eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Dec 15, 2014 1:49 pm Post subject: |
I am going the stainless line way on my square. I dropped the bucks for a hydraulic flare tool from the Snap on guy. Aluminum line works well if you can support it & tie it up nice. Ran it on my race car way back. Steel is the simplest & easiest to get & repair (if needed) _________________ I think he meant "rare", as in "not well-done" |
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Mon Dec 15, 2014 3:40 pm Post subject: |
Aluminum lines scary?? Ever flown on an airplane?? (hint: they are plumbed with 90% aluminum hard lines.)
I used steel lines. I can get 'em anywhere and they lasted 50 years so far. In another 50 years, I'll be gone if the car is still here. Gotta give the next generation something to bitch about. I'll happily be the "DPO" on that one. _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
eyetzr Samba Member
Posted: Tue Dec 16, 2014 5:28 am Post subject: |
I have a customer that builds aircraft training simulators & it is scary how light weight all the parts look. All that aluminum with lightning holes & rivets....oh all those rivets. _________________ I think he meant "rare", as in "not well-done" |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Tue Dec 16, 2014 6:33 am Post subject: |
Nate M. wrote: |
Bobnotch wrote: |
A little "over kill" for a problem that really doesn't exist outside of OZ. I mean Nate's not using any of that extra weight crap on his car, and he's pushing quite a bit more torque than the stock VW engine ever did. If there's a problem with the design, I'd think Nate would find it with his set up. |
I don't have any factory rear hangars on my '67 since it was a swing-axle car. I made my own rear hangars that attach to through the cargo floor using spacers and doubler plates to spread the load. Been running this since the Porsche 923 trans install back in 2011 and have never had an issue what-so-ever. I have since grabbed a set of rear hangars off a '69 derelict I have here at the shop, but I'm still on the fence about whether or not to install them. My custom set-up works well and is bulletproof to date so why muck-up the works??
Here's mine:
Thats a lot better than factory. You got the load pushing on the lot and spread out. The factory is pulling on the thin air ducting, pulling spot welds apart and eventually cracking the sheet metal. I'd keep it the way you have it. _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
vlad01 Samba Member
Posted: Tue Dec 16, 2014 6:37 am Post subject: |
Clatter wrote: |
Didn't the Square and Fasty have much larger hanger brackets back there than the Notch?
Here's a '67 Beetle fuel line done by a user here Critter1.
Wish I was looking at these parts sitting here like that right now...
He used a hard line with a bulkhead fitting at the front,
But the hard line comes out of the frame horn without a grommet in the back.
How to do a grommet at that slight angle is beyond me...
Shows how us Type 3 guys are lucky in this regard; the fuel line exits the tunnel 'squarely'.
Either at a right angle in front, like above, or straight-on in the rear.
Presumably right next to the factory exit somewhere back there by where the clutch cable comes out... |
I think so, ironically its been the square and fasty that have had the worst of it in my experience. Not sure why, maybe luck? _________________ The best of VW engine development!
Posted: Tue Jan 06, 2015 3:31 pm Post subject: |
I've been a little nervous about coupling the new 2.3L race motor to the Squarsche with just a stock clutch installed. In the past I had been able to slip the clutch just a bit in the harshest driving with the 2056cc engine with a disc I used to run. That hasn't been a problem wince I replaced the disc, but I didn't want that to be an issue. So when I found a guy on the local craigslist selling a NOS Centerforce dual friction 914 clutch kit, I bit and picked it up cheeeeeeeep.
He bought it back in 1999 for about $350. I bought it in 2014 just before Christmas for $250. Normally this set-up goes for around $850+ today so it was quite a score for me.
In order to comfortably use this HD clutch assembly, I would have to upgrade my clutch actuation to a hydraulic set-up. So after seeing what was out there and reading mixed reviews, I decided on the SACO in the tunnel MC/slave cyl kit since I could use my existing pedals.
I’m no stranger to custom installs. In fact, a good custom job beats a stock job just about any day since it’s doing something different. I love custom work. What I do not love, is tons of custom fabrication when the parts are advertised as “bolt-in”.
