1977 Bus Wiring Loom
trojan99
trojan99 is offline
PostPosted: Sat Jan 07, 2012 4:53 pm    Post subject: 1977 Bus Wiring Loom Reply with quote
When I bought my bus, the previous said the previous owner said the bus stopped working due to electrical issues. I have noticed that many of the wires to the engine have been cut.
I am thinking that I should rewire bus to eliminate headaches. The bus is stripped as it is now. I have not found a U.S. source for wiring looms for a 1977 bus. Two large VW parts sellers told me they are not made for a '77.
I just stumbled upon a wiring loom for 1977 bus at Just Kampers in the UK. Does the following loom look like it is all inclusive (ie. lights, dash, etc.)? http://www.justkampers.com/shop/wiring-loom-j16742.html
Also, does anyone have a voucher code that works for Just Kampers?
Thanks,
Tom
jinya
jinya is offline
PostPosted: Sun Aug 12, 2012 9:50 am    Post subject: Reply with quote
Did you end up trying this one? I worry that it is for a righthand drive, being from the UK.
Will this work for a US bus? I'm looking for a wiring harness for my 77 westy and just can't find anything.
busdaddy
busdaddy is offline
PostPosted: Sun Aug 12, 2012 9:59 am    Post subject: Reply with quote
The main harness from the fusebox to engine compartment is ambidextrous on a late bus since the fuse box is in the middle of the bus.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Aug 12, 2012 10:07 am    Post subject: Reply with quote
Depending on where wires are cut, you may just want to find a 1977 and pull the old loom. Unless yours has been damaged it is only about a days work to go thru a whole bus while it is apart to clean and replace the connectors as needed. Once you do that you'll find everything works fine.
