wehrbüchse Samba Member
Posted: Sat Dec 03, 2011 10:03 am Post subject: BOTH alternator bracket holes stripped badly. Any ideas? |
You guys should see me as I type this. I am just dismayed. I've been struggling lately with a drain on my battery and a back-with-a-vengeance bucking problem, and so I woke up bright and early determined to make some progress.
No dice.
I noticed the head sheared from the bolt where my alternator tension bar attaches, and set about replacing it. Once I had it off, I noticed the bracket to be quite loose. I went to tighten the left bolt and it kept turning, and it was LOOSE. It is stripped badly. This leaves me with BOTH holes stripped and deformed by the back-and-forth of the loose bolt. The right mount hole was completely stripped last spring, and until now I've bolstered the left bolt with the GoWesty bracket. One guy on here warned me!
I could roll with just the tension bar and the stainless GoWesty bracket and some rigged strap down to a muffler mount bolt or something, but for how long?
It's an impossible spot to access to do a helicoil, and I simply can't afford shop work that involves engine removal.
Any ideas?
dredward Samba Member
Posted: Sat Dec 03, 2011 10:17 am Post subject: Re: BOTH alternator bracket holes stripped badly. Any ideas? |
wehrbüchse wrote: |
No dice.
Any ideas?
Tap it to the nxt size up. _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
sbclayton Samba Member
Joined: October 14, 2003 Posts: 483 Location: A place where owning a VW and enjoying life are synonymous
Posted: Sat Dec 03, 2011 10:39 am Post subject: |
Better - TimeSert it and never worry about it again. No worries, no strain - you'll be just fine! Not that difficult to access..... Go for it! _________________ Steve - Tampa Bay Area
Original Owner (12/1990) of
NavDog, a 91 Carat
Enlightenment came when I realized that any time in my life I was having fun, it was somehow connected with owning a Volkswagen. |
BlackDogVan Samba Member
Joined: December 21, 2007 Posts: 855 Location: Vancouver Island
Posted: Sat Dec 03, 2011 10:44 am Post subject: |
Ya x2 on the timesert or helicoils. Going to he next size bolt is rarely a good idea, the other side of the connection might need mods to fit, your next alternator won't fit etc. _________________ Gone but not forgotten - 1991 Carat - AAZ transmogriffied to mTDi.
Still addicted, looking for Doka... |
Posted: Sat Dec 03, 2011 11:22 am Post subject: |
sbclayton wrote: |
Better - TimeSert it and never worry about it again. No worries, no strain - you'll be just fine! Not that difficult to access..... Go for it! |
Sounds like this is my only hope, though I'm pretty sure I can't get a drill in there, even if I pulled the coolant pipe. And at least one of the holes (the right one) is now oblong. Not sure where to start. If anyone's got experience with this, I'd sure be thankful for guidance. |
Dimitrios Samba Member
Joined: May 02, 2005 Posts: 113 Location: Athens, Greece
Posted: Sat Dec 03, 2011 11:32 am Post subject: |
Hmm you car is a panel/kombi right ?
It is tight here but consider also the option to have the engine hanged down at the front only to make the work easily...You have to remove the two shields,accelarator cable,AFM box and some coolant lines,also six 10mm bolts that secures the muffler shield and some more but it will work.If you have fresh coolant you can use a bucket to catch it and reuse it...
Good luck,
Jim _________________ Used Porsche 911 & VW 091 & 094 transaxles!!! |
Posted: Sat Dec 03, 2011 12:10 pm Post subject: |
Well, the guy at North Westy just told me they could do it on Monday but it sounds like quite a bit more labor than I can afford. However, they have special body-work drills they can use to get in there. Maybe I could do prep-work at home and have AAA tow it in for the time-sert. Or is it the case that I could do the time-sert myself if I can get the coolant pipe out if the way? Not sure where I'd start with that. It seems my Bentley was recently stolen out of my van. I've torn my entire house apart looking for it. |
Posted: Sat Dec 03, 2011 12:37 pm Post subject: |
If you have patience you can do it.You need basic tools,a bucket and a jack (hydraylic...10,13,6 allen and very very few more tools are required to do the job...It will take no more than 3 hours.
I can provide you step by step instructions if you like ?
Rgds,
Captjon1959 Samba Member
Joined: October 11, 2010 Posts: 287 Location: Peoria, Illinois
Posted: Sat Dec 03, 2011 1:26 pm Post subject: |
I had the same problem on the passenger side of the engine. If you remove the coolant pipe and use a 90 degree drill adapter (I got a cheap one from Harbor Feight for ten bucks) and a short bit you can get in there. I replaced all the threaded areas with inserts and then used the GoWesty bracket. It is worth the effort. _________________ 1984 Westfalia Wolfsburg Edition
Former 1.9 L now Bostig Ford Zetec |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Sat Dec 03, 2011 1:39 pm Post subject: |
Posted: Sat Dec 03, 2011 2:45 pm Post subject: |
BlackDogVan wrote: |
Ya x2 on the timesert or helicoils. Going to he next size bolt is rarely a good idea, the other side of the connection might need mods to fit, your next alternator won't fit etc. |
I agree but was thinking access. However letteing the motor hang for access and timeserts or helicoils is way to go. _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
Posted: Sat Dec 03, 2011 9:41 pm Post subject: |
I profusely appreciate the responses, but letting the motor hang seems slightly over my head, particularly with my Bentley guide disappearing just in time. Do you guys think I could do it removing only the obstructing coolant pipe?