I knew going into this install that it would not be 100% bolt-in because I have a Porsche 923 5-speed trans which is anything but stock so I knew I would have to figure out how to make the slave cylinder work with what I have. I did half way expect the master cylinder install to go fairly smoothly and be relatively bolt-in since the kit was made and advertised for both T-1 & T-3 cars. I can’t speak about how it installs into a T-1, but I can tell you all that the kit takes considerable tweeking to fit into a T-3. In retrospect, I think installing cheap Chinese chrome engine tins and getting them to seal like factory German tins would have been easier.
I’m just glad that I already had a larger access hole cut into my tunnel AND that I have a lift here at my shop so I had easier access than either on my back or through the top by removing the fuel tank.
To fit this MC and bracket into a type3, here are some of the added steps not noted in the instructions that had to be done in order for it to physically fit in it's intended location:
- I had to trim the upper, left tunnel cover mount hole off so the MC mount bracket/MC would even fit into the tunnel (it sticks out of the front of the tunnel approx 2”).
- I had to trim the entire left side of the tunnel access hole so the bracket would fit flat when bolted in.
- I had to use a burr to clearance the bottom, fwd end of the bracket approx ½”X1” in order to allow the 2 mount bolts to align with the factory pedal bolt locations.
It doesn't sound like much, but I cannot stress what a TOTAL PITA this was due to the location and access (or lack there of). Approx 5 hours of back and forth, taking a bit off and try and wrestle it back in only to find I had more to remove here and there. All the while laying across the seats reaching through a sharp access hole. There is no easy way to work in the pedal area; it ALWAYS sucks in the best of circumstances. I cannot tell you all just how many times I seriously contemplated taking this MC & bracket across the street and filling it full of .45 slugs!!!
The slave cylinder was surprisingly straight forward and rather simple. It fit perfectly between the casting on the trans case which holds the clutch cable end and the clutch arm. I simply drilled out the Porsche clutch clevis to fit the S/C. I turned a teflon bushing with my lathe for the other end and bolted it to the trans case being sure that it could move and pivot in the stationary hole. I had to slightly trim one of the ribs about 1/8" so the slave cylinder wouldn't hit it. Lastly, I replaced the supplied 90degree #3AN fitting with a straight #3AN fitting so the braided pressure line would fit better.
Of course, once I mounted the reservoir and bled the system, I quickly discovered that I needed just a bit more pedal movement then I could get with the factory hook. So I had to take out and pull apart the pedal assembly. I cut-off the hook and made a piece that was 10mm longer and welded it to the clutch pedal rod. Then I made a new clutch MC push rod that was about ¼” longer. When I then discovered that I still needed slightly more throw, I relented and cut about ¼” off the pedal stop. . .
FINALLY, a hydraulic clutch that works as it should. No small feat though getting this kit to work on my T-3. Not all the issues I encountered were due to the kit not fitting a type3. However, there was just no way that MC & bracket would ever fit without a lot of massaging of the bracket and the car.
While it seems to works well, I don’t know if I could recommend this to anyone installing it into a T-3 without letting them know what they are in for. Again, I’m no stranger to custom fabrication; it’s just irritating when parts that are supposedly designed to work and fit, don’t even come close to either. I’m glad this was for my car and not for a client. _________________ Regards,
Nate M.
Squarsche build
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Wed Jan 07, 2015 2:03 am Post subject: |
DOH!
Here I was all copying your old clutch cable arrangement after shitcanning the Saco set-up!
Also, FWIW, make sure to check the bores on both of those cylinders.
The Saco stuff is known to have burrs where the transfer holes are drilled.
Tears O-rings, and causes leaks.
Especially bad when it fills the tunnel full of brake fluid..
Dag.
Now you got me re-thinking all this stuff again...! _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Wed Jan 07, 2015 7:56 am Post subject: |
Clatter wrote: |
DOH!
Dag.
Now you got me re-thinking all this stuff again...! |
Sorry bro. After having the clutch tube break out recently with only the stock clutch arrangement, I just knew that it would not hold-up over time to the new pressure plate; this thing is stout!! The last thing I want to have happen is it to break free in another location when I was driving far from home (like during a race etc.) so hyd. was the best option. I gotta say that this kit was a total PITA to get installed. I can understand why so many folks had complained about it. Now that I've messed with it, and messed with it, and messed with it some more, it does seem to work very well but in reality it could not have worked as it was delivered. Longevity will be the key to this thing. If it shits on me, I will not hesitate to load up my Colt 1911 and make an example out of it. I'll post photos of that too if it comes to that (but I hope it doesn't) _________________ Regards,
Nate M.
