rider307g Samba Member
Joined: September 14, 2006 Posts: 124 Location: orange county
Posted: Tue Jan 10, 2012 9:48 pm Post subject: Buggy Motor Decision |
| So I am thinking about building a new motor for my short body manx that i play with on the street but use to play/put in the desert. I have a case as well as a stock crank, rods, bored heads (for 94 pistons) and a lot of other parts. I also have an 82 stroker crank but I think it has to be welded due to a micro crack. My question, is a 1915 enough power for a little buggy? Should I save the 2276 for the long body car in the future? |
LeeVW Samba Member
Posted: Tue Jan 10, 2012 11:09 pm Post subject: |
| A 1500 is "enough" power for a SWB buggy. A 1600 is even better, and the 1776 I am running with the stock carb is more than enough (lower R&P and fourth gear in trans). It pulls strong up to 4,000 RPM which is fine for me. A 1915 would push that buggy anywhere you want to go, especially if you set it up with dual carbs, a high energy ignition, and decent exhaust. |
joescoolcustoms  Samba Member
Joined: August 08, 2006 Posts: 6341 Location: West By God Virginia
Posted: Tue Jan 10, 2012 11:37 pm Post subject: |
The answer depends on you. What do you want the buggy to do, out run most everything on the road, quick, fast, dependable, show with few miles per year?
A 1915 in a full body sedan is quick and fast and will get you in trouble if you are not a good driver. It is even quicker in a lighter buggy.
As a side note, I have a 2165, 2276 and a 1915. The 1915 will be going in my buggy and will be plenty for me. _________________ The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740 |
joehadams Samba Member
Joined: May 19, 2011 Posts: 204 Location: Connecticut
Posted: Wed Jan 11, 2012 8:28 am Post subject: |
| i have a 1500cc in my manx clone. i havent driven it yet because its still being built. i chose the 1500cc cause i can build it up when (if) it gets tired or blows up. but for right now, i just think that if a 1200cc (what i used to have) can move around a german family of 4 just fine in a "heavy" beetle, then the 1500 will be great in a light buggy. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 3693 Location: Madisonville, La
mr_bill Samba Member
Joined: February 19, 2006 Posts: 549 Location: The "United States" of Orange, CA
Posted: Tue Jan 17, 2012 2:50 pm Post subject: |
| I came by a long time ago but did not eat. I will try to make a point of coming to it this month. |
