kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
badassdubs Samba Member
Posted: Thu Jul 25, 2013 12:42 pm Post subject: |
That will be next if this on fails. |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Thu Jul 25, 2013 12:47 pm Post subject: |
so...transmission? Inquiring minds need to know... _________________ Cheers,
Dennis Wood
The Grape |
Posted: Thu Jul 25, 2013 1:11 pm Post subject: |
denwood wrote: |
so...transmission? Inquiring minds need to know... |
Well that's another story. I thought this one would fail quickly, but I was wrong. I am currently working on building a new house with a 9 car radiant heated garage. So I will be tied up for awhile with that.
I can say this though. It won't work with a Subaru motor but will work well with a v6, v8 or any inline engine. I have see this set up with a BMW engine.
Subaru is just to wide. |
Posted: Thu Jul 25, 2013 2:00 pm Post subject: |
Our building here (super insulated blah blah) has 4800 sq/ft of over poured radiant heat spec'd by yours truly during our acquisition/gut/expansion last year...staff loves it when it's -35 C outside. Not sure if I'd do radiant again given the fact that we have 5 air handlers as well to deal with AC and fresh air...in a superinsulated building. At just a fraction over ambient, the floor will overheat the space...so it never feels "warm". Heating costs for 10 000 sq ft (winter temps at -35C coldest) at worst were $280 for a month. For the business across the street with less space... (not so efficient) $2000 over the same period.
That said, on a 9 car garage with leaky doors etc., that warm slab will feel pretty crazy toasty. Champagne wishes, caviar dreams..9 car, sheesh. Might as well throw an evauated tube array up on your roof while you're at it _________________ Cheers,
Dennis Wood
The Grape |
Posted: Thu Jul 25, 2013 2:37 pm Post subject: |
kuleinc wrote: |
Have you tried a urethane version? |
badassdubs wrote: |
Urethane is not suited to the shear forces that are applied to the steering joint. Look up the failures that the lightweight Beetles have with urethane. Think what the Vanagon would do to them. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
t'sunamibus Samba Member
Joined: January 29, 2012 Posts: 202 Location: Westport, Washington
Posted: Thu Jul 25, 2013 7:07 pm Post subject: |
That has to be a PO issue, not knowing how to pull up to or away from a curb or something like that. |
Posted: Thu Jul 25, 2013 7:48 pm Post subject: |
denwood wrote: |
That said, on a 9 car garage with leaky doors etc., that warm slab will feel pretty crazy toasty. Champagne wishes, caviar dreams..9 car, sheesh. Might as well throw an evauated tube array up on your roof while you're at it |
It doesn't get to cold or hot where I'm at so that won't be an issue. The house will be radiant heat also. Normally we only need ac for a few days here. All structures will be spray foam insulation so it should be fairly tight.
That $280 vs $2000 tells the whole story.
Yes that is a new one. A few pages back you can see where I talked about the new one and showed the old 30+ year original. Scary stuff. |
GreenMachineVW Samba Member
Posted: Thu Jul 25, 2013 8:20 pm Post subject: |
badassdubs wrote: |
For the life of me, I cannot find any pictures, or mention of the old one in this thread ... |
Posted: Thu Jul 25, 2013 8:50 pm Post subject: |
GreenMachineVW wrote: |
badassdubs wrote: |
My bad. Here it is. Hard to believe it could deteriorate like this in only one year. It crumbles in your hand. The one on the right is the original vanagon one.
Posted: Thu Jul 25, 2013 9:20 pm Post subject: |
Wow.
(Thanks for the sanity check!) |
heynanc Samba Member
Joined: September 13, 2013 Posts: 35 Location: North Carolina
Posted: Thu Nov 14, 2013 4:36 pm Post subject: Original? |
badassdubs wrote: |
badassdubs wrote: |
OK. First off -Holy Freaking WOW on your magnificent everything!!!
