Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sun Aug 05, 2012 9:27 am Post subject: |
And where do you live that the raw metal doesn't rust in your garage? |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Aug 05, 2012 1:27 pm Post subject: |
Woreign wrote: |
If he had it soda blasted, the soda leaves a coating that inhibits rust. You need to wash with vinegar/ water, dry, then spray a sealer before painting. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vdubin Samba Member
Joined: September 09, 2006 Posts: 305 Location: Huntsville, Al
Posted: Sun Aug 05, 2012 7:00 pm Post subject: |
I live in alabama. it's been quite dry lately. also I have kept it covered with heavy plastic sheeting to keep the moisture off. flash rust sucks. |
supaninja Samba Member
vdubin Samba Member
Posted: Tue Aug 14, 2012 5:35 pm Post subject: |
hey guys... since this is going to be for the rebuild I will post it here first.
I am looking for the plastic or rubber sleeving used to protect the wiring on the car. I am going to rebuild my harness and I do want to protect it. Does anyone reading this post know where I can get some sleeving all I am finding is the woven perforated stuff for wiring not in the elements.
thanks guys. |
FergU Samba Member
Joined: August 07, 2011 Posts: 267 Location: Huntsville, AL
Posted: Tue Aug 14, 2012 7:28 pm Post subject: |
Just thinking, but it might be easier to find large heat shrink tubing. _________________ 1962 Type 1
1963 Type 14 - Karmann Ghia "Sadie" (Restoration progress - http://vwsexysadie.wordpress.com)
1972 Type 3 - Squareback "Joseph" (Restoration Progress - http://jpdproject.wordpress.com/) |
vdubin Samba Member
Posted: Tue Aug 14, 2012 7:47 pm Post subject: |
heat shrink tubing is expensive. and when it shrinks it can be difficult to bend. I work for a cable company and can get some really large heatshrink... looking for a better choice. as a large chaffing preventer the H/S is a good idea. |
vdubin Samba Member
Posted: Mon Feb 11, 2013 5:30 am Post subject: |
I recently sand blasted my rims and found out i have 3 rims with a 46 et and 2 rims with 34 et. Now i need to figure out if i should use these rims putting the 34 in back for a staggered look or find another 46? Recomendations? |
vdubin Samba Member
Posted: Sun Mar 10, 2013 7:46 pm Post subject: |
so... I have been a bit busy.
threw a little mud, did a lot of sanding...
changed over my turn assys...
cleaned my engine bay.
here is the before of the engine bay.
got it in surfacing primer.
I have blocked it and fixed almost all of the low spots, all that I give a damn about, and have just sprayed the final surface primer. on thursday I will final block to give a tooth to the paint and start adding color... |
vdubin Samba Member
Posted: Sat Mar 16, 2013 7:59 pm Post subject: |
woohoo... we have color!!!
this car has driven me crazy... now I get to drive it.
my wife loves the color and paint. she could not stop rubbing it. I felt dirty for introducing them. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22407 Location: Kimball, Mi
vdubin Samba Member
Posted: Sun Mar 17, 2013 8:40 am Post subject: |
Im going to sponge brush that area. Too much dirt and grease on the front end to spray. |
LOW N SLOW66 Samba Member
Joined: March 03, 2013 Posts: 71 Location: Billings, Montana
Posted: Sun Mar 17, 2013 7:43 pm Post subject: |
What kind of paint did ya use? Single stage or base/clear?! Looks good either way! It's always cool to see fresh paint on a project! |
vdubin Samba Member
Posted: Sun Mar 17, 2013 9:44 pm Post subject: |
I used master series paint. Bright red and satin black. A single stage industrial anaerobic paint. |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Mon Mar 18, 2013 1:55 am Post subject: |
vdubin wrote: |
That's awesome!
Can you tell me about you gun setup? Looks like it sprayed nice. MS is some thick paint and if you thin it more than 10% or so it will fisheye. _________________ 69 Fastback Build
Berg5 Build |
vdubin Samba Member
Posted: Mon Mar 18, 2013 5:06 am Post subject: |
it is thick. I goofed up and tried to spray it with my HVLP gun with a 1.5 tip. that did not work. I went to harbor freight and got a convetional high pressure gun with a 1.8 tip and that worked well. I did thin the paint 10% and had 75 psi at my gun and it sprayed easy. i wasn't able to get the larger compressor I wanted and had to cobble together my air supply.
its an 8 gal harbor freight compressor tied to an 11 and 7 gallon spare air tanks. I added another regulator to the red tank to feed my gun. it worked quite well.
I am very happy with the results. I still have the doors and rear fenders to spray on thursday. while they dry I will start the wiring and insulating. I'm hoping to have the car together for a local show at the end of april called bugapalooza. |
Posted: Thu Mar 21, 2013 8:38 pm Post subject: |
That's awesome man, as a guy who paints cars for a living I can say it turned out pretty nice! My plan on my square is a two tone satin black with lime green accent color, hoping to get her painted this spring! |
tricken Samba Member
Joined: September 06, 2012 Posts: 38 Location: Tucson AZ
Posted: Fri Mar 22, 2013 12:10 pm Post subject: |
wow looks great my question is what is everyone doing for the weather stripping that goes between the fenders and body
do you jan and then repaint with that on after ? anyt help would be great i am a bit behind you with my 71 |
vdubin Samba Member
Posted: Sun Mar 24, 2013 4:57 am Post subject: |
thanks a lot guys. what I am using is stip caulk for automotive aplications. it comes in 1 ft strips, and all you do is cut off what you need attach and squish. its 3m 08578. |
Brent Samba Member
Posted: Sun Mar 24, 2013 5:59 am Post subject: |
vdubin wrote: |
I sprayed a ton of MS doing my car; something I wanted to try but never did was to drill out the nozzle to 1.8 or 2.0 on one of those $15 HF guns and ream the back side so the needle would seat. I ended up just always laying it on thick and then after a day or so it would level out and shrink quite bit. But I may try one of those conventional guns whenever I get back in the game... I'm not a big time painter, but just looove the way MS turns out when it cures, it's like a perfect powdercoat.
Anyway, looks really good. I think the first one we've seen topcoated with the AG111 kit from MS. _________________ 69 Fastback Build
Berg5 Build |
