exciter Samba Member
Posted: Mon Jan 16, 2012 7:04 pm Post subject: |
Patrick,
I had a package show up today for you!!! A killer sidewinder exhaust for a type four bus!!!!!!
[img]
[/img] _________________ Joe
419-236-9781 |
Iozzio Samba Member
Joined: March 10, 2005 Posts: 354 Location: Molalla Oregon
Posted: Fri Jan 20, 2012 4:51 pm Post subject: |
Patricks wheel machined.
_________________ Paul Iozzio
www.iozziowheels.com |
Tuned Perfection Samba Member
Joined: December 10, 2003 Posts: 263 Location: Port Colborne, ON, Canada
Posted: Fri Jan 20, 2012 6:40 pm Post subject: |
Oh hell ya!!!!
Rancho axle to axle trans shipped out today from Cali and should be at VMW for our visit next weekend. _________________ www.tunedperfection.com |
Jerry Samba Member
Posted: Fri Jan 20, 2012 7:10 pm Post subject: |
I'm glad this one's in your garage, I don't know of many teams that could tackle this one & get it right.
Keep the pics coming, I'm learning... _________________ Looking for SO34 parts.
thevwcompound *instagram* |
Posted: Fri Jan 20, 2012 9:22 pm Post subject: |
Jerry, yes these old crusty buses can be challenging but we just keep cracking away at them!!!
And Paul, thanks for the in progress pic of one of Patricks rims!!
Greg the tranny will be arriving in perfect time and so will Patricks custom built rims!!!!! Paul called me today to let me know they left today! so I will get Patrick's tires mounted up next week so we can do a mock up next weekend!!! We should see start seeing a lot more progress on this jewl starting tomorrow !! _________________ Joe
419-236-9781 |
Maxim Samba Member
petevdub Samba Member
Joined: January 01, 2005 Posts: 205 Location: Toronto, Canada
Posted: Sat Jan 21, 2012 10:24 am Post subject: |
Spoke with Lanner(vdubengineering) a couple days ago, and he was working on Patrick's beam and spindles. _________________ '72 super
'65 21w
'52 split 11C |
Posted: Sat Jan 21, 2012 5:07 pm Post subject: |
Sounds great Pete!!! Patrcik ut sounds like we will have the entire drivetrain and suspension and Wheels here by the time you get down here next weekend!!!!!
Also the cost of the wiring harnes for Patricks bus is right around $ 252 from Wiring Works. We use them for all our restorations and they are very nice and have been real accurate.
Robb got your rear corner cut off from where it was brazed and pop rivited in place years ago! And got it all cleaned up and ready to weld back into place. I finished seting yor right front door gaps and got the A pillar welded in solid then removed the old left side A pillar and welded the new gersone one together and got it tacked into place.
Just about ready to weld in the front inner valance and then the outer lower nose skin!!!!! And then the front floor!!!!!
419-236-9781 |
Iozzio Samba Member
Posted: Sat Jan 21, 2012 10:55 pm Post subject: |
lookin' killer guys! _________________ Paul Iozzio
Posted: Sun Jan 22, 2012 8:05 pm Post subject: |
Thanks Paul, This build will be getting some attention and making good progress here!!!!!
Patrick , Robb spent the day on your rear end again!!!!!
He got the rear frame all straightend out where it had been slammed years ago and never repaired properly. He then got your right side structure realigned and tacked into place and fitted like its supposed to. Your rear frame and structure is now nice and straight and just about ready for some sheet metal to be reinstalled!!!
419-236-9781 |
Posted: Mon Jan 23, 2012 4:40 pm Post subject: |
Patrick,
I got a good half day in on your bus today! I got your right side dog leg together and tacked in place and then prepped the front frame and rear and got your lower inner valance welded in to place and then finished cleaning up the front floor area then shot everything with a good coat of weld thru primer then prepped your front floor and got it all plug welded into place!!!! Shes looking good and solid in the front area now!!!!!
