ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 707 Location: Shawnee, KS
Posted: Wed Nov 16, 2011 2:19 pm Post subject: 914 Fresh-Air Blower Voltage?!? |
Hi guys! I don't make it in here very often, but I am using a 1970 914 fresh air fan in my 1968 Baywindow. I modified the fan housing to help me pull heated air up into the front of the cabin. It doesn't get that hot so it should be ok.
My question is since I don't have the 914 switch or wiring plug is did the fan originally run off of 12v? There are spade connectors on the motor itself. I hooked it up to 12v and it works GREAT! : ) Does not seem stressed, etc.
Just thought I would ask the voltage before I put it to some real use.
Thanks! Porsche live on! _________________ 68-71 Baywindows are not fat chicks, but more like well developed hotties!
58 Convertible Baja
61 Deluxe 23 Window (Microbus 241)
64 Safari Trail Buggy (1st or 2nd Fiberglass Buggy in my hometown.)
Aug 25th 67 Euro Spec Early Bay (Microbus 221)
69 Deluxe Clipper-L Sunroof (Microbus 241) |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 328 Location: Seattle-ish
Posted: Wed Nov 16, 2011 2:20 pm Post subject: |
12VDC, correct.
You should be able to nab a 3-postion switch from a 944 or 924S so you can have all 3 speeds. That'd be kinda cool. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Wed Nov 16, 2011 2:23 pm Post subject: |
| Root_Werks wrote: | 12VDC, correct.
You should be able to nab a 3-postion switch from a 944 or 924S so you can have all 3 speeds. That'd be kinda cool. |
I would need the wiring plug and switch. I guess I could put up a wanted ad! Thanks for the great info! These fans are GREAT quality! Quiet and put out some serious cfms. _________________ 68-71 Baywindows are not fat chicks, but more like well developed hotties!
58 Convertible Baja
