diceman55
Page: Previous  1, 2, 3 ... 10, 11, 12 ... 17, 18, 19  Next
pondoras box
pondoras box is offline
PostPosted: Fri Sep 27, 2013 6:33 am    Post subject: Reply with quote
Any time you have a sharp edge it becomes a stress riser and the potential for a crack to form or get larger over time increases. The hole drilled allows for a round smooth area that is larger in size for the stress to transition smoothly over a larger area. Think of a snow cat to car float over snow because of a larger area to spread out the force of gravity acting on the mass of the vehicle. Larger area to spread out the force equals smoother transition of the force.
This would relieve any potential built up stress in the area but since you are welding the area there is no need to do this as the end of the crack is where the stress riser exists. Once you weld it the vibrations will flow through the area almost like it was a solid piece of steel.
With all that said it wouldnt hurt to drill the end of the crack before welding if you want to for peace of mind but shouldnt be necessary. It is a repair for sheetmetal that is very thin or "plexiglass" where welding isnt an option or it doesnt have to look pretty.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk
54ovsemi
54ovsemi is offline
PostPosted: Fri Sep 27, 2013 12:52 pm    Post subject: Reply with quote
^^^ wow....thanks for sharing..... Are you Walter White? Laughing Laughing JK...thx for the reply. Cool
54ovsemi
54ovsemi is offline
PostPosted: Mon Oct 07, 2013 8:50 pm    Post subject: Reply with quote
So, I took a break from working on the 55 the last few weekends (27 years wedding anniversary celebration with wifey one weekend / Surf session the other weekend) but getting back on it this weekend Cool
The Resurrection Project (Jason) was kind enough to form a metal piece that I was absolutely stumped on bending myself....pics to follow.
Thx TRP Smile
Patiently waiting for UPS driver to knock on door Laughing
54ovsemi
54ovsemi is offline
PostPosted: Sat Oct 12, 2013 11:49 am    Post subject: Reply with quote
Weld on the stress crack on B pillar is completed. We did something completely different then what was recommended. Instead of risking the body lines not lining up correctly we decided to cut out a small circular hole (large enough for the welding tip to fit into) inside the door post. I must say it turned out really nice and I'm extremely satisfied with the repair.
A little body filler to finish off with and it's done.
54ovsemi
54ovsemi is offline
PostPosted: Sat Oct 12, 2013 12:01 pm    Post subject: Reply with quote
TRP.....thx Cool
One of the last details before paint.
54ovsemi
54ovsemi is offline
PostPosted: Sat Oct 19, 2013 5:39 pm    Post subject: Reply with quote
Body work is finished, next on the to do list is spray sealer and primer. I will not post any more pics (with the exception of a few teaser photos) until the 55 is painted.
54ovsemi
54ovsemi is offline
PostPosted: Sun Nov 03, 2013 4:40 pm    Post subject: Reply with quote
Removed the 4tip exhaust today off the motor. Stripped off all the old gunk, grease and paint. Cleaned up all the nuts, bolts and springs. Sanded and wired brushed all the rust. Applied rust converter to all sheet metal, then painted the exhaust with 1500 degree high-heat black paint. Tips and housings painted with high temp engine paint.
Turned out half way decent for a back patio Sunday project Cool
54ovsemi
54ovsemi is offline
PostPosted: Fri Nov 08, 2013 11:37 pm    Post subject: Reply with quote
36 horse all cleaned up and detailed Cool
54ovsemi
54ovsemi is offline
PostPosted: Sun Nov 10, 2013 7:43 pm    Post subject: Reply with quote
Test fit with 4 tip
54ovsemi
54ovsemi is offline
PostPosted: Fri Nov 15, 2013 11:06 pm    Post subject: Reply with quote
Pan nearly done Cool
54ovsemi
54ovsemi is offline
PostPosted: Wed Nov 27, 2013 10:29 pm    Post subject: Reply with quote
Cool
54ovsemi
54ovsemi is offline
PostPosted: Fri Dec 06, 2013 8:53 pm    Post subject: Reply with quote
Expecting temperatures in the high 30's tomorrow.... Not letting the cold stop the progress, guess I'll have to bundle up in the a.m. Dancing
54ovsemi
54ovsemi is offline
PostPosted: Thu Dec 26, 2013 9:00 pm    Post subject: Reply with quote
Picked these up a few weeks go....
Decoded
RX= Prescription
3+2=5
2+3=5
Prescription55....my medicine Shocked Laughing Laughing
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
54ovsemi
54ovsemi is offline
PostPosted: Wed Jan 01, 2014 6:49 pm    Post subject: Reply with quote
Took two weeks off from work so I could get some work done on the 55...... So far the first week I've been in bed with the freek'n flu Evil or Very Mad Exclamation Evil or Very Mad Exclamation
Now just hoping to get at least a few days in before returning to work.