Squarsche build
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Wed Jan 07, 2015 8:20 am Post subject: |
Just saw this discussion... I was trying to keep things as clean as possible. For my application I don't think there will be much vibration as the line is pretty secured inside the tunnel/frame horn. As it sits in this pic, there isn't any rubbing against the SS line, but just for extra insurance, I'll be using either JB weld or some other two part epoxy gooped cleanly around the opening at the base of the SS line. There won't be any vibration or leaks after that.
Nate M. wrote: |
Clatter wrote: |
I rarely use grommets since they have a tendency to fail in the center between the two faces you see (where all the protection is needed). What I do is to slide a split piece of appropriately sized fuel hose that's about 1" long over the tube and through the hole centered. Then a single zip-tie holds it in place. This method would work perfectly in this type of situation. This has never failed me on brake lines, fuel lines, whatever. |
_________________ Justin |
Posted: Wed Feb 04, 2015 6:37 pm Post subject: |
The quest for reliable speed continues. . .
After much contemplation, thought and otherwise thinkin' things over, I've decided that dry sumping the 2316cc race motor would be a wise investment. Here have been my thoughts in random fashion. . .
- The deep sump hangs down a little lower than I would like and otherwise makes me a bit nervous. I'm retired Navy and when I go on base with the Squarsche, I have to cross some pretty big steel barriers that would either (a) hit the deep sump or (b) come darned close to hitting the deep sump and every crossing I would wonder: "is this the day. . ." I don't want to test it!!
- Long sweeping turns are no big deal when you have 12 quarts in the dry-sump. They can be a problem in a wet-sump motor with less than half that. . .
- All the added weight is low and forward of the center of gravity in the car.
- Not having to worry about ruining my high $$$ race motor by running dry on oil; PRICELESS!!
I've acquired a new CB dry sump pump. This will be dutifully modified for use in a type4 and will be ported internally.
The custom mount bar I made earlier will need to be highly modified since the inlet/outlet to & from the dry sump tank are right where the solid mounts are that I made earlier. . . (sigh!) Such is custom car building. . . So a re-design is in order so the oil lines can fit in that space while still mounting the engine. I already have ideas so look for an update on that when I have time to make it happen.
The tank I found was an eBay special in the form of a Richardson Racing 12qt dry sump tank out of a modified race car. Some of the fittings are too big and will need to be made more VW-compatible. Some are not needed. But this tank has an integrated O-Berg oil filter and should fit nicely where the battery now resides under the rear seat. For the price, I couldn't pass it up!!
The battery will be permanently moved to the "frunk" where it belongs and where it will aid in adding weight where needed. _________________ Regards,
Nate M.
Squarsche build
Posted: Sat Feb 07, 2015 12:18 am Post subject: |
Oh, man, I have the popcorn out, and am watching...
Dunno if you saw my post on the STF Speed/Drag Racing forum about just this... It's a deep subject.
Venting to a breather box in the engine compartment?
Think it will give off heat in traffic on a hot day?
How to drain?
Low enough to not flood?
Please do show how those CB pumps are to be ported,
And how to mod your fan shroud and mount bar.
There is one guy right here who is watching very carefully.
My car is (finally) getting mocked up,
and while i'm not ready to do dry sump yet,
I'm trying to get my head around it,
and make it so i don't have to hack the car later. _________________ Bus Motor Build
Posted: Mon Feb 09, 2015 10:32 am Post subject: |
Clatter wrote: |
Dunno if you saw my post on the STF Speed/Drag Racing forum about just this... It's a deep subject. |
I just read through it; thanks. Lots of good info for sure!!
Clatter wrote: |
How to drain?
Low enough to not flood? |
The location I'm putting mine is similar to FJCamper's Ghia(?). I may have to do some funky stuff with the seat, but I think it will be pretty cool when done. We'll see how that plays out.
Seems like a solenoid operated valve (activates with ignition) would solve all back-flow issues, but I find it a little difficult to trust an electric valve that *could* potentially shut-off ALL oil to the motor if power is interrupted. I'll have to ponder this more. . .
Draining the tank is a non-issue. I have a vacuum pump which will make quick work of that in 2 minutes. It would also be easy to plumb a simple ball valve "T" a foot or so off the motor for draining.
