Kevin1957 Samba Member
Posted: Sun Dec 25, 2011 4:52 pm Post subject: Battery draining |
The battery on my 72 convertible is less than a year old. With colder weather, I haven't been driving it as often and the car may sit for a few days without being started. The last 2 times I turned the key the battery was too low to turn the car over. The generator light comes on.
Are there tests to determine whether this is a battery drain problem or a charging system issue? The generator and regulator appear to be original.
Thanks. |
h2odrx Samba Member
Joined: August 15, 2011 Posts: 56 Location: Eastern Neckville NC
Posted: Sun Dec 25, 2011 7:24 pm Post subject: |
where did you buy it and what type of warranty? It could have a dead cell from the start? _________________ - | Quote: | | Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown? |
| Quote: | | NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.'' |
Posted: Mon Dec 26, 2011 3:38 am Post subject: |
| O'Reilly. Yes, I believe it had a warranty. |
snookerdude Samba Member
Joined: June 30, 2004 Posts: 909 Location: central florida
Posted: Mon Dec 26, 2011 7:20 pm Post subject: testing for leak |
| remove the positive cable from the battery and with everything off and the wire to the clock removed, check for voltage between the battery clamp and the battery post. if you register voltage then something is draining your battery that shouldn't. |
Posted: Mon Dec 26, 2011 7:48 pm Post subject: |
| Thanks, this sounds promising. I"m not clear on where to connect the ends of the meter. |
Loren  Samba Member
Posted: Mon Dec 26, 2011 8:54 pm Post subject: |
| Remove the positive cable from the battery. Hook one end of the meter to the cable, the other end to the battery post. If there is a drain you will see it on the meter. Next remove each fuse in the fuse block, one at a time, until the drain stops. When you know which curcuit is causing the problem you can trouble shoot from there. |
ovghiaguy Samba Member
Joined: November 07, 2009 Posts: 827 Location: Orangevale Ca.
Posted: Mon Dec 26, 2011 10:04 pm Post subject: battery draining |
| do the test mentioned.if you don't get results from that you could always take battery to o'reillys and have it load tested. or just about any auto parts store also |
Posted: Tue Dec 27, 2011 6:08 am Post subject: |
| Thanks a lot. |
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1317 Location: Lebanon Church, VA
Posted: Tue Dec 27, 2011 7:54 am Post subject: |
Do you have an aftermarket stereo hooked up? That was the cause on mine. They require an "always on" connection for the clock and memory and that was enough to drain my battery over time.
I also suggest that you install a Battery Minder. Great device that will keep your battery charged and in top shape. Good luck! _________________ Mike
'67 Ghia Coupe "Lumpy"
The Panhandle Aircooled Club: www.panairvws.com |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1569 Location: Seattle, WA
Posted: Tue Dec 27, 2011 8:07 am Post subject: Re: Battery draining |
| Kevin1957 wrote: | | ...The last 2 times I turned the key the battery was too low to turn the car over. The generator light comes on... |
Did the light dim when you went past the ign position and into the cranking position?
If you go the route of a trickle charger, make sure to buy a quality Battery Tender or other brand - someone was just posting the other day about a customer who about burn down the house when their cheapo unit went T-U...thousands of dollars of damage to just the car. |
Altema Samba Member
Joined: June 20, 2010 Posts: 2051 Location: Lower Michigan
Posted: Tue Dec 27, 2011 8:29 am Post subject: |
Fire risk is why I disconnect my battery if I'm not planning on driving for a couple days, but it does ensure that there is no drainage from the stereo. I do have a solar battery maintainer but it only works if you park outdoors of course. Used it on my daughter's car and it kept the battery ready to go for half a year, with free electricity and pretty much zero fire risk.
But, identify the cause of the problem first
Paul
Posted: Tue Dec 27, 2011 8:30 am Post subject: |
I agree with Chris completely. Get a good trickle charger like a Battery Tender or Battery Minder. Always do your research before purchasing any device like this.
I think this is the thread that Chris was speaking of and it's worth a look:
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...mp;start=0
EDIT: I also agree 100% with Paul. Find and address the actual problem first. _________________ Mike
Posted: Tue Dec 27, 2011 12:27 pm Post subject: |
| Thanks, guys. I appreciate the helpful advice. |
John K  Samba Member
Joined: January 10, 2010 Posts: 69 Location: NORTH CAROLINA
Posted: Tue Dec 27, 2011 6:06 pm Post subject: |
| I have the same problem with my Ghia, so what I did temporarily until I can get the car looked at is that I put in a battery cut off switch at the battery. A very convenient way to disconnect the battery. And also it acts as a theft deterrent. When I figure out the battery drain problem, I'm still gonna leave the cutoff switch hooked up. |
