zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun Nov 13, 2011 2:48 pm Post subject: |
aircooled wrote: |
Coker white wall radials.
Very, very nice. Classy. |
bruce jones Samba Member
Joined: July 17, 2003 Posts: 324 Location: South Carolina
aircooled wrote: |
Coker white wall radials. |
Same here.
_________________ Driving in the slow lane since 1969. |
aircooled Samba Member
Joined: December 02, 2003 Posts: 1290 Location: Heartland, Neb
Posted: Sun Nov 13, 2011 2:49 pm Post subject: |
Coker bias-ply white walls makes driving a little more interesting at times.
_________________ 67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska |
Posted: Sun Nov 13, 2011 2:55 pm Post subject: |
bruce jones wrote: |
aircooled wrote: |
Same here.
Your Yukon Yellow convertible looks great!! Is it a 68?
Member of 67 Posse
Posted: Sun Nov 13, 2011 3:00 pm Post subject: |
aircooled wrote: |
Your Yukon Yellow convertible looks great!! Is it a 68? |
1969. _________________ Driving in the slow lane since 1969. |
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Sun Nov 13, 2011 4:36 pm Post subject: |
hitest wrote: |
I've run both- and I'm amazed how fast the Port-a-walls seperate and look like crap on a radial tire. As an issue of safety- they compromise the tire bead-to-rim bond. They are probably fine for cruising- but I'd never cook down the freeway with a layer of rubber keeping my radial tire from completely sealing the rim again. Also, if you have a tire run low quickly (like happens when you're at work)- you'll wear the portawall before the tire's sidewall. Then, when you air up- you get to look at your damage henceforth.
Get Firestone 2-3/4" Ww from Coker or Lucas- mine have be great for far longer than they should. |
This is a fact! My tire guys were pretty good and had problems getting the inserts to seat properly. Also, since most guys that use porta walls (yes, Ive been one of them) are being CHEAP, the money does add up! I installed a pair, only to find that they distorted and started ripping one month after I bought them. Had to either buy a new set, or get rid of them. I bought some different wheels instead. If you are planning on running low but also want whitewalls, be prepared to pay for the custom tires...or just raise the car and get a common size. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Nov 13, 2011 4:50 pm Post subject: |
Universal tire also sells the white walls - if you are going stock sizes, just bite the bullet and do real whitewalls IF you are actually going to drive the car - it doesnt really matter for a trailer queen.
Not getting into the debate and "I heard this and that". This is what I know - I am running Atlas porta walls temporarily on my VW woodie's stock sized radials until I nail down the tire/wheel combo and have had to replace the rear set already after 1500 miles. They were installed carefully, everything was clean - I reseated them after a couple hundred miles, and all that. What I have found is the you really need to run higher pressures to reduce the sidewall flex and they will be pretty happy. I am currently running 22/32 and I would expect them to last for quite a while with this pressure.
But over the winter I expect to nail down what I am going to stay with and will bite the bullet and get actual white walls. _________________ D-Dubya Manx clone - 63 Short pan,1914.
kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Wed Oct 22, 2014 10:28 am Post subject: |
Coker 530300 tires, actually rated for vanagon specs
Original Rims, powder coated Bengel Red
Spend the extra money, do it right |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Wed Oct 22, 2014 10:34 am Post subject: |
Firestone wide white bias ply- Go big or go home
_________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
HausBldrNC Samba Member
Posted: Tue Dec 02, 2014 2:24 pm Post subject: Tires wide whites |
6T5 square wrote: |
What size were your tires and roughly how much. |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Wed Dec 03, 2014 12:51 am Post subject: |
Coker wide whites...
_________________ Plate of shrimp |
v_dub_ya Samba Member
Joined: April 07, 2003 Posts: 85 Location: North Carolina
Posted: Wed Dec 03, 2014 8:40 am Post subject: |
panicman wrote: |
What size are those white walls and are they radials?
That's the exact look I'd like to have.
