danno627's 1970 fixer-upper
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
str8buggin
str8buggin is offline
PostPosted: Tue Jan 17, 2012 7:51 pm    Post subject: Reply with quote
Looks like a good project, can't wait to follow your progress.
It's good to be buggin...
1970 Beetle 1600SP <--build thread (0\ ! /0)....SOLD
19__ VW _(insert next project here)__
danno627
danno627 is offline
PostPosted: Wed Jan 18, 2012 3:50 am    Post subject: Reply with quote
gt1953 wrote:
Ignition Key read this.
http://www.vw-resource.com/ignition_switch_replacement.html
Take your time do it right. Pull the engine clean it up replace seals. You will be glad you did. Scout out the correct distributor also.
A 1600 single port is rock solid engine.
What is the right distributor? I have learned enough from this site that the 009 is a generic replacement, and my service records tell me that it was installed in 1998. What about the carb? Is it stock?
danno627
danno627 is offline
PostPosted: Wed Jan 18, 2012 3:58 am    Post subject: Reply with quote
This is the hole I believe I need to drill. Thanks to Luft Kuhl for the pic!
mrbigmax
mrbigmax is offline
PostPosted: Wed Jan 18, 2012 10:34 am    Post subject: Reply with quote
If you look on the side of the fuel bowl on the driver's side, it will tell you what model carburetor you have.
danno627
danno627 is offline
PostPosted: Wed Jan 18, 2012 4:17 pm    Post subject: Reply with quote
Home. Frustrated. Ignition is really getting to me. I cannot drill the hole with the switch still on the column. I cannot get the switch off of the column with the steering lock engaged. I cannot use a slide hammer because it would break the steering lock. I appreciate everybody's suggestions, and the links posted, but unfortunately all the information I have found relies on having the key. I think I'm going to have to call a locksmith Sad
Joel
Joel is offline
PostPosted: Thu Jan 19, 2012 1:09 am    Post subject: Reply with quote
You may have to disconnect the steering shaft from the coupler under the fuel tank to get enough movement with everything.
danno627
danno627 is offline
PostPosted: Thu Jan 19, 2012 7:32 am    Post subject: Reply with quote
Called a few locksmiths. The best price I got was $145!!!!! Evil or Very Mad
Chris Vellat
Chris Vellat is offline
PostPosted: Thu Jan 19, 2012 1:37 pm    Post subject: Reply with quote
Last time I needed a column/housing I bought the hole assembly for ~$40 off a local guy parting out a car.
Consider replacing the entire housing casting, especially if the land around the snap-ring groove for retaining the insulated bearing is broken.
(3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's
danno627
danno627 is offline
PostPosted: Thu Jan 19, 2012 3:49 pm    Post subject: Reply with quote
It's OUT!!!!!!!!!!!!!!!!!!!!!!!!
New cylinder with 2 keys
car in "garage"
and the carb (solex 30 pict-3)
danno627
danno627 is offline
PostPosted: Fri Jan 20, 2012 5:34 pm    Post subject: Reply with quote
The new ignition cylinder is in and the wheel is back together. I just have to reconnect the wires. Does anybody know of any plugs that I can use instead of butt connecting the wires back together? I'd like to make it "plug and play"
Chris Vellat
PostPosted: Fri Jan 20, 2012 5:44 pm    Post subject: Reply with quote
Excellent, unfortunately what you're describing is a `72+ "modular" car - which uses special plugs to eliminate the wiring involved in earlier cars. The electrical portion of the modular switches is more prone to failure, but easily changed out. I carry a spare in my modular cars, and an extra in the garage.
There should be no butt connectors at all...the electrical portion of the ignition switch has several wires with crimped female spade connectors that have corresponding male connectors in several locations.
With the correct tools and fittings you could make a single plug - but this component should rarely ever need to be serviced, and the expense/complexity doesn't warrant the effort IMO.
(3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's
danno627
danno627 is offline
PostPosted: Fri Jan 20, 2012 5:49 pm    Post subject: Reply with quote
I know what you're saying here... believe me I wish I could have just unplugged the whole assembly. But once I unwrapped the electrical tape from around the wiring I realized that the wires were butt connected (for the turn signal, not the ignition. I unplugged the ignition wires and just cut the butt connectors. I was thinking of finding a multi-wire plug for the seven other wires so I could plug and unplug them, but I think I'll just butt connect them back together.
Chris Vellat
PostPosted: Fri Jan 20, 2012 5:56 pm    Post subject: Reply with quote
So you can still use the wiring as intended for the ignition stuff? Do so, far superior to the butt connector method. For the hacked-up turn-signal stuff, I'd recommend soldering before crimping, but everyone has their own preference...They're quite simply replaced as well.
(3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's
danno627
danno627 is offline
PostPosted: Thu Feb 02, 2012 3:49 am    Post subject: Reply with quote
I am in contact with a guy who has a bunch of vw body parts and he has a hood and 2 front fenders. They are the right year and the hood has the vents like mine. I haven't seen them but it's only an hour and a half drive. Do you think the parts will fit in my Cherokee? Probably. Maybe. Rolling Eyes
"Harvey"--My 1970--http://www.thesamba.com/vw/forum/viewtopic.php?t=495804
danno627
danno627 is offline
PostPosted: Sun Feb 05, 2012 6:43 am    Post subject: Reply with quote
I'm going to pick up a new hood, with all associated hardware, and two front fenders on Friday for $180. All NOS. I'm taking the wife's Element because with the rear seats out there is a ton of cargo space.
70autostick
70autostick is offline
PostPosted: Sun Feb 05, 2012 7:50 am    Post subject: Reply with quote
Awesome "garage"! I need something like that for my baja to keep the pollen off. Smile
Looking forward to seeing a fresh face on that bug. Cool
Daily driven 1972 beetle, no more 70autostick
danno627
danno627 is offline
PostPosted: Fri Feb 10, 2012 2:19 pm    Post subject: Reply with quote
Got the hood, but not the fenders. He said he had a bunch of fenders but when I got there he only had one of the correct fenders and it was way too light to be OG. Oh well I got the hood for $100. It doesn't have any chrome or emblems, but the latch looks ok and works. I'm glad to have gotten the hood at least. I'll post some out of the car pictures soon.
danno627
danno627 is offline
PostPosted: Sat Feb 11, 2012 1:21 pm    Post subject: Reply with quote
No hood pics today... It just wasn't important to me after I went outside to warm up my Jeep that wasn't there...
Now that I don't have a daily driver I have to decide whether to get the bug running or to buy something else. If I decide to get the bug running, this thread should quicken its pace a bit.
danno627
danno627 is offline
PostPosted: Sat Mar 10, 2012 1:54 pm    Post subject: Reply with quote
I ended up buying a CR-V so all recent cash was diverted from my still not named bug. I hope in the next few weeks to get the fuel tank out while I'm still looking for fenders. Would you guys pull the fender for easier access? Also I found a dime sized hole in the passenger door section of the heater channel Confused
RDbugger
RDbugger is offline
PostPosted: Sat Mar 10, 2012 2:18 pm    Post subject: Reply with quote
Bro.I like your portable tent slash garage.What is it called on the market? I have been looking around for one.
Page 2 of 7
