it won't cut into the canvas -
Attached to bow:
www.facebook.com/Sanborn7 |
Kelly Samba Member
Posted: Wed Sep 30, 2009 9:27 am Post subject: Re: How-to? |
Stanw3 wrote: |
You will need to make a small slit in the canvas for this piece to slide into. This helps hold the canvas in place when sliding the top back. |
interesting..I didn't do that to mine. It slides open and closed fine but I wonder how much of a difference the slits would make? Where's my razor blade _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Stanw3 Samba Member
Posted: Wed Sep 30, 2009 9:30 am Post subject: |
I'm not sure it makes a huge difference - but it's how I was taught to do it. _________________ Sanborn7
Stanw3 Samba Member
Posted: Wed Sep 30, 2009 9:49 am Post subject: |
Ev - Here is the headliner screw and finish washer pic you asked about. Note the smooth, tapered end.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Wed Sep 30, 2009 5:15 pm Post subject: |
Stanw3 wrote: |
Attached to bow:
And the little imbedded strap goes under the end not sandwiched under the canvas side with the screw and washer. |
Stanw3 Samba Member
Posted: Wed Sep 30, 2009 5:30 pm Post subject: |
Barry -
Are you saying that the strap that is sewn into the pocket does not have the screw through it? I ran the screw through it: both sides of the canvas pocket and the inner webbing on mine. I was told this helps insure the pull stress is is on the web and not the canvas itself???
Edit: I did also uses slightly longer than original stainless screws here. Originals weren't long enough once I added the flat metal piece fills the gap on the aluminum part of the bows. I assumed the webbing and new stay fast canvas were causing the shortage. _________________ Sanborn7
Stanw3 Samba Member
Posted: Fri Oct 02, 2009 5:35 pm Post subject: |
OK - Time to eat some crow. My buddy Jorge looked at Henry's 56 today and whoever built it did things as Barry is saying. The end of the bow where the finish screw attaches does in fact go inside of the pocket. The enclosed webbing and the bottom of the canvas pocket are under the bow with no screw in them.
Hope it helps someone else in the future. I'll be outside changing mine now.
Edit: Just did the passenger side. It does look better as the canvas now down closer to the body of the bus. I'll take some pics tomorrow when I do the driver side. _________________ Sanborn7
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Fri Oct 02, 2009 6:27 pm Post subject: |
Could someone post a photo of this please. _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
Stanw3 Samba Member
Posted: Mon Oct 05, 2009 6:28 pm Post subject: |
Thanks to BarryL for sending me digging. It seals much better now!
Here we go. First pic is the gap between body and canvas with the canvas simply screwed to the top of the bow.
The canvas is of course 2 layers thick on th sides where it is folded and sewn. This creates the "pocket" that the webbing running through. Here is the canvas unscrewed and lifted up. You can see the hole where I had the screw through it and the indentation that the bow has already made.
I cut a slit the width of the bow in the lower side of the canvas - being careful NOT to go through the other (top) layer of canvas. I cut it just to the outside edge of the inner pocket stitch. I didn't want to cut that stitch and have the whole canvas come apart. I also only cut it just wide enough for the bow to fit in.
I slid the flat metal cover piece in first. I made sure the webbing went under the metal plate as I slid it in.
Next put the other end of the metal cover plate into the bow. Now just pull the cover over and slip it over the bow so that the bow goes into the slit you cut. It take a little pulling to get it over and to get the bow in the slit. Here is the gap after making this change: Mucho better!!
So the order of the materials as you dig down is:
Screw
Finish Washer
Top layer of canvas
Metal Cover plate
Ragtop bow
Inner Webbing
Lower layer of canvas
Hope this helps someone else down the road! _________________ Sanborn7
Kelly Samba Member
Posted: Mon Oct 05, 2009 9:09 pm Post subject: |
wow, I'm trying this tomorrow
I'll post how it goes, but hopefully it looks as good as yours! _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Kelly Samba Member
Posted: Wed Oct 07, 2009 6:36 am Post subject: |
just so I got this right, the plate and the bow go "in" the canvas? So there's no exposed metal at all, right? _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
