dingdow Samba Member
Joined: December 13, 2011 Posts: 20 Location: Clearfield, Utah
Posted: Tue Dec 13, 2011 1:01 pm Post subject: Toggle switches for my 68 beetle |
I want to change my switches to toggle switches on my 68 beetle. Does anyone know how to do this? Lots of wires going to the same switches, need directions and pictures, please? thanks |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Tue Dec 13, 2011 1:11 pm Post subject: |
change what switches? _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
TjdTaylor Samba Member
Joined: July 04, 2011 Posts: 1727 Location: Niagara Falls, Ontario
Posted: Tue Dec 13, 2011 3:56 pm Post subject: |
changing the switches could be problematic cause where are you going to but them? in the old switch holes? they definately wont fit. i would just pull them out and swich wired from one wither to the other _________________ 1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote: |
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows |
Posted: Tue Dec 13, 2011 4:59 pm Post subject: 68 bug switches |
I want to change the switches to the lights, wipers, emergency flasher lights, and add a momentary switch for the window washer and a toggle switch for the dome lights. I plan to put them in the dash after removing the pad (it's all cracked anyway). You can use a large washers with the holes the size of the switch mount. And maybe some lights to show what switch is on.
I want to clean up the dash area and paint it to match the inside. Normally you could just tie the wires together with wire nuts, then attach them to the the tabs on the switch. But the wipers have a delay to stow the wipers back where they belong. I plan to put a aircraft (red) cover over the emergency flasher switch to give it that aircraft look.
What do you think?? |
Posted: Tue Dec 13, 2011 5:03 pm Post subject: |
I think your loosing it !
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Dec 13, 2011 6:11 pm Post subject: |
Guessing it's just for visual purposes?
Why not just get some nice shiny billet knobs
The hazard and wiper switches are fairly complex, wiper switch has to send power for the park mechanism as well as two speeds and the hazard switch has to power up the relay when ignition is off but also change it over to turnsignal power once its on.
Even the headlight switch has several functions, rheostat, parker circuit etc.
It could be done but you are creating a huge job for yourself. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Greg in GA Samba Member
Posted: Tue Dec 13, 2011 7:50 pm Post subject: |
I hate to say this but you may be creating a mess for the next owner to fix. That is unless you have the determination to finish the job and make it look nice and neat. _________________ 1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area. |
Posted: Tue Dec 13, 2011 8:10 pm Post subject: |
reducing the value of the car ! _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue Dec 13, 2011 8:22 pm Post subject: |
Race cars, rails, buggies, ext have been set up like that for years. Its going to be A pane in the ass to do all the custom wiring but can be dun _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Tue Dec 13, 2011 8:47 pm Post subject: toggle switches |
I think the stock or those billet knobs are very ugly. It is much more fun and looks better to flip a toggle switch. I'm building a custom car, not your looks like you bought it off the show room floor or grandma's kind of car. Race cars and most really good custom cars use them. So don't dog me about my ideas of what looks good, ok? |
Posted: Tue Dec 13, 2011 8:57 pm Post subject: |
I wasn't dogging anyone's taste. I've seen some very nice custom jobs on here and at car shows. As long as you know the job is going to take twice and long and twice as much effort as orginally planned....I say go for it. _________________ 1969 Beetle
Posted: Tue Dec 13, 2011 9:05 pm Post subject: Re: toggle switches |
dingdow wrote: |
WOOOOOOOOOo big fella... your getting you panties bunched up for no reason! know one told you it was stupid... Just that its going to take some planing and work to pull it off
Ok maybe Jerry, But no one listens to him anyway _________________ 1302s sunroof..
Posted: Tue Dec 13, 2011 9:57 pm Post subject: 68 switches |
I understand, I'm just looking for some help on planning it all out, that's all. I'm cool with ya'all, ok? Wiring is a mess at best anyway. I have been chasing a wiring problem since I bought this one. So I'm just looking for away to do this. Any ideas? |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Tue Dec 13, 2011 10:42 pm Post subject: Re: 68 switches |
dingdow wrote: |
It's gonna' require a few specialty switches and relays, just about each one of these ideas has been taken on by someone in the past. Do some searches across the internet and you should be on your way to learning. |
Posted: Tue Dec 13, 2011 10:52 pm Post subject: 68 switches |
cool thanks |
JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Tue Dec 13, 2011 10:54 pm Post subject: |
didnt the later models (maybe 74+ super) have toggle switches? you might be able to rewire your car so that you could use those toggles. this would also give you a good head start on how it should be wired because you would be able to check out the wiring diagrams to help work out some of the probs involved with the changes. _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
Joel Samba Member
Posted: Tue Dec 13, 2011 10:58 pm Post subject: |
Nah, rocker switches, and the dashpanel has special moulded in sections to clip them in place
PatterBon Samba Engine Connoisseur
Joined: September 27, 2008 Posts: 3446 Location: Copperas Cove, TX
Posted: Tue Dec 13, 2011 11:36 pm Post subject: |
My airplane doesn't have any cover over any hazard switch _________________ PNW Dub Folk & Kitsap dub Folk (KdF)
Austin Aircoolers VW Gang
2020 Ford F-150
1973 Standard Beetle
1969 Cessna 172K Airplane
1959 Karmann Ghia
US Army CH-47 Chinook Helicopter Repairer |
Posted: Wed Dec 14, 2011 3:12 am Post subject: |
PatterBon wrote: |
My airplane doesn't have any cover over any hazard switch |
Posted: Wed Dec 14, 2011 8:23 am Post subject: |
Just throw in a rocker on some drilled sheet metal - If you going to custom the dash - weld the sheet metal panel in
Then wire in a relay like below - the toggle or rocker on off switch would go between the 30 and to power
As I showed before take a piece of rectangular tubing and then just rest the entire panel across the bottom of the dash - If you’re looking for a simple
