Brian_e Samba Member
Joined: July 28, 2009 Posts: 3283 Location: Rapid City, SD
Posted: Thu Jan 19, 2012 2:21 pm Post subject: |
Here are the numbers in the newest CB ad,
Ultra Mag Plus; intake volume 82cc , and flows 177cfm
Mini Wedge; intake volume 77cc, and flows 194.5cfm
044 Super Pro; intake volume 75cc, and flows 210cfm
Wedge port; intake volume 81cc, and flows 205cfm
By the numbers, the Super Pro has the smallest intake (more airspeed) and the best CFM. Sounds like it should be a killer on the street. I wonder if they have done a matched big beef intake yet? Maybe Pat D. could chime in. I am sure he has built a few engines with the new Super Pro.
Brian |
mark tucker Samba Member
Posted: Thu Jan 19, 2012 2:27 pm Post subject: |
tezer71 wrote: |
Anny one now a god offset manifolds that will fit the Cb super pros?
mark tucker is the bp manifolds offset? |
yes about 3/4" for the ones I have. |
tezer71 Samba Member
Joined: February 07, 2009 Posts: 126 Location: norway
Posted: Thu Jan 19, 2012 2:31 pm Post subject: |
And where did you get the bp manifolds? |
vocherro24 Samba Member
Joined: July 08, 2010 Posts: 21 Location: Pasadena, CA
Posted: Thu Jan 19, 2012 3:55 pm Post subject: |
well it looks like both the CB heads are a little too much head for my CAM so I'm going with custom heads and port matched manifolds from Jim Behrens. When I upgrade my CAM on the next rebuild I'll def go for some Super Pro's. Thanks for all the help! _________________ ____________________
1967 Beetle Street/Strip
2332cc w/ dual 48 EMPI EPC's |
turbo2go Samba Member
Posted: Thu Jan 19, 2012 4:58 pm Post subject: |
I'm not sure you can get away with running ratio rockers on that cam. I would call Web-Cam and see what they have to say. _________________ If you can't win,be spectacular! |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Thu Jan 19, 2012 5:08 pm Post subject: |
turbo2go wrote: |
I'm not sure you can get away with running ratio rockers on that cam. I would call Web-Cam and see what they have to say. |
Ditto, that cam is similar to a VZ25 engle. I think it would destroy valve train with 1.4's.
Nice cam though, it would run OK with super pro's.
You may can trade it off for something else. Someone with a sandrail would want it for sure that 105LC is sweet on the sand. That cam is perfect for 2000cc area engines with moderate 40x35 heads. |
Posted: Thu Jan 19, 2012 5:26 pm Post subject: |
that's what the motor was originally running, it could be the wrong info on the part. would it be worth the extra couple hundred bucks to upgrade to an FK8 or something similar, this project has already blown the budget and I just wanted to make it work with the CAM it has but now I'm not so sure _________________ ____________________
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Thu Jan 19, 2012 5:32 pm Post subject: |
an fk-8 is like $80 from CIP. _________________ These days people like me are hard to find- we don't give a damn what you think, about what we think. - JR
66' His
57' Theirs
63' Hers
62' Drag Bug - Theirs 13.1 @ 101 mph (GONE) |
SamT Samba Member
Posted: Thu Jan 19, 2012 5:57 pm Post subject: |
If your gonna swap cams, I would look at FK45 or fk46 |
Posted: Thu Jan 19, 2012 6:36 pm Post subject: |
i think the supers or the minis would be just right. as for the bp intakes I dont remember where, but they were new in the package.I think they have a D cast into them on a runner.there much thicker than the empi stuff&2x as heavy. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Fri Jan 20, 2012 7:53 am Post subject: |
Tanks for the picture ris!
i was thinking on baying the standard CB offset manifolds!but that is alot of welding to mach them to the heads!
the carb linkage i got from before is made to suit offset manifolds,oh well then i guess i sell what i have,and bay new manifolds and linkage that will suit the straight pro style big beef manifolds! |
RIS Samba Member
_NandoO_ Samba Member
Posted: Sun Jan 22, 2012 8:59 pm Post subject: |
Hello my friends, i'm from Brazil and i'm thinking to bye a CBperformance head for meu VW beetle with has a 2276cc motor with w130 cam.
