laug6615 Samba Member
Joined: November 07, 2007 Posts: 552 Location: Greer, South Carolina
Posted: Sat Nov 26, 2011 3:58 pm Post subject: Lost 34 Pict3 post |
Hey guys, looking for a post regarding carb. I have a new Empi, yea I know, and once installed the lower adjustment screw on the left side does nothing. All the way in or way out and there's no change. Seems like I read a post somewhere here that described those symptoms. Valves have been set, dwell is set, no vacuum leaks that I can find. Also running a SVDA distributor. Any advice would help or the post referencing this. Thanks. _________________ Gary
______________________________
Allison Daytona DuneBuggy |
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 1190 Location: West Jordan UT
Posted: Sat Nov 26, 2011 5:13 pm Post subject: |
Yea I know the history of EMPI. I just wanted to make sure its definitely a carb problem. Most of the used Solex carbs have worn shafts and I'm not sure where to find a good rebuilt one. Only thing new in my area is EMPI or Bocar. Both have about the same history. _________________ Gary
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Nov 26, 2011 6:05 pm Post subject: |
If you have an old Solex carb try using the screw out of that - worked for me on an Euromax carb.
There's more info in the Stickys: http://www.thesamba.com/vw/forum/viewtopic.php?t=183060 _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
