66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sat Apr 05, 2014 7:45 pm Post subject: |
MURZI wrote: |
1/8NPT and 10mm are so close....I use 1/8NPT on everything. |
Yeah 1 thread per inch at that size is negligible _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Sat Apr 05, 2014 7:46 pm Post subject: |
Motor is almost ready to shove in the back of the 68. As usual, I get a day off and it rains down here in Southern Louisiana. Southern Louisiana Rocks. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
66brm Samba Member
Posted: Sat Apr 05, 2014 7:48 pm Post subject: |
fivelugshortaxle wrote: |
I get a day off and it rains down here |
Perfect day to spend in the shed then, get er done _________________ Aust. RHD 66 Type 1
modok wrote: |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Apr 05, 2014 8:20 pm Post subject: |
You can buy that same brass tee for half the price in your local hardware store and there is no shipping.
You could also just run a VDO dual sender which will have a post for the stock light and a VDO pressure gauge. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sat Apr 05, 2014 9:06 pm Post subject: |
clonebug wrote: |
You could also just run a VDO dual sender which will have a post for the stock light and a VDO pressure gauge. |
Yeah, I may end up doing that. I have one, I just heard that they are set up different....read on aircooled dot net that it triggers at a lower psi ? _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Sat Apr 05, 2014 9:57 pm Post subject: |
clonebug wrote: |
..... it triggers at a lower psi ? |
If your new engine triggers a light you have a problem.
My light post doesn't work... the sender is stuck but the gauge works just fine. I'm too lazy to swap it out for the new one I have in a box.
With a fresh case you hopefully won't have pressure below 20 lbs if you are running a 26 mm pump. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Sun Apr 06, 2014 6:06 am Post subject: |
Those dual pole VDO senders do trip the light at a higher pressure than stock, but as long as you know that, it's no big deal. You'll have a gauge telling you the real pressure if there is question.
The only motor I ever had issue with that happening with was well worn. On a hot day fully warm, it would occasionally trip the light at idle. A quick glance at the gauge showed I was still making just shy of 10# of pressure, so no biggie IMO. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Apr 15, 2014 6:48 pm Post subject: |
Updates????? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Ryanh1323 Samba Member
Posted: Wed Apr 16, 2014 1:33 am Post subject: |
12/11/2012!?! Any chance this is a real build? I'm not going to bother reading thru 64 pages of posts because most of it seems like garbage that has no business being on a forum about cars. I don't want to hate, but a few years back I built a similar motor that is still running today and took less time to build (did my own machine work) than this clown has spent posting on a single topic.
I joined this site for information, not to listen to your personal problems. Also you seem like a dick from what I have cared to read. Either build an engine or stop wasting everyone's time.
Thanks for a complete waste of a topic
Ryan |
mark tucker Samba Member
Posted: Wed Apr 16, 2014 7:25 am Post subject: |
and new puppys smell just like.......with all the wining this thread could be just 5 pages long or less. If I recall correctly this same guy said the same thing...so why is he still reading the thread???? he must be a fan of my wit&banter...possiably my mutliating of the spelling teachers hard work....or is it the weather updates?/ he forsure dosent waht to hear any thing about the prior 64 pages....wonder if he is after some info on what to do in cali???or possiably what penny loafers to get....or stay away from. |
Posted: Thu Apr 17, 2014 2:52 pm Post subject: |
You do not recall correctly or spell correctly or form a readable sentence.
But what difference does it make.
I'm done reading (for the first time) this never ending topic. Instead
I'm going to go help my uncle jack off a horse.
My bad I meant to say I'm going to go help my uncle Jack, off a horse. |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Fri Apr 18, 2014 3:03 pm Post subject: yes |
Its like this if you dondt like porn do not look if you have a problem with guns do not buy one , if you think this thread is shit do not read it ...real simple _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Fri Apr 18, 2014 3:18 pm Post subject: |
Ryanh1323 wrote: |
No one is making you click on the thread douche-bag... _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Fri Apr 18, 2014 3:41 pm Post subject: |
And Mrs ryanh is.what I've been talking about...anyway......I ran into a problem with my exhaust. It's bugpack 1 5/8 merged. It won't go on with the sled tins and industrial tins. Actually wouldn't go on with just the sled tins. I think it was Glenn that said the berg exhaust fits. Glenn, you out there? And yeah.....California on my mind. Going to Los Angeles to work E3. May 31-June 17. And the princess may have a job in Eureka. They're flying her out for a formal interview next week.
Yeah, this.has taken a while....so what. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
modok Samba Member
Posted: Fri Apr 18, 2014 5:25 pm Post subject: |
Yeah, most all merged headers go though where the sled tin goes. It is kinda like that for a reason tho. Decide if performance or "tin" is the higher priority and modify accordingly!
Yes berg header should work with them. |
Posted: Fri Apr 18, 2014 5:35 pm Post subject: |
I wonder if reannah 123456 is enlisting his grammer to help with his uncles horse,,??
just getter done when you getter done. Im slowely worken on mine onbetween this & that& migrains. I did get some trick pistons ordered today.hopefuly they will do what I want.
74 Thing Samba Member
The Bugpack Street Max header is make to be used with heater boxes or J pipes and to run all the tin and the thermostat
http://vwparts.aircooled.net/STREET-MAX-HEADER-1-5-8-w-Stinger-Ceramic-Raw-p/2009-13-2009-23.htm
The Berg header is the GB933S - that is the 1 5/8" header that clears the tin and you can use the thermostat.
Your other alternative it so use an A-1 sidewinder header that is made to be used with heater boxes (you can use them with J tubes though) and they are made to clear the tin and thermostat also. |
MURZI Samba Member
Posted: Fri Apr 18, 2014 7:01 pm Post subject: |
You don't need all those tins. My cars have run for years without them...... In south Louisiana. With 94's at 12.7 AFR... In a vert... Don't believe everything you read. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Sat Apr 19, 2014 7:53 am Post subject: |
74 Thing wrote: |
Yep. That's it. Pipes from one and three look like the go outside where the sled tins are. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
