Generator and oil idiot light question
KzooThing
KzooThing is offline
PostPosted: Mon Mar 19, 2012 3:44 am    Post subject: Generator and oil idiot light question Reply with quote
My generator and oil idiot lights are coming on when I remove the key, and turn off when I have the key in first position. I am having to leave the keys in the car to not run out my battery. Any ideas as to why this is happening?
Thanks!
uberautowerks
uberautowerks is offline
PostPosted: Mon Mar 19, 2012 8:27 am    Post subject: Reply with quote
I would guess your ignition switch is bad.
Instead of leaving the key in you could simply unplug the wire harness from the back of the switch.
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
Captain Spalding
Captain Spalding is offline
PostPosted: Mon Mar 19, 2012 6:40 pm    Post subject: Reply with quote
That was my first thought too.
KzooThing
PostPosted: Mon Mar 19, 2012 8:50 pm    Post subject: Reply with quote
Thanks for the input - I bought a new ignition switch today and will install this weekend. Will follow up with the results.
memphisthing73
memphisthing73 is offline
PostPosted: Tue Mar 20, 2012 12:48 pm    Post subject: Reply with quote
Autozone gave me the wrong switch so make sure yours is correct. And don't lose the "TINY" screw that holds the switch in place....
'72 Beetle
'73 Thing
nikita
nikita is offline
PostPosted: Tue Mar 20, 2012 8:18 pm    Post subject: Reply with quote
73 and 74 are different. For me, its easy because there are many VW parts vendors nearby. My switch failed and SoCal Imports is in the same city where I work. '74 was only $9 for a made in Brazil one.
memphisthing73
PostPosted: Wed Mar 21, 2012 5:14 pm    Post subject: Reply with quote
I have Roy Rogers here in Memphis so I can get the correct parts when needed...
'72 Beetle
'73 Thing
KzooThing
PostPosted: Sun Jul 15, 2012 12:21 pm    Post subject: Reply with quote
Okay - I finally got to trying to repair this issue - moved in March and have been neglecting the Thing ever since - and I have eliminated the ignition switch as the cause. I unplugged the wire harness and the lights remained on. The only way to get them to turn off is to unhook the battery.
Also, I took it for a drive last night and noticed that the generator light is dim and lights up as I accelerate.
Could this be caused by a bad generator? Anyone have any more ideas before I take it to the shop?
Thanks!
Ferretkona
Ferretkona is offline
PostPosted: Sun Jul 15, 2012 3:27 pm    Post subject: Reply with quote
I found 95% of electrical problems in VW's are the grounds.
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
Wildthings
Wildthings is offline
PostPosted: Mon Jul 16, 2012 3:52 am    Post subject: Reply with quote
2x
Make sure you have a good ground connection to your gauge cluster.
