Manxdreamer Samba Member
Posted: Sun Mar 15, 2015 7:49 pm Post subject: gates commando tires |
I am looking for a pair of gates commando tires or similar style to the sand blasters. if you have a couple please let me know. thanks. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
isucorvair Samba Member
Posted: Sun Mar 22, 2015 5:30 pm Post subject: |
Found a pair of F70-14 Gates Commando, locally.
If anyone is interested, the owner wants $200. They appear to be in great shape from the pics.
They are studded.
Check out Craigslist in the Quad Cities ( Iowa/Illinois)- search studded snow tires.
I can go look at them if you want. I'd love them on my Manx- but want something more modern. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Wed Mar 25, 2015 9:33 pm Post subject: |
BL3Manx, You used Gates xt Sand Command tires back in the day. What did you think of them as a tire? How do they work on different terrains? Any quirks about the rounded tread crown on hard surfaces? _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Thu Mar 26, 2015 1:01 pm Post subject: |
The round crown type off road tires are intended to be aired down so its contact patch is fairly wide and it has higher flotation. On a buggy that means you need to run less than 15 psi. On an unpaved surface, the tread provides good traction.
Its not really intended for regular use on the highway. If you run it aired down on the pavement it'll feel a bit squirrely. If you run it with higher pressure on pavement, the center of the tread will quickly wear. |
TrackerCasey Samba Member
Posted: Tue May 19, 2015 8:02 pm Post subject: |
I have 2 gates Sand Command tires and I am thinking about swapping to something a little smaller. They are not checked or worn but I thing they were cut at some point. Not sure how to upload a pic from my phone. |
scooterperth Samba Member
Joined: October 20, 2010 Posts: 38 Location: Perth Australia
Posted: Sat Jun 27, 2015 10:44 pm Post subject: |
This buggy has been sitting in a shed since the early 70's the owner started a resto but other things got in the way, it has brand new Gates tyres on it that have never seen the light of day since they were fitted to the rims way back then. It even has the blue dye on the whitewall to protect them. |
Posted: Tue Jun 30, 2015 10:39 pm Post subject: |
Best, I've seen! Is that yours now?
I believe I recall seeing in the magazine ads that the Meyers Manx maker in Australia also imported Gates Commando tires |
Posted: Wed Jul 01, 2015 12:42 am Post subject: |
No BL3Manx I wish it was mine, the owner is not very well and he doesn't know what to do with it yet. The buggy I think might be a pre-tag body as there is no ID plate in the rear, this may have been a Made Under License body from the dealer in Queensland. It is the real deal but as it has the tubes in the sides and also the block in front of the firewall section.
Now as for the tires, the word is there is a sea container with all the left over stock that the guy couldn't sell when he closed the business, because Gates were not a known brand in Australia they didn't sell to well....plus off road racing etc. wasn't that big here in the late 60's early 70's from the conversations I've had. So if I can fine the mother load of NOS Commando tires were laughing. |
Posted: Wed Jul 01, 2015 7:50 am Post subject: |
Here's that 1972 Australian ad for the Gates tires. They were still making and selling genuine Meyers Manxes there but B.F. Meyers & Co. in the U.S. had closed in Aug 71. Hope you find the container!
GeoffP Samba Member
Joined: July 14, 2002 Posts: 400 Location: Blaine WA / Vancouver
Posted: Tue Sep 06, 2016 10:33 pm Post subject: Re: GATES commando tyres |
Found a set for the rear of my old Manx off road car. Match the orig fronts perfectly!
