Steven Samba Member
Posted: Wed Dec 21, 2011 11:57 am Post subject: |
I went ahead and ordered the key switch and the plastic ignition switch. So those are on the way.
Instead of cutting or splicing any factory wires I will wait and see if anything is screwed up on the column and if the switches fit and work, etc.
Anybody know why the PO put that extra starter junction block in? |
JonF Samba Member
Joined: December 16, 2005 Posts: 2030 Location: Oklahoma
Posted: Wed Dec 21, 2011 1:59 pm Post subject: |
jodybug wrote: |
OK, I'm under the rear seat and i have a coule junction boxes. Heres a pic.
Is this all stock from the factory under here? |
jody bug the red wire right next to the blue wire with the big plastic connector in the lower center of the photo... you see it. if you unplug that red wire you can then plug a short jumper into the back half of it and tap it on the battery and the starter will spin.
that relay box looks like it might be for the rear window defogger. the blue wire on the left side of the photo i am not sure what it is. you might track it down and see what it plugs into after it goes out that hole under the back of car.
if your still wanting to try to hot wire your car for testing purposes just hook a wire to the hot side of the coil and then to the +plus side of the battery and the coil will be hot and use the red wire i am talking about above to spin the starter. _________________ 68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix |
schadenfreude Banned
Posted: Wed Dec 21, 2011 2:37 pm Post subject: |
i think it's not a test
its to actually run , it and not spend money
i think?
and i have the grommet on mine, and no wires there.
so mine was hacked, i will find out now.
Last edited by schadenfreude on Wed Dec 21, 2011 2:56 pm; edited 1 time in total |
JonF Samba Member
Posted: Wed Dec 21, 2011 2:52 pm Post subject: |
schadenfreude wrote: |
its to acutally run , it and not spend money
i think? |
i am just going by his 1st post on this thread...
jodybug wrote: |
Is there a way of starting the motor to see if it will run and if it is any good? |
to me that sounds like he wants to test his engine to see if it even runs. so maybe he can start fixing things. _________________ 68 bug 1600sp 30/31
Posted: Wed Dec 21, 2011 3:00 pm Post subject: |
yes , how to do it and not start a fire
he said the ignition KEY SWITCH wires are laid bare.
so that big red one is hot all the time.
so first fix that, then hot wire it any of the 3 ways.
it will start and run. and not catch fire.
how you choose to do it , or for how long, is your call. OP |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Mon Jun 14, 2021 4:05 am Post subject: |
Itawayoflife wrote: |
Hot wiring: off the ignition take the thick solid red wire (power all the time from fuse block) and the thin black wire (power to the coil) and twist them together. The take the thick red & black wire and hold it to the other two wires until the engine starts and then let go the red & black wire so it doesn't touch the other two while the engine is running. I don't recommend doing this for long periods of time. It can cause the black wire to overload and burn. You should get the ignition switch fixed before you start driving it.
The auto stick is like driving a manual without a clutch. You still have to shift through the gears like a manual, you just don't have to push the clutch pedal to shift. Here is a better explanation: http://www.thesamba.com/vw/archives/manuals/69bug/page20.jpg |
Saved my car from being impounded and I don't have the dough to bail it out. VERY good info.
Ignition lock failed (new) and the part it goes into slid out (took steering lock with it).
Thank God for the samba and the guys/gals on it! |
