beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Thu Aug 21, 2014 7:17 am Post subject: |
Top work!! _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Thu Aug 21, 2014 2:04 pm Post subject: |
virtanen wrote: |
One question is not clear for me, there is a douple hole at front, does the douple rectangular nut belongs to the bottom plate, spot welded there? I think it does. So some more work to do to be complete bottom plate |
I just took off the bottom of a ´49 heater chanel.
The rectangular block with the two threats lays moveable in a little metall cage that is fixed at the front end of the heater chanel and not fixed at the bottom plate. The cage lays just flat on the bottom but is only fixed at the front wall of the chanel. _________________ Master of my domain! |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Dennis74 Samba Member
Joined: May 03, 2009 Posts: 17 Location: Südküste Luftwaffe, Finland
Posted: Tue Feb 24, 2015 9:04 am Post subject: |
Once again, very nice parts Mika _________________ VW 1300 Sedan (6/-74) German Look 2110cc
VW De Luxe Sedan 11C (10/-51) Project "original"
VW 181 -72 Military |
Posted: Tue Feb 24, 2015 11:12 pm Post subject: |
Cool part again.
Most will never see it in the place it sits.
I never had till I had worked lately in that area.
You will make left and right I guess? _________________ Master of my domain! |
Posted: Wed Mar 25, 2015 10:56 am Post subject: |
I tested new half gear for Atlas brand. Works fine, but Atlas is a bit tricky to do the job. One of the pivot rivets need to open to get the gear riveted. To prevent cracking, the deforming area needed to heat to get it soft. Then pressed out by suitable pin and support. I didn't softened it for reassembly and get some cracks.
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
splitjunkie Samba Member
Posted: Tue Apr 28, 2015 9:17 am Post subject: |
Very impressive. As always! _________________ Chris
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Tue Apr 28, 2015 10:34 am Post subject: |
seeing stuff like this makes me smile _________________ regards
Uli
My57Oval Samba Member
Posted: Tue Apr 28, 2015 11:04 am Post subject: |
Totally amazing! All you need is a 200 Ton press and you could do floor pans and roof sections! 3 fold roof sections!
All you need is this setup....
https://www.youtube.com/watch?v=ixPhogfZTHU
Rob
VW Kaefer Samba Member
Joined: June 27, 2006 Posts: 87 Location: Scotland, UK
Posted: Tue Apr 28, 2015 11:40 am Post subject: |
Amazing parts and good to see _________________ 1976 Beetle 1200L |
Posted: Fri Jun 05, 2015 4:27 pm Post subject: |
Very nice!
I wish that i needed one....
Robs |
Posted: Thu Aug 13, 2015 1:37 am Post subject: |
Tiny metal parts this time, old style ring connectors. These first with 5 mm holes.
Here you can see the difference to a modern connector, and material thickness is 0.55 mm for modern and 0.70 mm for early:
Here the connector parts, the brass connector and rubber isolator:
Here soldered and squeezed to a wire:
Here the finished joint to a wire:
New projects |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Thu Aug 13, 2015 6:29 am Post subject: |
Very nice |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1747 Location: Winnipeg
Posted: Thu Aug 13, 2015 6:39 am Post subject: |
If you made up the wire that goes from the distributor to the coil with these connectors and correctly coloured wire I would buy a couple for sure!
Don _________________ Better and better mistakes! |
