Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5409 Location: Holland, MI
Brian Samba Moderator
Posted: Wed Sep 17, 2014 8:57 pm Post subject: |
Or, how about something like this? I could make some 80deg elbows with flanges on each side and have the collector on top of the engine angled up slightly. Could attach a stinger to the end of the collectors three bolt flange.
Ok, so I got a rough distance the manifolds protrude beyond the bell housing mount on the engine. Aproximately six and a half inches. I wish I had the transmission up here so that I could see if I am in any danger if having interference issues with the half-shafts. If anybody wants to give me a rough distance from the bell housing to the drive flanges, that would be awesome. Doesn't have to be super accurate, just something to give me an idea of how much space I have to work with. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Wed Sep 17, 2014 9:17 pm Post subject: |
Cut holes in your frame, use it as the exhaust manifold itself? What could go wrong with that?
Or just go straight pipe
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Thu Sep 18, 2014 10:46 am Post subject: |
Brian, I saw the rebuild thread for that rig online a couple years ago. Some guy restored his grandfathers buggy. Pretty cool rig really. As for the straight pipes, mmm, no. I'm thinking a stinger pointing straight out the back with a fiberglass baffle installed and a 3x5 spark restorer on the end.
So, since I don't have my transmission on me at the moment, I asked a buddy to get a rough measure of the distance from the face of the bell housing to the cv joint flange. Worked out to be approximately 6 1/4 inches. Now, that is also about how far the manifolds hang out past the bell housing mount on the engine, which doesn't leave me with a whole lot of room to work with. I can shorten the manifolds by about 2 inches which will help a lot. Exhaust tubing donuts are available in 1 5/8 inch tubing with a radius of 1 5/8 of an inch measured from the center of the tubing. One donut and a section of straight tubing a few feet long is enough to cut four bends out of and create the piece I need between the manifold and the header. This would be cutting it close if the manifolds were up against the cv joints, so this should be able to clear the axles since the manifolds are outboard of the cv joints.
Looks like the only thing to worry about is making the adapter pieces tall enough to clear the cross brace between the frame horn braces. Shouldn't be to hard.
What do you guys think? _________________ 1800 Type 4 Berrien 295
dustymojave Samba Member
Posted: Sat Sep 20, 2014 9:01 pm Post subject: |
Boys....
It appears there is some mis-understanding here...
The header collector is supposed to be behind the engine...toward the rear bumper. NOT wrapped around the bellhousing! The header MAY have been designed to fit an engine with the aftermarket Porsche upright fan housing. If this is the case (as with my T4), you can add about 5" of tube just behind the flanges. _________________ Richard
SoCalBajas Member
Posted: Sat Sep 20, 2014 10:57 pm Post subject: |
Just because it is "supposed to be" doesn't mean it has to be.
Exiting out the back, as it was designed, it would be outside of my rear cage. I would rather not have a header for my bumper.
And what is this about not having the exhaust around the bell housing? Hey, it works for European Motorworks.
Last edited by Vanapplebomb on Sat Sep 20, 2014 11:16 pm; edited 1 time in total |
Posted: Sat Sep 20, 2014 11:15 pm Post subject: |
Vanapplebomb wrote: |
Come on Dusty, of all people I know you should know how to break the rules to make stuff work _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sat Sep 20, 2014 11:18 pm Post subject: |
Brian wrote: |
Come on Dusty, of all people I know you should know how to break the rules to make stuff work |
Yeah!
Hahaha, Sorry Richard, just giving you a hard time _________________ 1800 Type 4 Berrien 295
Posted: Sat Sep 20, 2014 11:28 pm Post subject: |
Off road cars are meant to break the conventional rules. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Sun Sep 21, 2014 8:29 pm Post subject: |
I have been having trouble uploading pictures to the gallery for the past couple days. I have more to share, just can't seem to get it to work. It keeps crashing every time I try to upload. Once I get it working I will give you guys shot or two of some pretty substantial previous owner syndrome. _________________ 1800 Type 4 Berrien 295
Posted: Mon Sep 22, 2014 3:18 pm Post subject: |
I was considering the potential to build a header like the European Motorworks one.
But I consider it more work for less result.
You have to clear not only the bellhousing, carbs, fan and cylinder shrouding, but axles and frame yoke supports and crossmembers too. The existing header you have is fine, but those stock manifolds it connects to are awfully long. And do you plan to race this car in the sand dune derby? Or is there so much traffic out there on the forest trails to deal with that you're really concerned about someone rear-ending your buggy and smashing your headers?
Brian wrote: |
I've spent a lifetime catching those who try to break the rules to make things work in ways other than the "approved" method.
But at the same time...I'm very much a "Path Less Traveled" person. You'll only hear me say "Baaa...Baaahhh" if I'm trying to communicate with people I perceive are inclined to follow the leader. _________________ Richard
SoCalBajas Member
Posted: Mon Sep 22, 2014 4:39 pm Post subject: |
This is going to be a woods buggy. If the exhaust came out the back it would be limiting aproach and departure angles as well as be the first thing to get bashed up in the back. Getting bashed up would most likely take out the cylinder heads. Not cool.
As I mentioned, this set up will clear the bell housing, carbs, and air filter. I just have to make a few tweaks to make sure it clears the axles and cross brace. Those are the only two things I really have to worry about. It can be worked around. _________________ 1800 Type 4 Berrien 295
Posted: Tue Sep 23, 2014 2:10 pm Post subject: |
As it is to be a woods buggy, I suggest you use a muffler rather than a stinger. A Thrush Turbo would work great and be very low cost compared to other options. It would need some support from the top of the case, but that's EZ.
On the subject of rear clearance angle, I suggest that you angle your lower bumper cage tubes up at the back edge of the engine, then up again to meet the rear crossbar. Most bumper cages on play cars are designed with a right angle bend at the back edge of the bumper cage. This drags badly. _________________ Richard
SoCalBajas Member
winchin73blazinbaja Samba Member
Posted: Tue Sep 23, 2014 3:26 pm Post subject: |
i just about busted out laughing in class. |
Posted: Tue Sep 23, 2014 4:00 pm Post subject: |
City Boys!!!!
SoCalBajas Member
Posted: Wed Sep 24, 2014 7:45 pm Post subject: |
dustymojave wrote: |
As it is to be a woods buggy, I suggest you use a muffler rather than a stinger. A Thrush Turbo would work great and be very low cost compared to other options. It would need some support from the top of the case, but that's EZ. |
Funny you should say that, because I happen to have a Turbo muffler by CherryBomb sitting in the basement. Basically the same as the Thrush turbo. _________________ 1800 Type 4 Berrien 295
