Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Thu Feb 19, 2015 5:18 pm Post subject: |
shane red wrote: |
Joel wrote: |
Hot oil?
Why you ask?
Hoover bit aint gonna help.....
Everyone knows baja bugs dont need oil cooling. They just forgot to ad the 5/8" heater hose leading to the dangling 3 row transmission cooler with all the fins flattened out. Its a work in progress. |
THe worst part is it was in a Bay window.
the seller's just like yeah mate was running when removed.....
It's such a bitsa, one case half is a Bay with the cradle mount the other half is a Beetle without it. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Joel Samba Member
Posted: Thu Feb 19, 2015 5:31 pm Post subject: |
That's too funny, they put the air filter on the fan outlet instead of inlet. _________________ Quick little bug, you got a Porsche motor in that?
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Thu Feb 19, 2015 6:20 pm Post subject: |
Now that's a turbo!! _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Feb 20, 2015 12:46 am Post subject: |
technically that's not a turbo but an electric supercharger... nice idea, poor execution.
unless it's just some random stuff put there to enhance the steampunk look of the car. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Mayor Marion Berry Samba Member
Joined: August 30, 2014 Posts: 119 Location: Fredericksbug VA
Posted: Tue Feb 24, 2015 2:10 pm Post subject: |
Does this "1300" in my 59 bug count? It's a frankenstein, I think every major part came from a different year bug.
How many different wrong things can you spot?
I'm asking because I have no idea |
Posted: Tue Feb 24, 2015 3:28 pm Post subject: |
Actually it looks pretty good just needs the heater hoses and the pre heat hose to the air cleaner, I hear the yellow coil will add 10 hp _________________ 71 Super - Backroad Thrasher
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Tue Feb 24, 2015 5:58 pm Post subject: |
Mayor Marion Berry wrote: |
11 |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Tue Feb 24, 2015 9:32 pm Post subject: |
Its a nice balance of yellow between the coil and vacuum plugs on the carb. Yellow plug wires would really set it off nicely.
On a serious note, is the vacuum port on the manifold below the carb plugged? Looks like a hose sticking out with nothing on the end. _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
Posted: Wed Feb 25, 2015 1:54 pm Post subject: |
It might be, I have zero clue. This is my first bug (car with a carb for that matter) and I got it like that. Thanks for the heads up about the vacuum port, I'll take a gander or two. I was told the carb was from a 69 or 70 if that helps
So far I replaced the wiring between the generator and 12v regulator with wider gauge wiring. Next up in terms of the engine, I have to relocate that fuel filter sitting in the back for something less blow-uppy. On a good note it runs way better than it looks. Today it started up now problem in 30 degree weather with a shitball battery. Woot! |
Joel Samba Member
Posted: Sat Feb 28, 2015 5:03 pm Post subject: |
I was told the carb was from a 69 or 70 if that helps |
The manifold is but the carb is a Brazilian repro H30/31. _________________ Quick little bug, you got a Porsche motor in that?
vwsonmybrain Samba Member
Posted: Sun Mar 29, 2015 4:33 am Post subject: |
From another thread...there might be enough here to support a research paper or something:
j.goodspeed Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Sun Mar 29, 2015 9:56 pm Post subject: |
EverettB wrote: |
vwsonmybrain wrote: |
Interesting breather/oil filler usage.
I guess it has an electric fuel pump? |
It must. Still, at least with the filler there you can always make sure the distributor drive gear is well lubed! XD _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Thu Apr 02, 2015 10:24 am Post subject: |
EverettB wrote: |
Yes, that's why they added the alt!
Must be one hell of a stereo in there! _________________ Everything known to man has been written.
Readers are Leaders! |
Posted: Thu Apr 02, 2015 10:22 pm Post subject: |
wythac Samba Member
Posted: Fri Apr 03, 2015 4:22 pm Post subject: |
I just threw up a little bit. Nice detail work but awful color choice and some things painted that just shouldn't be.. |
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Fri Apr 03, 2015 5:09 pm Post subject: |
80s yeah,,, um well,,, what can i say , i lived through it ,worked at vw shops then ,drove a mini truck draggin the ground , that stuff was hot at the time before it went all tweed and billet ..we are all more better now ....
fabricator john |
Joel Samba Member
Posted: Sat Apr 04, 2015 1:47 am Post subject: |
So I thought the typical Aussie 70s/80s 12 volt conversion might be the worst of this ones problems,
Then I saw the other side of the shroud.......
Posted: Sat Apr 04, 2015 3:06 am Post subject: |
Nice use of garden hose! _________________ Two Bugs-
