New motor build 1904cc
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
W1K1
W1K1 is offline
PostPosted: Sun Apr 29, 2012 2:18 pm    Post subject: Reply with quote
Still working on getting the jetting dialed in for 3000ft over in the engine forum.
Right now, We are at
30 vent
122 main
55 idle
170 air
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1961 beetle
1965 squareback 1500E
W1K1
W1K1 is offline
PostPosted: Sun Apr 29, 2012 2:23 pm    Post subject: Reply with quote
Forgot to mention i picked up a vintage speed shifter last week, big improvement over the worn out stock shifter.
All new bushings and a proper type 3 hockey stick showed how bad the stock shifter was.
1973 super
1961 beetle
68notch
68notch is offline
PostPosted: Mon Apr 30, 2012 7:22 pm    Post subject: Reply with quote
Hey W1K1, I also got one the vintage speed shifters and found it to be very tight to shift which was frustrating at first. It's better now with 1 year of weekend use but could still be a little better. I loosened the bolts on the ball and lube it all the time.
Is yours like that or better out of the box?
John
68 Aussie notch
2011 Citroen Berlingo
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227
W1K1
W1K1 is offline
PostPosted: Mon Apr 30, 2012 9:13 pm    Post subject: Reply with quote
Mine is solid to shift, not stiff though. We have a berg and a CSP as well, they all shift nice.
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Sun May 06, 2012 12:25 pm    Post subject: Reply with quote
installed my Faux VDO tach Laughing
works pretty good for a princess auto $25 chinese tach.
lets see now..... gutted a stock clock from the junkyard. bought cheap tach. pulled the face, needle, glass,off the tach. Took the stock face from the clock with the numbers on and clamped it in the drill press and started sanding the plastic down on the back till the numbers are gone. put new numbers (water slide decal) on the front the same orientation as the numbers on the tach and clear coat it. I tried to have BOOM for 7000 rpm but I couldn't get the letters to line up nicely. Laughing
luckily the Chinese tach face screws and the clock housing face screws are really close to matching up attaching the old housing with revamped face and the new together was easy.
Then it was the needle I pondered this thing for a long time. I had 2 needles from an old sirocco gauge cluster but they were not the same size as the new tach post, plus the shaft from the needle is not long enough to reach. what to do, what to do?
Then I started thinking something skinny like a hypodermic needle, small enough inside to grab the tach post and I could drill the hole bigger in the needle if needed. Turns out I have a "Chair doctor" glue kit with a big fat needle that just slides on the post, and fit inside the needle. So cut to length and dab a spot of superglue on the ends.
I had a new glass cut for the face, a freebee from a "hot rod" friendly glass shop. As soon as the wife explained what it was for they just said good luck and sent her on her way.
So now I have a tach is a viewable spot in the dash and an oil pressure gauge in the old spot.
1973 super
1961 beetle
supaninja
supaninja is offline
PostPosted: Sun May 06, 2012 3:42 pm    Post subject: Reply with quote
I'm digging that tach Wink
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
IAMIROY
IAMIROY is offline
PostPosted: Sun May 06, 2012 5:04 pm    Post subject: Reply with quote
Very cool, nicely done Applause
Taking orders? Wink
Mark's Squareback build
W1K1
W1K1 is offline
PostPosted: Sat May 19, 2012 8:47 am    Post subject: Reply with quote
So the other night i'm fiddling around with odds and ends I've been fixing on the car while waiting for new jets in the mail.
I pulled the fuse block out so i could reach the gas gauge from behind and find this
My ignition switch is relocated in the console since the switch in the column has been sketchy. This is the wire from the fuse to the switch. Thankfully it was wrapped with two other wires in shrink wrap so not exposed Except the section just before the fusebox, which i noticed when i pulled the fusebox out.
I'm guessing it was when i shorted a wire from the coil on the old motor. It smoked a lot Shocked so i might have missed this one since i was at the back working on the motor.
As for my jets, i ordered them to ship priority air 6-10 days, but they shipped them 1st class to save me money, so now there is no tracking and no set delivery time frame. Confused
Thanks for thinking you were helping but i would rather have parts in hand to get something done on a long weekend, than wondering when they going to show up
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Fri Jun 08, 2012 9:08 am    Post subject: Reply with quote
Been a while...
I got my new jets 55 and 52 in the mail, the 55 were right in the hot range 14.5 afr so I went to try the 52's and they were not all the same size I had 3 that fit snug on the 50 pin of my jet gauges and 1 that slid on the 55. So sent them back and ordered 52 and 50 from ALFA1750 on ebay, they arrived in a week.
in the mean time I thought I would try the undrilled 60 idles since the drilled 57 were pretty close on the rich side. waaaay to rich, smelled gassy fouled my sensor (Black Shocked sooty).
So I'm going to pull the carb, check the plugs and valves and my CHT gauge for accuracy before I change jets again this weekend.
I have a weird thing going on with the stock fuel pump, it seems to heat soak real bad and boil the gas which is pushing fuel past my floats.
It doesn't over power the floats and flood if I have a gauge in the tee fitting but as soon as I take it out, it floods. I'm guessing the diaphram in the gauge is absorbing the pressure instead of the needle seats.
I have the fuel lines not touching the case, but i did a temp check on the case after sitting for 1/2hr to 45 min in the garage and the case read 100F while the pump which was making gurgling sounds measured 125F.