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
GM Industries
GM Industries is offline
PostPosted: Wed Jan 01, 2014 7:43 pm    Post subject: Reply with quote
Bro that bites man..hope you can get some time in on her.. Can't wait to cruise with ya!!!
54ovsemi
54ovsemi is offline
PostPosted: Sat Feb 01, 2014 6:05 pm    Post subject: Reply with quote
Thx Gabe Cool
Update.... Fast forward to February 1, 2014
Was finally able to get back to the shop today with my friend Michael to finish up a few last metal work details. When I removed the body I snapped two of the front pan head bolts located underneath the heater channel which are held by the captive fasteners underneath the front firewall. If you have snapped one of those bolts you understand the pain it is to remove the snapped bolt from the fastener.
I had to order a front heater channel replacement bottom plate from Wolf (excellent replacement part) that would be eventually sacrificed. We had to cut out a small section of the bottom heater channel plate to remove the captive fastener in order to access the broken bolts. Once we had access to the captive fastener we found that the retaining plate that holds the captive fastener was rusted Exclamation Exclamation a little heat from the torch and the bolts were removed.
Michael thank you so much for your expertise and coming up with a plan to remedy this tricky repair! Basically Michael formed a replacement retaining bracket (which houses the captive fastener) positioned the captive fastener and then welded onto the Wolf replacement heater channel bottom.
This is not a fun repair to have to do....I'll post a few pictures so you can see the progress.
BIG SHOUT OUT to Michael for all your help!!
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
54ovsemi
54ovsemi is offline
PostPosted: Sun Feb 02, 2014 9:28 am    Post subject: Reply with quote
For those of you that may have the same problem here is one way to access the captive fastener in order to remove the broken bolts.
1.Cut a flap in the heater channel bottom plate and fish out the captive fastener.
2.Get the plate out, it's about 3/4"W x1"L x1/8"T.
3. Once you have removed the faster you will have to somehow back out the broken bolts. We chose to heat them up with a torch and then were able to back them out quite easily.
4. There is a little sheetmetal cage spotwelded over the plate on the inside of the channel which almost always rust away, mine did. Michael fabricated a new cage out of a piece of sheet metal and formed the replacement cage.
5. You will need a small replacement heater channel bottom plate piece in order to marry the cage to the replacement bottom channel. I had to purchase a front section bottom heater channel plate and I chose to go with Wolf part.
6. Cut the replacement channel plate to desired length, position captive fastener, tack weld cage into place. This will prevent the fastener from getting lost in the heater channel and allow for proper adjustment as well.
7. Because the bottom of the heater channel is double walled you will have to cut out the additional metal in order for the replacement piece to fit properly.
8. Grind down excess metal on the bottom of the heater channel where it marries to the front fire wall. We just ground down the spot welds enough to allow the metal to be removed with a metal chisel.
9. Test fit all parts before final welding.
Again this is not a fun repair to do but in order to do it will require some cutting, welding and fabricating.
Cutting out a flap to gain access to captive fastener.
Replacement bottom channel plate, captive fastener and fabricated cage.
Cut the front foremost bottom part of heater channel plate to use as replacement.
Weld the parts together.
Before welding the replacement part back to body you may want to apply some rust converter while you have access to the inside of the heater channel.
I'll post a few more pics showing end result soon.
Obviously....it helps when you have someone helping you that has dealt with this in the past, Michael thank you so much again!!
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
54ovsemi
54ovsemi is offline
PostPosted: Wed Feb 05, 2014 9:11 pm    Post subject: Reply with quote
Placed my order for a 4" narrowed beam w/shock towers dropped German spindles cross drilled rotors and red ceramic Wilwood calipers from Russell @ Old Speed.....gonna be SIC Cool
1 NARROWED BEAM AND BARS POWDERCOATED MODEL
1 DROP SPINDLE WILWOOD DISC BRAKE KIT
2 FRONT SHOCKS
1 MODIFIED PITMAN ARM
1 COMPLETE FRONT END CORE CHARGE
1 20.6MM DUAL MASTER AND BOTTLE
1 PAIR TIE RODS WITH ENDS
4 TORSION ARM SEALS
1 STEERING DAMPENER
1 ASSEMBLE AND GREASE COMPLETE
Mama Mia!!!!!
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
54ovsemi
54ovsemi is offline
PostPosted: Mon Feb 17, 2014 1:47 pm    Post subject: Reply with quote
Just listed these in classified section....
First-generation flat four BRM's... 5" and 6.5" x 15. I decided to go different direction with wheels.
2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval
mr. warehouse
mr. warehouse is offline
PostPosted: Mon Feb 17, 2014 1:58 pm    Post subject: Reply with quote
Did you every get your air cleaner sorted out?
Page 11 of 19