BTW: if I detach that pipe on the right, will it pull straight out of the pump?
Thanks! |
Cygnus Samba Member
Posted: Sat Aug 11, 2012 5:24 am Post subject: |
I just had the same thing happen - both alternator bracket stud are broken off though fortunately are still sticking out a bit . They are pretty rounded though. Are these just threaded posts? I was thinking of welding a bolt on the end like some have mentioned. Are these supposed to be bolts or just threaded posts to receive a nut? What size are they? Heres a pic after I pulled the alt.
[img]
Thanks for any advice!
-Brian[/img]
edit - it won't let me post the pic - need to fiddle with that... _________________ '86 Syncro Timbertech Hightop "Cygnus" |
Posted: Sat Aug 11, 2012 9:01 am Post subject: |
They are bolts that screw into the aluminum, not posts threaded to accept a nut. It sounds like you're doing relatively great by comparison, as your holes aren't stripped (right?). I had to rig custom brackets that work along with the gowesty bracket* to enable me to run without using either of these posts. In retrospect I should've time-serted it when I had the pipe out of the way swapping my coolant pump.
Anyway, I bet you could get a grip on them with vise grips or one of those stud extractor bits they sell at hardware stores for 10 bucks. At the minimum, they will back right out if a nut is welded to them at a muffler shop. Somewhere in this thread or another thread I have about my alt bracket issues I list the part number of a v belt that'll enable you to drive a short distance (like to a muffler shop) without the alternator (it goes around the main drive pulley and the coolant pump pulley).
Keep us posted,
WB
*the GW bracket, which you are strongly advised to order ASAP, was not designed to be used this way, but nevertheless should not have been designed with the square corner that enables it to crack so easily. Additionally, when mine was fully installed it would no longer allow my undamaged alternator mount bracket to line up with both holes anyway. |
Cygnus Samba Member
Posted: Sat Aug 11, 2012 9:18 am Post subject: |
Thanks for the advice - I hope the bolts are not stripped - I tried turning em with vice grips (no dice) But I don't have any reason to believe they are stripped otherwise. I ordered the gowesty bracket today. I am not sure what you mean in that last part about the gowesty bracket - is it a bad design? Does it crack? Does it need the old bracket with it? Won't line up?
Do you know what the other v-belt that would work with the water pump is? That would be tricky to get on I expect since the alternator is used to tension it.
Thanks,
-B _________________ '86 Syncro Timbertech Hightop "Cygnus" |
Posted: Sat Aug 11, 2012 9:40 am Post subject: |
Just to be clear: it's the holes that strip, not the bolts. If yours are stuck it sounds like your holes are not stripped, which is GOOD news!
I don't remember what the belt number/brand is, I'm posting from a phone and I must officiate a wedding shortly, though you might be able to find it using the search for my posts including the word 'belt' along with 'bypass' or something. The belt stretches over the pulley with a screwdriver, not too tricky.
The gowesty bracket is intended to work along with the existing bracket. Since your holes probably aren't stripped, it probably won't crack and you should install it when it arrives. But it did crack on mine when I was using it with one unstripped bolt hole, and it wouldn't have if one particular corner were rounded.
One last thing: if you go to a muffler shop you should be assertive and don't ask them how much it'll cost or if they can do it. They can. Confidently state that you need them to weld nuts to the end of broken posts and ask them how much their hourly labor rate is. Because this job will take 10 minutes you should not be paying them 50 bucks or any such nonsense. |
Cygnus Samba Member
Posted: Sat Aug 11, 2012 10:06 am Post subject: |
Oh OK thanks for the clarification - Good news! I towed it home last night and just now went and broke out the BIG vice grips and some PB Blaster - Both are out and the holes are not stripped! Now just to wait for my new bracket.
Thanks for the advice!
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9769 Location: Mt Lemmon, AZ
Posted: Sat Aug 11, 2012 11:44 am Post subject: |
I have the GoWesty bracket in addition to the sotck bracket and observed no problem with that set up. As I recall Ben (poosibly on his website) came up with a home-made brace that did essentially the same thing as the GW bracket.
FWIW -- If needs must (with a good battery) you can drive a long way w/o an alternator -- my personal best is over 500 miles but that was only because I didn't realize the the alternator had failed. A temporary water pump belt can be fashioned from a length of nylon rope (did another 300 with that and the aux battery). |
Cygnus Samba Member
Posted: Sat Aug 11, 2012 12:06 pm Post subject: |
Ahwahnee wrote: |
Thats Awesome! More details on the nylon rope fashioning please?
Posted: Sat Aug 11, 2012 12:51 pm Post subject: |
bserret wrote: |
Ahwahnee wrote: |
-B |
Ahwhanee helped me out too, but I'd say don't bother with rope. Took me only a minute to find my bypass belt post using the search tool:
wehrbüchse wrote: |
I put a smaller v-belt on to bypass the alternator (DAYCO TOP COG 15300, slipped on tight without un-doing the pulley) and drove it to the muffler shop. Took the guy 10-15 minutes, the stud backed right out! |