I think I may just wire up my spare electric pump and run that, I've never had a problem with them on our other 2 cars running dells and electric pumps.
1973 super
1961 beetle
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Jun 08, 2012 9:48 am    Post subject: Reply with quote
Waiting 20 minutes at Rest Stops to get our stock '67 to fire up got old! I wouldn't blame you for ditching the mechanical fuel pump.
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
Bobnotch
Bobnotch is offline
PostPosted: Fri Jun 08, 2012 11:23 am    Post subject: Reply with quote
Since you've got an AS 41 case, I can't help you. But on my all aluminum case, I had to switch over to an electric pump, otherwise the pump would vapor lock on shut down. The carb bowls stayed full, but the pump wouldn't push fluid, even with the electric pump running. Evil or Very Mad What I couldn't understand though, was that IF you left the engine running, the mechanical pump kept pumping. Think But with it now on the electric pump, I don't have that issue at all. Very Happy
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
W1K1
W1K1 is offline
PostPosted: Fri Jun 08, 2012 11:31 am    Post subject: Reply with quote
My wifes 2110cc with aluminum case did the same thing, drove us nuts piddling with that one. I finally had enough sitting waiting for it to cool off, swapped hers out after a couple months and a couple stock pumps.
1973 super
1961 beetle
Bobnotch
Bobnotch is offline
PostPosted: Fri Jun 08, 2012 11:46 am    Post subject: Reply with quote
I found it out the hard way, on the way to the 2010 Invasion. Shocked After the first time that it happened, I just left the car running for the rest of the day. If you were at some place where the car was allowed to sit off for more than an hour or so, it was fine, but it really hated rest areas. Surprised But after I got back from the Invasion, I had it do it again after a 3 mile drive to the paint supply shop (with a 20 minute sit), only to find it did it again. Evil or Very Mad In that case I already had the electric pump in place, so I just removed the hose from the pump outlet, and plumbed it into the fuel feed line to the pump, and drove home. Since then, the electric pump has been in place, and I also haven't had that issue again with it on the Notch. Cool
W1K1
W1K1 is offline
PostPosted: Sat Jun 09, 2012 5:25 pm    Post subject: Reply with quote
Got the new pump in after several hours of fartin around making a bracket for the beam
I wanted to get accurate numbers on my VDO CHT gauge so i pulled a cam out of my parts pile and set the gear on the stove till it was over 400F. Then i clamped the sensor to it and started measuring as the temps went down.
400f gauge = 300 at the ring
350 - 250
300 - 200
250 - 180
225 - 150
200 - 130
So all the time i thought it was running hot, it's not.
It sits at 350 most of the time.
Now to check my oil pressure with a gauge in the oil cooler and do some testing with my new 52 idles
1973 super
1961 beetle
Willo357
Willo357 is offline
PostPosted: Sat Jun 09, 2012 5:48 pm    Post subject: Reply with quote
350 - 250
300 - 200
250 - 180
225 - 150
200 - 130
get dakota digital cht gauges, they are are temperature referenced to a constant temp and will always read true no matter the ambient.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...highlight=
W1K1
W1K1 is offline
PostPosted: Sat Jun 09, 2012 9:22 pm    Post subject: Reply with quote
pressure gauge reads correctly, but the 52 jets protest a lot.
i'm hoping for good weather tomorrow so i can run on just the idle for a while and see where the afr is with them
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Wed Jul 04, 2012 8:41 am    Post subject: Reply with quote
I'm waiting for my new mains to show up, the 125's seem rich.
I had an interesting front end development the other day, maybe it had to do with the 8 66lb bags of concrete I was carrying last week.
My steering felt loose, I had a couple inches of play in the wheel. I had the bolts come loose on the box before and had the box moving on the beam which felt similar. So I crawled under the front the other day to check those, nope all good. Then I grabbed the rubber coupler to see if there was something loose or torn, then i noticed the splined shaft from the steering box moving in the coupling Shocked The bolt had loosened just a smidge and that little bit translated to a couple inches on the wheel.
The bolt still had the metal lock plate, and was reasonably tight. I replaced the bolt and nut so everything is nice and snug again. steering is back to normal now.
1973 super
1961 beetle
IAMIROY
IAMIROY is offline
PostPosted: Wed Jul 04, 2012 8:50 pm    Post subject: Reply with quote
I sure hope we don't have to fart around with carbs much. Shocked
W1K1
W1K1 is offline
PostPosted: Thu Jul 05, 2012 6:06 am    Post subject: Reply with quote
That's the trouble with having the LM2 stuck to the dash, i keep watching it and thinking its close but i can do better.
1973 super
1961 beetle
W1K1
W1K1 is offline
PostPosted: Mon Aug 27, 2012 8:56 am    Post subject: Reply with quote
I got my setrab cooler last week from Aircooled.net, very nice set up.
The only spot i can find to mount it is next to the trans because we are still running the heat exchangers.
I am wondering about the early Type 3 heat exchanger set up with this though.
The heat exchanger itself doesn't have an outlet on it for venting the hot air, it is on the attachment to the body. Which vents the hot air in the summer when it's closed right at the front next to the trans where I was planning on mounting the oil cooler. Not an ideal situation
I have a set of late ones, I may have to swap them and come up with a connector and hose to replace the early set up on the body to keep my heat.
1973 super
1961 beetle
Page 6 of 7