[img]
419-236-9781 |
Posted: Mon Jan 23, 2012 6:05 pm Post subject: |
Lookin' killer Joe and Robb. I bet Patrick can't wait for this weekend to roll around. _________________ www.tunedperfection.com |
tlambert Samba Member
Posted: Mon Jan 23, 2012 9:55 pm Post subject: |
You and Robb are kickin its ass fosho! |
Posted: Sat Jan 28, 2012 12:15 am Post subject: |
Well Patrick came down for the weekend to check on his bus and to help make some progress!!! Also his custom wheels by Iozzio showed up today as well. I really dont know how to describe them other than WOW They are 17" custom made to his specs and are truley a work of Art! Thank You Paul Iozzio for making such a killer set of wheels!!! Anyone interested in a custom set of 17" wheels get ahold of Paul and I'm sure he would be glad to hook you up! www.Iozziowheels.com.
Patrick spent the evening sandblasting and cleaning up his window frames and dissasembled his speedo to restore it . I worked on getting his lower outer valance whelded inplace then got his lower nose skin tacked into place also!!!! Good evening for only a couple of hours work. We will get up in the morning and hit it hard then as well.
[img]
[/img]<a href="http://s439.photobucket.com/albums/qq118/exciter2008/Patricks%201967%2021%20window/?action=view&current=patrickslowernoseskinweldedon1-27-12027.jpg" target="_blank"><img src="http://i439.photobucket.com/albums/qq118/exciter2008/Patricks%201967%2021%20window/patrickslowernoseskinweldedon1-27-12027.jpg" border="0" alt="Photobucket"></a>
419-236-9781 |
Iozzio Samba Member
Posted: Sat Jan 28, 2012 10:51 am Post subject: |
Lookin good. Its really coming along. Glad you like the wheels. _________________ Paul Iozzio
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sat Jan 28, 2012 11:30 am Post subject: |
exciter wrote: |
[img]
How did the KF lower nose panel fit? The 'V' looks a little off to me in the photos? I have heard others say that it's not the correct width....Great progress by the way.... |
55VW Samba Member
Posted: Sun Jan 29, 2012 8:46 am Post subject: |
Joe, where are you oocated. I gotta come see the shop and projects. Email me at [email protected] |
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Sun Jan 29, 2012 8:59 am Post subject: |
You guys are killing it. That's going to be one solid bus when your done. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Sun Jan 29, 2012 10:27 am Post subject: |
Thanks for the props guys we really apreciate it and it helps us keep motivated on our projects,
Buseric, Yes the V stamping is a little off on these sections but definetly not enough to gripe to much! And yes you cn see in the pics and thats why I havnt welded it up fully yet, I will go back and do a little slicing and dicing to align it up and she'll be perfect!
Matt, We are located at 19240 Townline Road, Wapakoneta, Ohio 45895
It is right off of Intersate 75 about 1 hour north of Dayton Ohio, Give me a call sometime 419-236-9781 we would love to have you stop by.
We had another good day yesterday on Patrick bus.He got his old beam all tore down and the trailing arms cleaned up blasted and painted and misc little peices to go on his new beam. He also got his front seats all stripped and ready for blasting and paint. His headlights dissasembled and parts blasted and lots of other little misc things wrapped up. I got both cargo door bottoms repaired and then rebuilt/repaired the lower hing and corner of his drivers door. Joel then stripped the paint off bith of the cargo doors and got them ready for final sandblasting. I also repaired one of his floor crossmembers, and other misc weldig needed. Overall a great weekend and it was a pleasure to have you down for the weekend to help out Patrick! (by the way thanks for the Pizza & Beers)
[img]
419-236-9781 |
Iozzio Samba Member
Posted: Sun Jan 29, 2012 11:07 am Post subject: |
This bus is gonna be so nice, I'm jealous! Great job. _________________ Paul Iozzio
