VWheeler Samba Member
Joined: October 21, 2010 Posts: 473 Location: Tallahassee, FL
Posted: Mon Jan 02, 2012 11:16 am Post subject: alternatives to dynamat |
i want to cover my interior with dynamat, but its really expansive. whats a cheaper alternative with the same effects? _________________ 74 1303 |
bajajoe16 Samba Member
Joined: August 03, 2011 Posts: 88 Location: eatonville
Posted: Mon Jan 02, 2012 12:02 pm Post subject: |
they sell this roofing stuff at lows that works |
1973 Super Beetle Coupe Samba Member
Joined: September 18, 2010 Posts: 88 Location: Georgia
Posted: Mon Jan 02, 2012 12:13 pm Post subject: Re: alternatives to dynamat |
VWheeler wrote: |
i want to cover my interior with dynamat, but its really expansive. whats a cheaper alternative with the same effects? |
try this stuff. I picked it up at Lowe's. 2 rolls should be more than enough to do the whole car if ur doing the floor boards too. if just the doors than 1 roll. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Jan 02, 2012 1:13 pm Post subject: |
Do a search for sound proofing - lots a good threads. I use "Quik Roof" from Home Depot. _________________ D-Dubya Manx clone - 63 Short pan,1914.
mittsfit Samba Member
Joined: December 21, 2010 Posts: 28 Location: Destin,Fl
Posted: Mon Jan 02, 2012 1:16 pm Post subject: |
hello, You can go to home depot and buy quick roof in the roofing dept or lowes roofing called peel and stick, also buy 1/4 inch carpet pad to put over the roofing material for added deadening. They are both good and have the peel and stick option...they come in 6 or 8"x25' rolls Good luck let us know what you've done and how it works, thanks _________________ Kusten Kruezers VW club, Fort Walton Beach,Fl |
donmurray Samba Member
Joined: December 30, 2008 Posts: 841 Location: Frisco Texas
Posted: Mon Jan 02, 2012 2:29 pm Post subject: |
http://secondskinaudio.com/
Appears to be good stuff. Heavy foil on one side, very sticky on the other side, dense rubber stuff in middle. I put 2 layers inside firewall, 1 layer on package area floor, and some on doors. Think I bought it from CIP1, but can't remember for sure. |
ryohey Samba Member
Joined: August 08, 2007 Posts: 560 Location: Plains, PA
Posted: Mon Jan 02, 2012 2:54 pm Post subject: |
Code: |
hello, You can go to home depot and buy quick roof in the roofing dept or lowes roofing called peel and stick[quote]
The stuff at Lowes is considerably thinner than Quik Roof (Home depot) and doesnt bond as well....... Ask me know I know. :oops: [/quote] |
flyboat Samba Member
Posted: Mon Jan 02, 2012 8:42 pm Post subject: |
Here is what I used. It came from Lowes and is about $16 per roll. It took six rolls. I am planning on adding sound deadening material that is about 1/2" on top of this before carpet goes in
_________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Mon Jan 02, 2012 9:01 pm Post subject: |
Just read up. None of the stuff from Lowe's or Home Depot is sound deadening material. You get what you pay for. If you're OK with roofing flashing then go for it. Some swear there is no difference of don't care due to price. As they say, it's your car, do what you want and can afford. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
pb_foots Samba Member
Joined: April 15, 2010 Posts: 1089 Location: Ben Lomond, CA
Posted: Tue Jan 03, 2012 6:56 am Post subject: |
I did my 75 with dynamat and my 67 with the quick roof from Home depot.
Dynamat is nice, but it's pretty spendy and the car is still louder than a modern car. The quick roof is easier to work with, a little thinner, and as has been stated, not made for this. It did add mass to the panels and worked pretty well. I would not hesitate to use either of them again.
I also used 1/4 carpet pad on top of both of them to give some padding to the floor. I picked that up from a carpet store for next to nothing.
It's well worth the effort, I'm just not convinced that the extra cost of the Dynamat is warranted on these cars. |
Posted: Tue Jan 03, 2012 7:02 am Post subject: |
Quick comment on the Lowes product - The stuff that I had that I didnt like was not foil backed. Looks like they handle something different now. There's 2 threads running right now on this topic by the way - different OPs. _________________ D-Dubya Manx clone - 63 Short pan,1914.
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Tue Jan 03, 2012 10:30 am Post subject: |
I used the Quick roof stuff from HOme Depot, worked just fine, though after I stuck it into place, I heated it up with a heat gun to make sure it stuck and so far, it's stuck really well.. |
bcollum Samba Member
Joined: February 12, 2011 Posts: 219 Location: Waco, Tx
Posted: Tue Jan 03, 2012 3:36 pm Post subject: |
Eastwood's has there equivalent to Dynamat on sale fairly often. |
19-VW-74 Samba Member
Posted: Tue Jan 03, 2012 4:17 pm Post subject: |
bcollum wrote: |
But it usually costs about $4.50-sq/ft. I know I can't afford that.
Quick Roof comes in a roll of 6"x25', 45 mils thick, at a price of $16.45 at Home Depot. ( http://www.cofair.com/roof.aspx and http://www.homedepot.com/h_d1/N-5yc1v/R-100594339/...gId=10053)
That means that there are 12.5 sq/ft of 45mil mat in each roll. (1mil = .001in)
So... 25x12=300. 300x6x0.045=81
There are 81 cubic inches in a roll of quick roof.
81/16.45=4.92
Quick Roof value: 4.92 cubic inches of material per dollar.
Fatmat, when bought on ebay in the 50sq/ft 50mil roll, costs $70 (Free shipping).
50sq/ft=(144x50)=7200 square inches. 7200x0.050=360.
There are 360 cubic inches of material in 50sq/ft 50mil roll of FatMat.
360/70=5.14
FatMat value: 5.14 cubic inches of material per dollar.
BOOM. I'm glad I just did that math... I was about to go and buy a bunch of quick roof when I could have bought FatMat (made for the purpose of sound deadening) for a BETTER VALUE THAN QUICK ROOF. I'm gonna buy a 50sq/ft roll of FatMat and if I need more, I'll run down to Home Depot for a lil' Quick Roof.
I realize that this post makes me look like a rep for FatMat... I'm not.
So there. _________________ -Austin
My 1974 Standard Beetle Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=492617 |
Justin-Az Samba Member
Joined: October 03, 2011 Posts: 169 Location: Waddell, Az
Posted: Tue Jan 03, 2012 5:15 pm Post subject: |
Try Fatmat , they sell it on ebay. |
Posted: Tue Jan 03, 2012 5:24 pm Post subject: |
how many square feet do i need to do the entire lower half of my bug?
(rear compartment, floor pans, center hump, from firewall, behind door panels and rear panels) _________________ 74 1303 |
Posted: Tue Jan 03, 2012 5:49 pm Post subject: |
19-VW-74 wrote: |
bcollum wrote: |
81/16.45=4.92
360/70=5.14
So there. |
ummmmmm - to calculate cubic inches per dollar, you would divide the the $$$/cu" Quik roof is 0.20 per cubic inch, Fat Mat is 0.19 per cubic inch. BUT since the thickness is really close, a "per sq ft" would be better
Quik Roof is $1.32 sq/ft, Fat mat is $1.40 sq/ft. Bottom line is that its really close. Nice exercise though. And has anybody actually compared these side by side - would not be surprised if it's not the same thing. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Jan 03, 2012 5:51 pm Post subject: |
3 rolls of Quick Roof does it for me - if using fat mat, get your calculator out....LOL _________________ D-Dubya Manx clone - 63 Short pan,1914.