But on the steering thing - is that a New one, and a one year old one, or is that a new one, beside a one year's use one that looks like 30 years of use? _________________ Nancy
2011 Subaru Outback daily driver
1975 “art bus” transporter “Cherry Garcia”
1984 Westfailia Vanagon EJ22 “ Guinness”
2006 Dodge Sprinter (long/tall)
2006 Winnebago View (in case the buses aren’t cooperating) |
Posted: Sat Nov 16, 2013 1:56 pm Post subject: |
I'm starting to get confused now. Here is the correct order.
UPDATE: Well I have no updates. Sorry. The van has been almost trouble
free, only minor issues. Cooling setup has been trouble free. Mileage has been around 15 mpg. Not too bad considering it is running in open loop.
Future plan is to run meqasquirt 3 to remedy the situation. Along with true vortec heads and marine fuel injection. The transmission swap is calling me, so that might happen sooner than later.[/img]
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Sat Nov 16, 2013 2:39 pm Post subject: |
Nice build, it's good to see someone trying a less ordinary engine swap. I was looking at all the different engine adapters at the KEP website and wonder why so few of them get used.
I'd love to see the s2000 engine in a sweet lowered GL. |
Posted: Sat Nov 16, 2013 7:30 pm Post subject: |
Thanks. You have to be careful on the small displacement engines. You need to look at the torque the motor makes. Hondas are low on torque and that is what is needed to move a big heavy van. 150 torque is too low in my book.
260 torque in the vortec v6 is a real mover. This has been driven for a year now with no transmission problems. Treat it right and don't drive it like you stole it. My trans has approx. 150K+ miles on it. |
Vanagon Nut Samba Member
Posted: Sun Nov 17, 2013 11:58 am Post subject: |
Zoinks. As with others, am finding it hard to see how that coupler started to fail in only 3000 miles.
Thankfully, it seems that part of the design allows for some poor feel to driver before failing completely. Link to an old webpage of mine containing an image of severely failed coupler (not mine) that IIRC, was still somehow in use. https://sites.google.com/site/tubaneil2/steeringcouplingdiscfrom%2781
I'd be very curious as to the price paid for that then new part. i.e. there must be a marked difference between any NOS and newer offerings.
Glad to hear your conversion has been trouble free!
1988 West DIY 50º ABA
VE7TBN |
Posted: Mon Feb 10, 2014 5:51 pm Post subject: |
So I was thinking about changing the heads and installing a marine fuel injection setup along with megasquirt, which would have run about $2K, but I decided to work with what I had and decided to burn my own chips.
I went with Moats http://www.moates.net/gm-19851995-c-64.html since he seemed to have the best setup for my needs. I purchased the chip adapter, zif socket, ALDL w/cable and the chip burner. There is a bit of a learning curve but so far I have been able to get rid of the automatic transmission codes. No more check engine light. I also made a VSS or reluctor ring as GM calls it and attached it to the cv joint at the trans along with a gm vss sensor.
Finally the ecu knows that the van is moving and it goes into closed loop. The chip adapter allows me to keep my original EPROM, which only allows the use of the limp home mode and cruise control part of it, while also utilizing the zif socket for the burnable chip. The zif socket makes it easy to remove the chip for burning purposes by just moving the lever and will be permanently removed once I have the chip calibrated to where I want it.
You can also burn on the fly but I chose just to remove the chip to burn it because of the added expense.
ALDL cable for access to OBD1 plug.
Chip burner.
As of a few months ago an app for OBD1 was created so I purchased that along with a Bluetooth adapter which makes it really easy to see what is going on.
Bluetooth adapter.
Screenshots from my tablet.
GM also uses what is called a DRAC and is for adjustment of gear ratio and tire size along with converting the AC signal from the VSS sensor to a DC output. I installed a dip switch to make adjustments easier. I use this only for the ecu, not for the speedo as I have a skydrive gps for that.
Still learning but hoping to improve gas mileage. Driveability has already changed. Once I put in the new trans I will also be able to set that up also
with this program. I use tuner pro. http://www.tunerpro.net/
Posted: Mon Feb 10, 2014 5:58 pm Post subject: amazing |
I suspect I am not alone in being impressed by your knowledge and application thereof. Awesome! _________________ Nancy
Posted: Tue Feb 11, 2014 4:07 pm Post subject: |
Thank you. |
