carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Fri Jan 10, 2014 12:32 pm Post subject: |
I'm refitting the interior with new carpets in my '69 Ghia, these two bits of board were in the pile of bits from the interior to re-fit. Can anyone tell me where they go please?
_________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
aerosilver Samba Member
Posted: Fri Jan 10, 2014 1:44 pm Post subject: |
They look like the pieces that go behind the rear seat,above the wheel arch, kind of like an extension to the interior rear 1/4 panel. |
Altema Samba Member
Joined: June 20, 2010 Posts: 2903 Location: Lower Michigan
Posted: Fri Jan 10, 2014 2:20 pm Post subject: |
carl4x4 wrote: |
That would make sense thanks, are they glued in? they don't seem to have any fastenings. |
Mine sort of lodge in place and seem to be held in by the shape of the area they fit into. I've never had one come loose on their own, but I have taken them out a couple of times. The bottom one in your photo is for the right side of the car, and the notch is there so the rear defroster tube does not get crushed.
Paul |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
ghialuv Samba Member
Posted: Sun Feb 09, 2014 9:01 am Post subject: unknown part |
I found in one of my boxes for my 58 Low another part which I don't understand for what it is good for and to which place it has to go to.
Maybe it was wrong boxed from the pre owner and belongs to another aircooled car ...
Any idea?
Regards, Peter
_________________ I remember the first time I saw one, and I knew I just had to get one. |
PFN Samba Member
Joined: September 26, 2013 Posts: 159 Location: Australia
Posted: Sun Mar 02, 2014 2:10 am Post subject: |
I'm feeling silly here, but after some cleaning behind the pedal cluster I noticed that tube which enters through the firewall, runs across the floorpan and then seems to exit through the tunnel. What is it?
_________________ 1962 1/2 Australian Made Beetle
1961 factory RHD Karmann Ghia
(gone now)
1964 RHD Conversion Karmann Ghia
1956 RHD Beetle
1972 Kombi |
Posted: Sun Mar 02, 2014 5:01 am Post subject: |
That little tube runs from the brake master cylinder to the rear brakes. It should run along the tunnel to the rear and exits through a grommet under the rear seat. Once outside it follows the rear fork alongside the gear box to the "T" joint which splits the pressure to both sides.
RHD cars have all this on the right side and LHD cars have it on the other side.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
PFN Samba Member
Posted: Mon Mar 03, 2014 8:27 am Post subject: |
Thanks Nicholas! I had a vague feeling that was brake related. _________________ 1962 1/2 Australian Made Beetle
(gone now)
1956 RHD Beetle
1972 Kombi |
Brassneck Samba Member
Joined: November 17, 2012 Posts: 420 Location: Seattle
Posted: Tue Apr 01, 2014 3:57 pm Post subject: |
OK, was going to start cleaning up my dirty engine bay today ('69 coupe), and noticed something in the right rear fender that I've never really noticed before...It looks stock, and it looks like a mounting bracket for something (like the charcoal canister?), but I can't find a reference for it anywhere...and in my manual, the canister (which I no longer have) seems to be typically more up front, near the decklid and in front of the oil bath.
Here's a couple of pics (It sits back behind the oil bath) and it looks like it would interfere with the side panel (If it had one) as it crosses both sides of that ridge line (Please ignore the wires hanging across the field of view):
Anyone know what it's for? Maybe for a really big fire extinguisher?
Thanks, |
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Tue Apr 01, 2014 11:07 pm Post subject: Re: unknown part |
ghialuv wrote: |
Any idea?
Regards, Peter
That's engine tarboard/insulation for a Vw bug, fits on the sides |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Wed Apr 02, 2014 2:16 pm Post subject: |
Brassneck wrote: |
Thanks, |
The answer is in here. It's a bracket for an autostick component. I have one too.
http://www.thesamba.com/vw/forum/viewtopic.php?t=457281&highlight=autostick+brackets |
Posted: Wed Apr 02, 2014 4:03 pm Post subject: |
Yes! That's it... Thank you Kman. Much appreciated. |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sun Apr 06, 2014 4:32 pm Post subject: |
I found this part inside the passenger door:
What is it? |
vwcomet Samba Member
Joined: January 05, 2008 Posts: 42 Location: Las Vegas, NV
Posted: Sun Apr 06, 2014 4:46 pm Post subject: |
I believe it clips to the rod that goes from the door opener to the actual latch on the edge of the door. It insulates it to keep it from rattling against the inner door. |
Posted: Sun Apr 06, 2014 6:02 pm Post subject: |
vwcomet wrote: |
That makes sense. I thought it snapped over something like that. The next time I have my door panel off I'll replace it... |
J1 Samba Member
Posted: Thu Apr 17, 2014 11:18 pm Post subject: |
While replacing the fuel filler hose, I found these nearby. What are they and will they come in handy some day?
Bonus question: Who does this resemble?
_________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
kman Samba Member
Posted: Sat May 17, 2014 4:13 am Post subject: |
I think the top two are bumper tube end gaskets.
I don't recognize the face. |
J1 Samba Member
Posted: Sat May 17, 2014 9:15 am Post subject: |
Thank you. I happened to run across another pic of those gaskets somewhere here since that post.
I believe the nostrils are what the door wedge rubber screws into, which makes sense since the wedges are missing on my car.
The bridge, still a mystery but it appears to be broken off of something so probably useless.
The mouth... still don't know... non-critical, but seems worth holding onto. Thx. _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sat May 17, 2014 10:11 am Post subject: |
The nose bridge looks like the wind shield washer/squirter without the little chrome pice on the top. It's upside down in the pic.
** nope looked harder. Don't know what that is. _________________ 63 ghia coupe |
