nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun Sep 02, 2012 8:48 pm Post subject: |
Can anyone tell me what this top row of text says, especially the last word on the first line? I know it's German, I just want to know what words are there. Actually a picture o that right side would really help.
Thanks. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sun Sep 02, 2012 9:07 pm Post subject: |
nlorntson wrote: |
Thanks. |
You'll have to post a better picture of the last word, first line. |
Posted: Mon Sep 03, 2012 9:55 am Post subject: |
Helfen wrote: |
Not my picture or air cleaner. I want to know what the letters are in the picture.
I Think they are GEGEBENENFALLS or something similar.
Can anyone with a similar label take a picture and send it my way? |
Helfen Samba Member
Posted: Mon Sep 03, 2012 10:11 am Post subject: |
nlorntson wrote: |
Helfen wrote: |
I went back through all my air cleaners and found one like that;
BEI STARKEM STAUBANFALL TAGLISH PRÜFEN GEGEBENENFALLS ÖL WECHSELN
Which literally translates to; DUST IN HEAVY ATTACK Taglish CHECK IF NECESSARY CHANGE OIL.
All of the rest of mine say;
BEI STARKEM STAUBANFALL TAGLISH OLWECHSEL SONST ALLE 5000KM
That literally translates to;
DUST IN HEAVY ATTACK Taglish oil change every 5000 km otherwise.
Now are you not glad that we speak English? Knowing German was the original basis of the English language, and by taking something from many other languages we now have the English of today which allows us to explain in great detail instead of generalities what we want to say. There is no translation for Taglish, but tag is day. Being a good German that I am I interpret that as checking your oil bath air cleaner daily under dusty conditions .
D. |
L378 Samba Member
Posted: Tue Dec 11, 2012 6:54 am Post subject: |
Just adding a couple of photos noting 2 small differences in the late oval/early
square window 36hp Mann lid. The first photo is of a 5/57 Mann. The second is
of a 4/58 Mann. There are 2 small differences - The 4/58 has a raised area
where the VW part number is located vs a flat spot on the 5/57 and the MANN
lettering is slightly thinner on th 5/58.
dvancleve Samba Member
Joined: August 11, 2013 Posts: 129 Location: Chandler, AZ
Posted: Sun Aug 18, 2013 5:49 pm Post subject: Thread excavation... |
Eric&Barb wrote: |
marklee wrote: |
Quick question air filter gurus....will a 69 air filter have any clearance issues with the deck lid on a 66 Beetle? |
Only if you want to close the engine lid!
Get a 1966 air cleaner or the 1966 style air cleaner with the post 1967 preheat tube as seen on page one for the post-1968 engines in pre-1967 Beetles. |
So are the post '68 in a pre-'67 air filters hard to find/expensive? Would deck lid offsets (hinge or latch type) allow the late model oil baths to fit in a '62? I have the original '62 filter in my car, but mounted on a 34 PICT-3 dual port 1600. It occurs to me that the air cleaner might be a bit restrictive...
Thanks, Doug
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Aug 18, 2013 5:54 pm Post subject: |
The 1966 style air cleaner that is for the later 1600 engines is probably easy to find in Europe.
The 40 HP air cleaner is probably just fine for a daily driver, but would be restrictive for drag racing. Though if drag racing you probably would be running dual carbs or even FI. _________________ In Stereo, Where Available! |
Posted: Mon Aug 19, 2013 11:00 am Post subject: |
What is the part number for the 1966 (only?) air cleaner? If I can't find a 113 129 613 Q, I will look for a '66 instead...
Thanks, Doug _________________ '62 ragtop bug w/ '71 1600 dual port |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Mon Aug 19, 2013 5:55 pm Post subject: |
dvancleve wrote: |
I will look for a '66 instead...Thanks, Doug |
The 1300 Air Cleaner is part number 113-129-613F
It was only used in 1966 for the US market, but in Europe a '67 1300 Deluxe was still available, and it continued to use the same 1300 Air Cleaner for one more year. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Robert H Samba Member
Joined: January 19, 2014 Posts: 90 Location: Wichita, KS
Posted: Tue Jan 28, 2014 8:47 am Post subject: preheater tube--the other end |
I have a 65 bug with a dual port 1600 (stock-ish) and have an air filter like the on shown below for a 69. But, the large preheater tube is gone. There is also no place for it to go in the rear tin, but that could be remedied one way or another. My question is, where does this pre-heater tube go one it is through the rear tin that it gets warm air?? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Tue Jan 28, 2014 8:56 am Post subject: |
61SNRF wrote: |
dvancleve wrote: |
It was only used in 1966 for the US market, but in Europe a '67 1300 Deluxe was still available, and it continued to use the same 1300 Air Cleaner for one more year. |
Thanks, I will add that information to the first post here. _________________ How to Post Photos
Posted: Tue Jan 28, 2014 8:10 pm Post subject: Re: preheater tube--the other end |
Robert H wrote: |
That tube sucks hot air off the rear of the #2 cylinder. Note the tube is just laid into place and not bolted in correctly. _________________ In Stereo, Where Available!
Posted: Sat Feb 01, 2014 5:57 pm Post subject: |
This is a 1949 and possibly earlier air cleaner.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Feb 01, 2014 9:42 pm Post subject: |
So ...looks like I have a 1964 air cleaner on my 1966 engine?
I wonder how that happened? Everything else seems to be "normal" for the this original 1300 engine ....Except for the electrical box in the upper left of the pic. Can't seem to figure out what that's all about.
Posted: Sat Feb 01, 2014 10:05 pm Post subject: |
Yes, after all these decades you are lucky to have even that!
Electrical box looks like it might be a electronic coil.
Get new fuel lines in there now!
Get the preheat tube going to the carb or at least block off the hole in the rear tin for now. Any holes or missing seals allow hot air under the engine to be sucked back in and cause higher engine temps.
Block the three holes in the shroud with the stock plugs that also hold the spark plug wires. Those holes are allowing cooling air to leak out, so are as helpful as having holes in a radiator.... _________________ In Stereo, Where Available! |
Posted: Sat Feb 01, 2014 10:28 pm Post subject: |
Thanks for the quick reply. I'm not running the engine right now, so not concerned about the cooling issues. ...it does run, but I plan on re-doing the engine before I put it back on the road ...as well as a body-off rebuild as well. It is a numbers-correct car (body, pan, engine) but it did have pre-66 wheels on it, and wrong front seats, so I guess I shouldn't be surprised that the air cleaner is wrong! |
D-train Samba Member
Posted: Mon Feb 10, 2014 12:31 pm Post subject: |
Accessory Dual set ups for dusty conditions. _________________ shiny paint doesnt make it worth any more |
notsnarb Samba Member
Posted: Mon Feb 10, 2014 3:08 pm Post subject: Intake Listing |
Seems like this thread is missing this useful info:
Posted: Mon Feb 10, 2014 8:25 pm Post subject: |
61SNRF wrote: |
dvancleve wrote: |
That's interesting, both the original '66 F case 1300 engines I have came with 113-129-613 E
Do you have a photo of a 613 F? Its not listed in the VW parts pages I listed today. |