Clatter wrote: |
There is one guy right here who is watching very carefully. |
That is already started on the pump. More yet to do but it's pretty basic stuff just to optimize flow through the pump. Once I have the pump ready to put i the motor, then I can do the rest with the mount bar and fan shroud.
Stay tuned. . . _________________ Regards,
Nate M.
Squarsche build
Posted: Tue Feb 10, 2015 8:59 am Post subject: |
As I try and go through my day, I always keep thinking about cars.
Any time there's a minute, my thoughts wander.
They say men think about sex like every 5 minutes or something.
Malarkey.
Some woman said that..
Anyhow,
How's that hydro clutch setup working?
Did you get under there and watch while a helper pushed the clutch in/out?
Can you get full 'swing' at both ends of the slave without fouling the cable mount boss?
I somehow recall during mock-up that the trans case would need clearance..
Was paining me to think of cutting that 923 case even just a little..
Also,
Are you planning to weatherproof the front of the tunnel?
We all drive in the rain now and again, would suck to fill the tunnel full of water..
Maybe just make up a rubber boot/bladder of some kind?
I know its probably raining up there, but, please share your impressions of driving that set up..
Will be interesting to see how it all holds that big clutch.
I'm sure that P/P is off with the rest of the big lower end for a matched spin-balance, right?
Oh, man, I'm just green with envy over big motor your set-up there.
I know full well why so very few type 4s get taken 'all the way'.
On the subject of dry-sump:
Having the tank inside the passenger compartment scares me.
Now that my stunt-driving career has put me upside-down twice
I keep thinking of medieval torture.
You know the one,
Where the king has his captured prisoners boiled in oil... _________________ Bus Motor Build
Posted: Wed Feb 11, 2015 9:24 am Post subject: |
Clatter wrote: |
Malarkey.
Some woman said that.. |
So,. . . you're saying they found someone who could make it 5_whole_minutes huh??
Clatter wrote: |
Anyhow,
Was paining me to think of cutting that 923 case even just a little.. |
The new clutch will be balanced prior to install; absolutely!! With the old clutch/motor in there, I have had no problems what-so-ever since the install. Really nice pedal feel and it works as advertised. Like my rant said earlier; it was a total PITA to install in a T3. If I had known that going in, I would have approached the job with a different frame of mind. I tend to loose my cool with stuff that's advertised as "bolt-in" when they are anything but. . . All in all, it's been working really nice.
Clatter wrote: |
Also,
Will be interesting to see how it all holds that big clutch. |
I have nothing at the moment and I'm not getting water in the tunnel. Weird I know, but it seems fine in there.
Clatter wrote: |
You know the one,
Where the king has his captured prisoners boiled in oil... |
Do some auto-X events with a local club so you can test your car's capabilities in a safe environment. That way in hard driving later, you will know how far you can push it in certain circumstances. I'm planning this in the spring.
BTW, a cage is now a necessity more than just a want; I was driving the other day down one of the twisty back roads hitting the corners pretty hard with the sticky snow tires and actually cracked my windshield (D'uh) The suspension is now more capable than the car!! I gotta address that before I hit the track with it. . . (or replace the windshield)
I'm not worried about having the tank inside at all. It's a sealed unit. The vent will be vented into my breather system outside the cabin. The only way it could leak is from the filler cap. . . I also plan on keeping the rubber side down. _________________ Regards,
Nate M.
Squarsche build
Posted: Mon Feb 23, 2015 5:15 pm Post subject: |
I spent some time today doing some of the mods necessary to correctly fit a CB Performance type1 dry sump pump into a type4 motor. I have to say that it was not much more difficult than the mods required for a 30mm pump.
Here's how the pump breaks down:
The pump uses a 26mm suction side (the bottom pump) and a 21mm pressure side.
On the back side of the pump, there was a small bit of clearancing needed. On the drive shaft boss, I needed to shave approx. '040" off. On the idler boss, I shaved it approx .030" which was basically flush with the pin.
On each end of the drive pin, I shaved approx. '025". On the pressure gear end, I removed the '025 on my lathe. On the drive tang, I simply removed it by hand on a disc sander and re-profiled it.
On both the inlet (from the tank) and outlet (to the tank) I had to drill each approx. .200" deeper and re-tap the holes deeper into the body to be able to attach the inlet/outlet nipples. They would not fit otherwise. Kind of crappy manufacturing, but I've seen this before on other things.
