PAdom Samba Member
Joined: December 19, 2009 Posts: 207 Location: Wilmington NC
Posted: Wed Nov 16, 2011 12:26 pm Post subject: Changing Fresh Water Lines |
85 westy
question . .. .
can you change your fresh water lines from the tank to the sink without taking the kitchen unit out? i have been searching for this topic. i think i once read that the water line gets stuck in the van frame or something behind the millwork somehow and that you should attach the new pipe to the old to pull the new line through. p.s. my pump is in my tank
thanks .. _________________ 85 Westy-EJ2.2 Powered |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
PAdom Samba Member
Posted: Wed Nov 16, 2011 1:43 pm Post subject: |
dobryan wrote: |
The waterline in my '87 was attached by some clips onto the frame behind the kitchen unit. If you can get something back there you may be able to release the clips, or just run a new line and leave the old one in place on the clips. |
that's a pretty good idea.
thanks dave. i remember hearing there was something back there. do you think removing just the fridge would good enough to get back there and get at those clips ? that's on my list too. _________________ 85 Westy-EJ2.2 Powered |
syncroserge Samba Member
Joined: November 26, 2005 Posts: 553 Location: Okotos, Alberta, Canada
There are 2 clips holding the line to the wall panel. From the faucet, the first clip is about 8 inches rearward from where the line goes through the panel.
The second clip you can access through the grill on the side of the stove, by the table. It is a few inches below the fridge exhaust tube.
In mine, 91 westy, there is a union in the line 6 inches below the faucet. I seperate it there and attach the new line to the old one and just drag it
through that way.
You can't reattach the clips but when you see the crud in the old lines you won't care |
PAdom Samba Member
Posted: Wed Nov 16, 2011 1:54 pm Post subject: |
syncroserge wrote: |
through that way.
SYNCRO
do you think the 1st clip you mentioned is accessible ?(By the faucet) i think that is the same spot where the LP gas lines go back to the stove. small spot. _________________ 85 Westy-EJ2.2 Powered |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Wed Nov 16, 2011 2:23 pm Post subject: |
Just get in there and fish a new line through, leave the old one in until you're done. Use a fish tape, or straightened out wire hanger. There's enough room to get a new line in there without taking out the cabinets. Cut back the old line after you're done and tested. It's not going into space. It won't matter if the new line is clipped in or not. _________________ 89 Westy 2.1 Auto |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Wed Nov 16, 2011 2:31 pm Post subject: |
With some contortions you can also get your hands on those clips that hold the hose by reaching your hand and forearm through the hookup holes on the side of the van (if your arm is skinny enough). You'll have to remove the city water and water fill hookup boxes to be able to reach in there.
This also gives super-easy access to be able to thread the new line through.
No need to reuse the clips. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
Posted: Wed Nov 16, 2011 2:32 pm Post subject: |
PAdom wrote: |
do you think the 1st clip you mentioned is accessible ?(By the faucet) i think that is the same spot where the LP gas lines go back to the stove. |
Yup, small black dot where the propane lines do a 90 deg. The other one is accessible too. They would pop out if you yank hard enough on the line...
but safer to push them out. |
PAdom Samba Member
Posted: Wed Nov 16, 2011 2:37 pm Post subject: |
PAdom wrote: |
Thanks guys . .i now know there are clips back there and what i need to do.
indytriple wrote: |
With some contortions you can also get your hands on those clips that hold the hose by reaching your hand and forearm through the hookup holes on the side of the van . |
Or you find a 8-10 year old...old enough to follow instructions but still have pencil arms.. one of my daughters even managed to get the clips back in once....the wind was howlin' in the Mojave so we had nothing better to do ! |
PAdom Samba Member
Posted: Thu Nov 17, 2011 6:34 am Post subject: |
PAdom wrote: |
PAdom wrote: |
found the two black dots popped them out and changed the water line . .thanks for the help guys !!
now i know the water is clean. _________________ 85 Westy-EJ2.2 Powered |
randywebb Samba Member
Posted: Sat Jun 15, 2013 8:43 pm Post subject: |
any pics? _________________ 1986 2.1L Westy 2wd Auto Trans. |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Sun Jun 16, 2013 8:20 am Post subject: |
Do you have to use/remove these clips, or can you just fish new hose through and skip the clips all together?
through that way.
Yes, please! I'm going to check my Bentley tonight, so hopefully that helps...
randywebb wrote: |
any pics? |
Great idea! If my arms don't fit, will get one of the children to try. Though, I have boys, they don't follow instructions like I'll bet your daughter did! LOL
indytriple wrote: |
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
