ACN super squishies
Goto page Previous  1, 2, 3  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
Buellistic
Buellistic is offline
PostPosted: Tue Feb 14, 2012 9:06 am    Post subject: Reply with quote
Eaallred wrote:
Politics. All you need is one "big name" person on the forums to say "I don't get how they work, so they must not. Waste of money, domed pistons have been avaliable for a long time, there's nothing special about them", or something along those lines, and pretty soon you get all the internet parrots squaking the same thing in masses. It kills the idea.
Same kind of crap is why my motorcycle was a collectible only 8-9 years after it was produced. No one seems to like the air-cooled sportbike. Everyone claimed they weren't reliable despite plenty of evidence for the contrary.
Alstrup
Alstrup is offline
PostPosted: Tue Feb 14, 2012 12:17 pm    Post subject: Reply with quote
There is no doubt that they work as intended. But to get full potential out of them you must understand how they work, or at least listen to the people that do.
F.i. a guy over here bought a set (not through me) and put them in his 2332 engine with an FK87 cam and the works. I told him how to tune it and set the timing. But once he made it to the dyno, the operator didnt beleive in what he said and jetted it like a normal engine. Results, WAY to little power, like 20 hp and a tendency to run hot. He was also told that the engine had too high CR because the timing should be 4-6 degrees further back. THEN the power would come in.
- The guy took the engine out and reduced CR by 1 full digit and back in and on the dyno. Well, now it would take 28-29 degree advance, but the power was even worse. At that time I was approached. And when I heard what they had done, I just said stop wasting your time at the dyno and bring it to me. He guy and I took it apart - again - adjusted the cam timing, bumped the CR again, and at that time I also performed a better valve & seat job on it. back together and on the dyno again. This time I was the operator and jetting master Very Happy After 2½ hours of trial and error I managed to pull a full 30 hp and 20 Nm torque more out of it than it had the first time around, AND with 2 degrees less timing and 0,15 smaller main jet.
Yes it runs nice and cool, even with a power pulley. Yes it makes very good mileage for what it is.
The elderly gentleman that owns the dyno shook his head and said that we were moving on the edge of disaster. Well, going into the 4rth season now and no problems.
T
[email protected]
john@aircooled.net is offline
PostPosted: Tue Feb 14, 2012 12:39 pm    Post subject: Reply with quote
sometimes people refuse to RTFM....... LOLOL
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON THE NEW WEBSITE, vwparts.aircooled.net
Steve Arndt
Steve Arndt is offline
PostPosted: Tue Feb 14, 2012 3:18 pm    Post subject: Reply with quote
Alstrup, what was your final timing at peak torque?
I was running 22* on my 12.8:1 86B 2275. I'm rebuilding it now with a modified 86A 115LC. I'm a few days away from having it running. I'm keeping the compression the same just to push the limits a bit further.
I have the first set of squishies that John sold, from way back in 2002. Smile
Alstrup
Alstrup is offline
PostPosted: Tue Feb 14, 2012 4:20 pm    Post subject: Reply with quote
Cam retarded 3 degrees to 110 degree base circle, 26 degrees total advance. Elliminator 2000 heads massaged by - somebody - in the US. (I suspect Jeff Denham) Quite well done job with very little to improove. 12,8 CR. 48 IDA´s etc.
224 hp @ 6800 and 248 Nm @ 4700. But as usual when the SS combo is used, a relatively wide torque band. Here we had more than 200 Nm available from 3200 to 6300 rpm.
T
VIN
VIN is offline
PostPosted: Tue Feb 14, 2012 5:25 pm    Post subject: Reply with quote
do you run standard combustion chambers in the heads? or a hemi type chamber since the piston is domed??
Co-owner, 2 Brothers Guns
[email protected]
Click to view image
veedubcrazy
veedubcrazy is offline
PostPosted: Tue Feb 14, 2012 8:12 pm    Post subject: Reply with quote
Really starting to get me interested in a set for my 2387.
1967 Deluxe Sedan & 1969 Stroker!
www.bayareavwclub.com
[email protected]
PostPosted: Wed Feb 15, 2012 2:37 pm    Post subject: Reply with quote
They are designed for conventional VW Chambers. You'll get no squish with Semi-Hemi, there is no deck.
Eaallred
Eaallred is offline
PostPosted: Wed Feb 15, 2012 3:08 pm    Post subject: Reply with quote
I once heard it:
"The Semi-Hemi bucket shaped design is great for holding lots of carbon buildup..."
Laughing
Eric Allred
10.29 @ 131mph
Utah's fastest and quickest VW.