Now all I have to do is to port in internal passages and clean in my ultrasonic cleaner and it'll be ready to install in the motor. _________________ Regards,
Nate M.
Squarsche build
Posted: Mon Mar 16, 2015 7:24 am Post subject: |
This weekend, we got the chance to test the Squarsche at a track event. Evergreen Drift was hosting an auto-X @ Evergreen Speedway in Monroe, WA, so we grabbed our gear and headed down. That was about the best $65 I've spent in a long time!!
The course took most about 1:00 - 1:20 seconds to complete depending on your car and driver's ability to get through it. My best time was around 1:08. I won't even talk about the times on 2 runs that I spun out.
It poured rain for most of the day, so that was to our advantage since we didn't have the HP of some of the other cars giving us better traction. It was very satisfying to beat an R32 Skyline, 'course if the pavement had been dry, he'd have handed my @$$ to me.
I did get to play with the Koni front shocks a bit and found that full firm minus one turn was the hot ticket for that track in those conditions for my car. On full firm, the back-end would get loose a lot easier in the slalom section under braking, but when I softened it up a bit, the rear was more compliant and stuck better. It really handled great! In the back section, I could normally begin to close gaps between us and the car in front. It laid pretty flat in the corners and handled as good and better than I had imagined.
Some areas of improvement that became very evident are:
1. I need a fuel cell. I could smell gas sloshing out of the cap on a few corners.
2. I need new easier to reach adjustment screws for the rear suspension.
3. I need to dyno tune the EFI to this motor. We gave up a lot of time due to tuning and having a lack of power at the moment we needed it.
4. Of course, MORE HP!!
As can be expected with the weather we had, it was a drift-fest and one hell of a lot of fun. The best part was that my son Josh could ride with me in the so we could enjoy it together.
Here's a shot of the Squarsche w/ Josh inside in the staging lanes waiting for the next run.
In all, we were able to make 9 runs around the course. I got them on the GoPro, however I had it mounted upside down on the suction cup. Normally I have it outside the car, but this time I had it inside and it would only fit up side down. If any of you know how to flip the videos before I up load, let me know how please. I'm electronically challenged. . . _________________ Regards,
Nate M.
Squarsche build
vwfye Samba Member
Posted: Mon Mar 16, 2015 8:07 am Post subject: |
Sounds like a hoot and a holler there Nate! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
68vwfasty Samba Member
Joined: March 26, 2014 Posts: 277 Location: Portland, OR
Posted: Mon Mar 16, 2015 9:41 am Post subject: |
Nate, your car looks so awesome! I really hope I get to see and hear it someday. |
vlad01 Samba Member
Posted: Tue Mar 17, 2015 5:01 pm Post subject: |
Hey Nate?
I figured you might have a bit of knowledge on the subject of AFRs on AC engines.
what target AFRs would be a rough ball park to start with on a Porsche 930 engine? its modified but specs are unknown other than the modified twin plugs. Some aftermarket intercooler as well.
I am developing a whole engine management system for a car which had a crappy mixture of dumb DFI with no boost retard and, aux injector run by some crappy module which feeds from the actual tacho and factory mech injection.
any ideas on cruise, med load and under WOT boost?
im thinking cruise 14:1 or can I go leaner? 13 mids and 10.5-11 under boost ? _________________ The best of VW engine development!
Posted: Wed Mar 18, 2015 6:29 am Post subject: |
vlad01 wrote: |
im thinking cruise 14:1 or can I go leaner? 13 mids and 10.5-11 under boost ? |
Typically you want 11.5 - 12.5 AFR under load (including boost) for max power.
13.5 - 16 cruising with light throttle.
The trick is getting it to instantly respond with more fuel as you stab the gas. It's not as easy as it may seem. Much of this should be handled by properly setting up your adjustable, boost sensitive, fuel pressure regulator.
Timing plays a big part too. For example, with MS EFI, I can add timing as I cruise and watch as the AFRs go rich. This then allows me to pull even more fuel out of the VE tables in the cruise areas. You'll also need to retard timing a bit under boost to avoid knocking (the twin plugging should help greatly with that too).
BTW, why on earth would you risk a high $$$ motor to a cobbled together system with what sounds like junk yard parts. It sounds like you are using CIS (K-Jetronic) pieces from many different cars. . . Use a real management system like MS or Motec etc. for quality results. Just my .02 FWIW. . . _________________ Regards,
Nate M.
Squarsche build