Thanks _________________ 1964 Beetle Deluxe |
Posted: Wed Dec 03, 2014 8:57 am Post subject: |
They are 2.25" white walls. They are radials, 165 R15. The car is stock height. I bought them from Coker and picked them up a few months later at the Portland Swap Meet to save shipping, but apparently you can find them at other online vendors who don't charge for shipping. I have been very happy with the tires. I would add that I had mine installed with Dyna Beads, not lead balancing weights, and the ride is great! _________________ Plate of shrimp |
Posted: Wed Dec 03, 2014 9:48 am Post subject: |
panicman wrote: |
They are 2.25" white walls. They are radials, 165 R15. The car is stock height. I bought them from Coker and picked them up a few months later at the Portland Swap Meet to save shipping, but apparently you can find them at other online vendors who don't charge for shipping. I have been very happy with the tires. I would add that I had mine installed with Dyna Beads, not lead balancing weights, and the ride is great! |
I had my new Coker tires balanced with weights on the inside only and it's not working very well. I get a noticeable vibration above 58 MPH. I've heard about the Dyna Beads but I've never been brave enough to try them. I always thought they were just another gimmick. _________________ Pearl White 1966 Sedan
Retired US Army - 21 years 11B40, 173rd Airborne Brig. - Vietnam Combat Veteran |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Wed Dec 03, 2014 10:00 am Post subject: |
aircooled wrote: |
I personally don't like WW on VW's, but look great on a Cadillac. But if you intend to install them they look so much better when they are period correct like this 67 vert. Using a wider 50's style not only didn't happen when the 67 was new....because they didn't make them anymore because the style changed, but changes the era of a car that does not belong there, it's like trying to adapt towel rack bumpers from a early bus to a bay window bus. |
Posted: Wed Dec 03, 2014 10:11 am Post subject: |
Helfen wrote: |
Didn't the first year for the narrower WW tires start with the 1966 model Beetle? _________________ Pearl White 1966 Sedan
Helfen Samba Member
Posted: Wed Dec 03, 2014 10:43 am Post subject: |
shortride wrote: |
Helfen wrote: |
Didn't the first year for the narrower WW tires start with the 1966 model Beetle? |
On domestic cars, the first downsizing came in 1959, then again in 1961, then again in 1963, by 63 they were only 1/2" WW, by 68-69 they were just a sliver about 1/8". By the time I bought my 76 Olds they were 1/2" on smaller Olds and a 3/4" on Cadillac. But as far as VW goes we need to go to the archives to see how VW's came.
A 1956 from R&T magazine;
http://www.thesamba.com/vw/archives/lit/56road_track/3.jpg
A 1960 --they are getting narrower;
http://www.thesamba.com/vw/archives/lit/60roadandtrack/2.jpg
A 1962, even narrower;
http://www.thesamba.com/vw/archives/lit/62ads_fulline/2.jpg
A 1965, about the same as 62;
http://www.thesamba.com/vw/archives/lit/65whatsbehind/1.jpg
A 1966 a little wider;
http://www.thesamba.com/vw/archives/lit/66cut-outs/page4.jpg
A 1967 narrow again note the picture is a European 6 volt deluxe;
http://www.thesamba.com/vw/archives/lit/67beetle/45.jpg
a 1971 Super Beetle;
http://www.thesamba.com/vw/archives/lit/71superbeetle/cover.jpg
Looks to me that to be period correct a one size fits all doesn't work. |
Posted: Wed Dec 03, 2014 8:58 pm Post subject: |
panicman wrote: |
Thanks for the info. I will check into them and ask about the dyna beads. Any certain tire store that you had those installed? _________________ 1964 Beetle Deluxe |
Posted: Wed Dec 03, 2014 9:37 pm Post subject: |
I had them installed at a local tirefactory store. The one local to me, http://www.tirefactory.com/millars
has really good customer service, and the crew that installed my tires was really careful with my painted wheels, and was happy to try the dyna beads in the tires. Great store. _________________ Plate of shrimp |
