Gas keeps flowing into Caen when I turn off engine
vwbug14
vwbug14 is offline
PostPosted: Sun Jan 08, 2012 12:28 pm    Post subject: Gas keeps flowing into Caen when I turn off engine Reply with quote
Well I guess the subject says it all.
1600 DP. Single carb 34 3 pict. Just rebuilt and put on today. Started fine, ran fine and warmed up. Stalled when it got warmed up and I shut it off and I could hear gurgling coming from the carb. I popped off the air filter and the gas was still flowing into carb. Mechanical stock feul pump.
Before I pull it off Any thoughts??
I was thinking cut off valve stuck. How do I check it??
Mike
buguy
buguy is offline
PostPosted: Sun Jan 08, 2012 12:33 pm    Post subject: Reply with quote
What is a Caen?
vwbug14
vwbug14 is offline
PostPosted: Sun Jan 08, 2012 12:41 pm    Post subject: Reply with quote
Oops. Carb.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jan 08, 2012 1:28 pm    Post subject: Reply with quote
Probably too heavy or cracked float or sticking float shut off valve in the carb.
Could be too much fuel pressure from the fuel pump, but that should stop pretty quickly after shutting off the engine.
In Stereo, Where Available!
Nwilgus
Nwilgus is offline
PostPosted: Sun Jan 08, 2012 7:01 pm    Post subject: Reply with quote
buguy wrote:
What is a Caen?
Caen is a town on the north coast of France, but that's irrelevant. Very Happy
As to the OPs question, a cracked float sounds right.
might check out this site, its a great resource: http://www.vw-resource.com/index.html
Michael Fischer
Michael Fischer is offline
PostPosted: Sun Jan 08, 2012 7:41 pm    Post subject: Reply with quote
Bad float or bad needle and seat.
buguy
buguy is offline
PostPosted: Sun Jan 08, 2012 10:41 pm    Post subject: Reply with quote
Not necessarily bad needle and seat....could just be trash in it. First thing I would do is pull it apart and inspect everything and clean it reeeeeally well. Then again....if its apart...a needle and seat cant be expensive to simply replace. I hate doing shit twice.
Eric&Barb
PostPosted: Sun Jan 08, 2012 10:49 pm    Post subject: Reply with quote
Have been a lot of reports that the new shut off valves are junk. So best to keep old shut off valve just in case.....