I am in doubt choose between HEAD which, I am among these four options:
Cylinder Heads - 044™ Super Pro
Cylinder Heads - 044 CNC Mini Wedge Port
Cylinder Heads - 044 CNC Wedge Port
Cylinder Heads - 044 CNC Ultra Wedge Port
I'm just thinking of changing the command to a some FK line and rocker to someone 1.4
Which head would be better to me?
Thanks for all.
RIS wrote: |
Didn't get a chance to post these earlier, CB part #1423:
this is a super pro? you tested him? What are the impressions?
thanks |
wildman1 Samba Member
Posted: Sat Jan 28, 2012 6:03 pm Post subject: |
So the Super Pros would create more overall HP/TQ than a set of Oval Ports? (Ultra Mag Plus)
84x94
5.5"
44x37.5 [i]Super Pros vs. Ultra Mags[/i]
FK45/1.4's
9.5:1CR
48 Dells 40 vents
1 3/4" merge
12.5lbs. FW
MSD
Would that be a fun street engine? hmm? |
andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Sun Jan 29, 2012 6:29 am Post subject: |
RIS wrote: |
Here's how the CNC 044 Super Pro match up to the standard CB offset manifolds:
Getting some Big Beef ones and hand porting them to match. |
good picture that also shows the need to clean up the flash in the air passages |
KopfenJager Samba Member
Posted: Fri Apr 13, 2012 1:53 am Post subject: |
I was looking at going with either mini wedges or super pro's with the CB 2246 Camshaft. 314 adv Dur and 260 Dur @ 0.050 .513 lift with 1.25's. I emailed CB but havn't got a response yet. This is going in my sandrail with a close ratio gear box and 10-1cr. Here are some of the specs.
1200lbs sand sprite rail
002 trany (built by bill Kenny) with,
5.38RP
3.78 1st
2.46 2nd
1.78 3rd
1.318 4th
33" STU 16.50 paddles full cup
engine is,
AS41 case.
76mmX94mm CB crank, AA SlipperSkirt B pistons, total seal rings .40 deck.
12lb lightend flywheel.
CB unitech rods 5.5".
44IDF's 36mm vents, 60 idles, 200airs,160mains F11 emulsion tubes, 2" velocity stacks.
CB's 28mm ultrlight lifters. (75grams Vs 105grams stock and 95grams perf lifters)
racing pushrod tubes
CB straight cut gears.
CB power pully.
1-5/8 tri-mil exhaust with flowmaster.
009 dist Bosh blue coil compu fire points, C 6500rpm Rev Limiter.
external oil cooler.
CB maxi 2 pump
fully balanced. (pistons and rods weigh the same, crank and flywheel balanced)
I'm looking for around 150-165Hp. CB has 154hp with there dynoed 2109 with cnc round ports,here is a link to there dyno charts. http://www.cbperformance.com/dyno/dynocharts.html
What do you guys think? |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Fri Apr 13, 2012 6:52 am Post subject: |
I find it interesting that the 2 times they use that cam in their dyno pages (2109 and 2180) it's paired with round ports and power peaks at 5500. With that much duration (260' @ 0.050") both motors should go another 1000 rpm, which tells me they're overcammed (or there's not enough intake port volume). You could make the same power with 10' less duration.
Either head will work well here; I would go with the Super Pro's (better airspeed) and ask CB about using the 2246 with 1.4 rockers, to get the most out of those heads. With .575" lift you'll get a fair bit more than 165 hp. Make sure the heads are set up for that much lift. You might find the 44's need slightly bigger vents to get the most out of it. In your rail this motor will be a blast!
As usual, just my 2 1/2 cents (I'm Canadian, eh). Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Fri Apr 13, 2012 6:09 pm Post subject: |
Nice. I just heard back from CB and they said that in such a lightweight car to run the super pro. It's always nice to pose the same question to two different groups and get the same answer. So super pro's it is.
I just take the cam as one of those parts that works with many different combos. Some engine combos work bettter than others and when you find a sweet spot things just fall together. Maybe a cam with less duration didn't make the same power on the top end and likewise a bigger cam mite have loss a lot of low end. IDK. Maybe they just had lot of em and needed to use them, lol.
CB and most of these guys on Samba know way more about engine building and tuning than I do, So I tend to listen. Sometimes I don't like what I hear or who and how I hear it from, but I generaly in the end I listen. |
EvilleT Samba Member
Joined: March 19, 2008 Posts: 68 Location: Spring Branch, Texas
Posted: Wed May 09, 2012 7:41 pm Post subject: |
RIS wrote: |
Wonder how Scat-Trak manifolds would work on Superpros? |
