Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Dec 21, 2014 5:43 pm Post subject: |
Snug fit and does not rotate...
kdcaul Samba Member
Posted: Sun Dec 21, 2014 7:50 pm Post subject: |
Hi Dale,
are bearing races also snug and fit?
Thanks for the reply,
Kevin |
Posted: Mon Dec 22, 2014 8:28 am Post subject: |
kdcaul wrote: |
Hi Dale,
Kevin |
Kinda sorta.... Not interference but snug... Precision slip fit... Some time you have to polish spindles if there is a burr or rust on them but they should not be "loose"...
If they are real sloppy you may have wrong bearings... Believe later BJ bearing (inside) has larger inside diameter for larger spindle...
kdcaul Samba Member
Posted: Mon Dec 22, 2014 9:35 am Post subject: |
Once again Thanks,helpful info |
prkid424 Samba Member
Joined: April 21, 2015 Posts: 171 Location: Wodbridge, VA
Posted: Mon Sep 21, 2015 6:28 pm Post subject: Re: Front Wheel Bearing Spacers |
nick.falconer wrote: |
Hi,
I am rebuilding my front wheel bearings and brakes and have some questions about the spacers behind the bearings. Both sides seem different.
Left Side:
I know this is an old thread but what is the suggested method to get those spacers out....I am rebuilding my from brakes (see this thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=636943 ) and I cannot get these off. I tried a puller but I cant get the "hooks" around since its so close to the backing plate. I tried chiseling it out but they are not budging. I just sprayed a liberal amount of PB Blaster and I was going to try again tomorrow.
Also can the backing plate come off with out removing the spacer? Really i just want to remove the backing plate to clean up and paint before the new brake hardware goes on. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Sep 21, 2015 10:25 pm Post subject: |
You might try breaking it loose with a pipe wrench. I don't imagine that will bugger it up any worse than the chisel already did. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Tue Sep 22, 2015 6:32 am Post subject: |
SBD wrote: |
You might try breaking it loose with a pipe wrench. I don't imagine that will bugger it up any worse than the chisel already did. |
should I just purchase new spacers? I am sure these may get pretty beat up. do those need to be as smooth as the bearing racers? Do I need to worry about damage to the spindles?
In reality all I wanted to do is remove the backing plate- does that spacer need to be removed to take the backing plate off? |
Posted: Tue Sep 22, 2015 6:52 am Post subject: |
I might be mistaken, but doesn't hub seals run on spacers...
Posted: Tue Sep 22, 2015 9:36 am Post subject: |
SBD wrote: |
LOL- yup that did it. Just need it to break loose then I was able to pry it out...and yes it did bugger it up quite a bit. Oh well - one more thing to order, fortunately its pretty cheap.
BTW it looks like the backing plate would have come off w/o having to remove that spacer. Live and learn.
Dale M. wrote: |
Dale |
they do.... |
eschmi Samba Member
Posted: Fri Jan 08, 2016 3:16 am Post subject: Re: Front Wheel Bearing Spacers |
Sorry if this is an old thread and don't mean to thread jack... but what's the part that sits on the spacer? I appear to have misplaced it though I don't even remember taking it off... but putting everything back together now I noticed one is missing a part... have looked through my books and online and can't find a name for it. Have found pictures and stuff with it on it but no actual name for it so I can find a replacement. any ideas?
EVfun Samba Member
Posted: Fri Jan 08, 2016 6:14 am Post subject: Re: Front Wheel Bearing Spacers |
In the top picture the inner race in the inboard wheel bearing is still in place. It appears to be an original style ball bearing race. The seal race is inboard on that on both spindles. In the top picture the seal race looks rusty and likely to leak. The amount of rust on that spindle would concern me as well. In the bottom picture the seal race looks like it has been damaged trying to chisel the wheel bearing race away from it so it can be pulled. It could damage the seal when the drum is installed unless the outboard edge is carefully deburred. _________________
Wildthings wrote: |
eschmi Samba Member
Posted: Fri Jan 08, 2016 6:38 am Post subject: Re: Front Wheel Bearing Spacers |
ah, so are the parts replaceable or should I just get 2 new complete spindles? I had heard of carefully using a file for the rust but not sure, and didn't even notice the other one had been damaged. |
Posted: Fri Jan 08, 2016 8:50 am Post subject: Re: Front Wheel Bearing Spacers |
eschmi wrote: |
No need for new spindles ... The seal race or spacer what ever you wish to call it is replaceable .... IF actual seal surface is not damaged or rusted, you can carefully dress (file) any damages smooth and just go with it.... If it were me, I would just replace both spacers...
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26-405-017
eschmi Samba Member
Posted: Fri Jan 08, 2016 1:21 pm Post subject: Re: Front Wheel Bearing Spacers |
awesome thanks Dale! but whats smooth machined thing on the one spacer that I'm missing on the other? |
Posted: Fri Jan 08, 2016 3:06 pm Post subject: Re: Front Wheel Bearing Spacers |
eschmi wrote: |
As mentioned before it appears to be inner race of from wheel (ball) bearing....
eschmi Samba Member
Posted: Fri Jan 08, 2016 6:09 pm Post subject: Re: Front Wheel Bearing Spacers |
ah sorry I missed that... so I have all new bearings basically it's the part that comes in the center of them? Sorry I'm not entirely familiar with all the parts and pieces yet. |
Posted: Fri Jan 08, 2016 8:43 pm Post subject: Re: Front Wheel Bearing Spacers |
eschmi wrote: |
Ball bearings consists if inner bearing race and set of caged ball bearings and a outer race.... As three parts...
A roller bearing set is almost same thing, a inner race and a caged roller bearings assembled as a unit (does not come apart), and separate outer race....
See a difference...
eschmi Samba Member
Posted: Sat Jan 09, 2016 12:36 am Post subject: Re: Front Wheel Bearing Spacers |
oh I gotcha, awesome thanks Dale!! |
