What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3, 4, 5, 6 ... 35, 36, 37  Next
tkfar
tkfar is offline
PostPosted: Thu May 22, 2014 1:18 pm    Post subject: Reply with quote
the nostrils and mouth are glove box related. the mouth is half of the glovebox arm and the nostrils screw under the dash into the "mouth " bracket .
"Better to burn out than to rust"
1958 Single Cab
1971 Karmann Ghia vert
tkfar
tkfar is offline
PostPosted: Thu May 22, 2014 1:43 pm    Post subject: Reply with quote
and the nose looks to be the plastic stud and nut embedded in the lower ghia dash panel or dash pad......
1958 Single Cab
team bogus
team bogus is offline
PostPosted: Wed Jun 25, 2014 11:43 am    Post subject: Reply with quote
From out of a 1967 Ghia.
This bolts up, accessible from the storage area under the package tray, and stick out into the engine compartment from the firewall.
The T handle turns all the way out and looks like a jet at the screwed in side. And then the hose leads to I don't know what.
What the hell is this thing?
1967 Karmann Ghia
KGCoupe
KGCoupe is offline
PostPosted: Thu Jun 26, 2014 7:05 am    Post subject: Reply with quote
Altitude adjuster?
It doesn't look exactly like the ones referenced in theses threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=465149&highlight=altitude+adjuster
http://www.thesamba.com/vw/forum/viewtopic.php?t=594900&highlight=altitude+adjuster
... but perhaps they varied by year?
Porschedave
Porschedave is offline
PostPosted: Tue Jul 08, 2014 5:43 pm    Post subject: Reply with quote
I think that is the regulator for a gas heater that would be installed under the rear seat area.
Dave
1977 911S
1958 Karmann Ghia build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139
team bogus
PostPosted: Tue Jul 08, 2014 9:21 pm    Post subject: Reply with quote
Dave
There was in fact, a gas heater installed under the rear seat!
I've since removed it as well. I don't think I'm going to use these pieces.
So they go together then? Makes sense.
1967 Karmann Ghia
Marlonius
Marlonius is offline
PostPosted: Sat Jul 19, 2014 8:17 am    Post subject: Reply with quote
Yep, definitely gas heater related. I took one out of my 69...not to be reinstalled later.
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Sep 23, 2014 4:37 pm    Post subject: Reply with quote
Found this little guy in my box of parts that came with my 73 coupe no idea what it gose on or holds?
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Tue Sep 23, 2014 4:42 pm    Post subject: Reply with quote
it holds the jack in place.
71 Ghia A/S - 88 Van A/T - 13 JSW TDI 6M/T
-Zodiac-
-Zodiac- is offline
PostPosted: Tue Sep 23, 2014 4:53 pm    Post subject: Reply with quote
Much appreciated,always wondered what it was for. Just finished working in the trunk area today. Now I need a jack
c21darrel
c21darrel is offline
PostPosted: Mon Oct 13, 2014 2:36 pm    Post subject: Reply with quote
Found these at a swapmeet this weekend and bought them to get them to someone who needs them. Any help in what year these belong to?
They are both Huf. #1 is a solid handle, It is labled "R" right side, 1430405452 part #, has 5584 near part #, also has 11K067 on it. Guessing one is a key number?
#2 has the same 5584 in the "hollow" handle where it says Huf, has S6157 on the chrome that slides into the door.
Also, are these grab handles correct for all lowlights and just lowlights?
Bolt pattern looks a little long for 60's dash.
GhiaBuild
1967 DC build
sputnick60
sputnick60 is offline
PostPosted: Tue Oct 14, 2014 3:25 am    Post subject: Reply with quote
I suggest that is SG157 and is the code for the key fitting this lock assuming the original barrel is in there.
for LHS
Part # 141 837 205 is up to '62
Part # 141 837 205 A is up to '63 to '66
Part # 141 837 205 B is '68 to '69
Part # 141 837 205 C is '67
Part # 141 837 205 D is '70 to '71
Part # 141 837 205 E is from '72 and up
Similarly for RHS 141 837 206 and so on.
You might need to look more closely at your part numbers. what you report seems to not match what's in my parts book.
Nicholas.
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c21darrel
PostPosted: Tue Oct 14, 2014 9:37 am    Post subject: Reply with quote
I knew you would be on this Nicholas, thanks. The stamping on the part # is very clear ( im going to try to photograph it) #1430405452. I samba googled and came up with nothing.
The grab handle is lowlight only? all years LL?
Thanks
GhiaBuild
1967 DC build
c21darrel
PostPosted: Tue Oct 14, 2014 11:04 am    Post subject: Reply with quote
Best pic i could get.
GhiaBuild
1967 DC build
sputnick60
PostPosted: Tue Oct 14, 2014 6:03 pm    Post subject: Reply with quote
Clear enough.
I've got 9 digit part numbers and a 10 digit part number is shown. Buffer overflow error. Does not compute. Danger Will Robinson. Brrrr Fzzzt Pop.
Brick wall
Nicxkjasd%#
NWGhiaGuy Premium Member
NWGhiaGuy is offline
PostPosted: Wed Oct 15, 2014 10:21 am    Post subject: Reply with quote
Just looking at the photos, those outer door handles are 63-66 style, maybe 67 too?
Yes, the dash handle is from the low light era, but I also had a '60 ghia with that one, but my '63 and later ghias had the black plastic handle. Haven't had a 61 or 62, but I think they were the later style also. 1960 was a bit of a transition year.
c21darrel
PostPosted: Wed Oct 15, 2014 10:27 am    Post subject: Reply with quote
Thanks Dan, Appreciate the info. Darrel
GhiaBuild
1967 DC build
thruhiker74
thruhiker74 is offline
PostPosted: Thu Oct 16, 2014 10:54 am    Post subject: Reply with quote
My '62 has the black plastic handle.
kman
kman is offline
PostPosted: Thu Oct 16, 2014 5:19 pm    Post subject: Reply with quote
It's the size of a tow hook. Chromed. Has part # KL 1970 with a VW logo stamped next to it. Can't figure out where it would bolt on.
Plantman
Plantman is online now
PostPosted: Thu Oct 16, 2014 5:42 pm    Post subject: Reply with quote
It looks to be the receiver for the lobster claw seat belts. Not positive though.
David
Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia
Page 5 of 37
