what are these plastic things on my case bolts?
groovydoobie
groovydoobie is offline
PostPosted: Tue Jan 17, 2012 11:59 am    Post subject: what are these plastic things on my case bolts? Reply with quote
Hey y'all, I've been doin a lot of reading in tom wilsons book but I can not find a description of a particular piece. This piece is a plastic sleeve that fits over the biggest engine bolts, I didn't receive any new ones with my gasket kit and I'm just wondering if I need to replace them
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Jan 17, 2012 12:03 pm    Post subject: Reply with quote
I think they are case isolators and yes you do need them.
Sendd the gasket set back and buy the elring set. They should have them.
Amskeptic
Amskeptic is offline
PostPosted: Tue Jan 17, 2012 5:15 pm    Post subject: Re: what are these plastic things on my case bolts? Reply with quote
In the spirit of learning about your bus, the biggest bolts are known as the case bolts or main bearing bolts, and the plastic stripy sleeves are known as dampers. They prevent the main bearing bolts from vibrating through their long long journey from one side of the case over to the other.
What brand gasket kit did you buy, and was the plastic wrap intact at time of purchase?
Colin
www.itinerant-air-cooled.com
groovydoobie
PostPosted: Fri Jan 27, 2012 12:30 pm    Post subject: Reply with quote
I bought the one from bus depot, and to say the least I'm pissed it didn't come with them. I remmember the brand name bieng victor reinze (german) so wtf how come I didn't get all the parts I needed from a german manufacturer
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jan 27, 2012 12:49 pm    Post subject: Reply with quote
all the VR type 4 kits I have gotten have the nylon pieces in them. Type 1 cases use a rubber o-ring.
you can see here on Ratwell part FF about 10:00
http://www.ratwell.com/technical/GasketSet.html
It is a 40 to 50 year old car that has been abused by at least one of the prior owners. Many parts are no longer available, and like BusDaddy says - rust never sleeps. Better get used to it. If you can't then be prepared to get out your wallet, and your tools.
groovydoobie
PostPosted: Fri Jan 27, 2012 12:59 pm    Post subject: Reply with quote
Is this from the reinze set? I called bus depot when I first got it and confirmed the numbers on the outside before I opened it(because it voids the return policy). So my question now is, does the reinze set come with dampeners for the type 4 gasket set or do I have a type 1 gasket set???
SGKent is offline
PostPosted: Fri Jan 27, 2012 2:58 pm    Post subject: Reply with quote
Do the parts all match what you see in that image? That IS a VR T4 set. The gaskets E and phenolic spacers EE should be a dead give away as T1 don't have that style. Also W is the steel flywheel lock for the bolts and T1 don't have that either.
old DKP driver
old DKP driver is offline
PostPosted: Fri Jan 27, 2012 3:09 pm    Post subject: gasket set missing parts? Reply with quote
Bus Depot only list 2 gasket sets for TYPE4 engines
Look at your reciept for part # maybe they shipped the wrong gasket
set. Sad
021 198 009 B $ 62.17 FOR 1700 engine no crank or fan seal
029 198 009 $ 77.73 for 2000 engine
V.W.owner since 1967
groovydoobie
PostPosted: Fri Jan 27, 2012 4:41 pm    Post subject: Reply with quote
Alright well they did forget it then=S this is the weird thing the seal set has this number printed on it:01-21925-03 then writen underneath that in pen is:021-198-009b so what's the printed number mean...seriously bus depot wtf. I'm not even going to call and complain I tried and they said the reinz set doesn't come with it so that's a lie. Also because I live in freakn oregon and that's at least a week in shipping. Ef it ill go pay 6 bucks sumwhere else and not get a gasket set from bus depot agin.