Aircooled.Net
Blackline Racing (Formerly ACE)
Steve Arndt
PostPosted: Wed Feb 15, 2012 5:49 pm    Post subject: Reply with quote
Alstrup,
Were your numbers using premium pump fuel? 26* I've been running 91 octane pump at 12.8:1
Steve
catbox
catbox is offline
PostPosted: Thu Feb 16, 2012 3:20 pm    Post subject: Reply with quote
So when I want to up the power in my 2332.
I can use my Tims stage 2's the way the chambers are?
I will obviously have to up the compression and change to the cam that works best with my combo.
But the chambers....
Hmmm...
Twisted Evil
"...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume.
Alstrup
Alstrup is offline
PostPosted: Thu Feb 16, 2012 3:52 pm    Post subject: Reply with quote
Steve Arndt wrote:
Alstrup,
Steve
Yes that was on EU 98 octane. Thats where this one liked it. going from 24 to 26 gave 9 hp. going to 28 TOOK the 9 hp Shocked So that was definitely the sweet spot.
T
VIN
VIN is offline
PostPosted: Thu Feb 16, 2012 5:14 pm    Post subject: Reply with quote
Sooooo,,, who wants to buy some fresh, brand new AA FORGED 94 mm B pistons, so I can get some super squishies Cool
[email protected]
Click to view image
neil68
neil68 is offline
PostPosted: Thu Feb 16, 2012 7:41 pm    Post subject: notches Reply with quote
I'm assuming that these pistons would need to be heavily notched for valve clearance, correct? How does that work with a dome, but then notched? Just curious, thinking about whether they would work with my flycut heads...
Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro
DarthWeber
DarthWeber is offline
PostPosted: Thu Feb 16, 2012 9:35 pm    Post subject: Reply with quote
Neil, go back to page 1 near the bottom and read Eaallred's post about using valve notches with SS pistons.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
Eaallred
Eaallred is offline
PostPosted: Thu Feb 16, 2012 9:54 pm    Post subject: Re: notches Reply with quote
My recommendation is to follow Johns camshaft advice to a "T" to avoid having to notch. My notched squishies don't have near the advantage as non-notched do. Better than flat tops, but I digress.
Eric Allred
10.29 @ 131mph
Aircooled.Net
neil68
neil68 is offline
PostPosted: Thu Feb 16, 2012 10:03 pm    Post subject: Re: notches Reply with quote
With my current flycut heads, I'm down to only 2 mm valve clearance, with Mahle flat tops and 10.6:1 CR. So, as with your engine, it sounds like I wouldn't be able to get the maximum benefit from SS pistons...
Neil.
68 Beetle 2332 cc
Eaallred
Eaallred is offline
PostPosted: Fri Feb 17, 2012 6:17 am    Post subject: Re: notches Reply with quote
I'd recommend talking to John. Cam timing that he recommends makes a big difference on if you would end up needing to notch or not. I wouldn't count it out until I talked to him.
But you also have to go by EVERYTHING John recommends (ignition timing, etc). Only listen to part of his recommendation, and you only get part of what you should get out of them.
Squishy's work best for people with open minds.
Eric Allred
10.29 @ 131mph
Aircooled.Net
Stripped66
Stripped66 is offline
PostPosted: Fri Feb 17, 2012 7:52 am    Post subject: Re: notches Reply with quote
As Eric mentioned, cam timing is a big part of it. I had to retard my cam 8 degrees to achieve the proper valve-to-piston clearance. Keep in mind, the cam was ground with 4 degrees of advance to start with, so it only had a total of 4 degrees retard as I installed it. Your cam card should verify how much advance your cam already has ground into it.
Rocky Jennings Enterprises
Pauter Machine
DRD Racing Heads
KCR Transmission
Aircooled.net
R-Baja
R-Baja is offline
PostPosted: Wed Jun 06, 2012 12:58 pm    Post subject: Reply with quote
First off, the semi-hemi combustion chamber is stupid, you need at least 36 degrees of ignition advance to make them work. As for the theory behind the super squishy pistons, here are some great links. You can design the "squish" properties into the piston crown or the combustion chambers.
http://www.theoldone.com/articles/The_Soft_Head_1999/
Read the last two sentences here regarding exhaust temps:
http://www.jagweb.com/jagworld/v12-engine/page4.html
And do a Google search in images for michael may fireball combustion chamber. You will see the intake valve is flat and at near the piston crown which also is flat. The exhaust valve is also flat but considerably recessed in the head creating the actual combustion chamber and has the spark plug in that location. 1981 design!
And for the 21st century, check out Mazda's upcoming "squishy" combustion chamber:
http://www.mazda.com/mazdaspirit/skyactiv/engine/skyactiv-g.html
14:1 compression ratio! Very Happy
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 3
