bwaz Samba Member
Posted: Tue Jan 24, 2012 10:50 pm Post subject: Early 15" rim question |
Riveted rims... bolted rims, I've heard about both, and wonder what it all means? When underneath the car, I look at the rim and see that the center of the wheel is riveted to the outer part. Two rivets fairly close together, I think 8 in total? Correct for the Zwitter? I haven't checked for date codes, just happened to be under the car tonight. I don't see any in the photo gallery.
thanks
Brian Waz |
janerick3 Samba Member
Posted: Tue Jan 24, 2012 11:06 pm Post subject: |
The earliest 15-inch rims (dated 3/52) had the hubcap clips bolted on. I don't believe there are any VW wheels where the center hub is bolted to the rim; they are either riveted or welded, depending on the supplier's (Lemmerz, Kronprinz, Sudrad, VW) assembly methods. _________________ Thanks,
Jan K. |
bwaz Samba Member
Posted: Tue Jan 24, 2012 11:22 pm Post subject: |
Thanks for that reply... i never thought about the manufacturer being different for the riveted rim, I guess I will have to dig deeper to the date codes
thanks again |
bwaz Samba Member
Posted: Fri Jan 27, 2012 10:56 am Post subject: |
does anyone remember a thread where different manufacturers were discussed? I did some searching and through the photo gallery, but haven't found much.
thanks |
Posted: Fri Jan 27, 2012 8:27 pm Post subject: |
I seem to recall a post (don't remember whether it was in the Split, Oval or Barndoor) forum, where somebody identified the wheel supplier by the style of date stamp on the center hub. _________________ Thanks,
Jan K. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 42221 Location: Phoenix, AZ
bwaz Samba Member
Posted: Sat Jan 28, 2012 10:29 am Post subject: |
Thanks again.... I see that Peter Schepens said:
If they are VW you can have Lemmertz or Kronprinz wheels.
If they are for beetle they are 16x 3.0 inch.
If they are for bus they are 16x 3.5 inch.
THe lemmertz wheels are most likely stamped with the logo near the wheel bolts as where you kan find also the date stamp.
If they are Kronprinz the name is stamped in the inside of the rim with also the month and year.
and quoting an earlier post by Janerick3
I have seen two identical (at different times and locations), 15-inch VW wheels dated 3/52. These were different than later 15-inchers in that the date was stamped inside a 1cm circle (Kronprinz?) and the clips were bolted on, not riveted.
Either these were a factory/aftermarket option for VWs or Porsches in 1952, or VW's suppliers were already building up inventory for the October VW facelift.
I think finding bits and pieces of info from different posts is how I'll put it all together! |
