clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Mon Apr 29, 2013 7:24 pm Post subject: |
pallen wrote: |
Well I just put in a order to Pacific Customs for the last few things I need and also ordred a set of SCAT 1.25 rockers off here so I now will have everything except rods...
CB is still out of stock on the 5.4 unitech rods... so I hope its not much longer. |
CB has been out of stock of those rods for over a year now.
I looked at them for my build last March and ended up just using my stock rods again.
You might just want to source some from somewhere else. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
pallen Samba Member
pallen Samba Member
pallen Samba Member
Dan_Lorenze Samba Member
Joined: February 23, 2012 Posts: 61 Location: Ventura County
Posted: Sun May 05, 2013 9:32 pm Post subject: |
Nice work.... |
pallen Samba Member
Posted: Fri May 31, 2013 5:24 am Post subject: |
Some updates...
Engine is running pretty good, I plan to get a Bosch 010 distributor to finish it up. I got it down to one very small oil drip, I did an oil change and didn't go to the full line on the dipstick; I only put in 4 qts vs 5 the first time. It reads just a little below the middle mark.
I had to pull the pedals due to the flange breaking.. I thought it was the 50 year old mount failure but in fact it was from my own fault! I made a double arm on the gas pedal and the original pin wasn’t long enough so I used a ground down bolt, well the head stuck out a little too far on the part that butts up to the frame and was putting pressure on the mount when the mount was bolted up.... So 11 dollars off the classifieds and I was back in business. I also welded a bolt in for the clutch cable....
Then trying to put it back in the front mounting nut stripped out... luckily I was able to get the welder in there and welded a nut on the back side.
You can see in one of the pics the bolt head sticking out, this was before I fixed it...
I also started on a rear brake/ turn/tail center led bar and a reverse light, also moved the plate down to the bumper ...
Aslo you can see I moved the oil filter up to the bumper, no need to absorb heat off the exhaust...
_________________ Buggy Build > http://www.thesamba.com/vw/forum/viewtopic.php?t=499786
Ecotec Street Rail Build > http://www.thesamba.com/vw/forum/viewtopic.php?p=8146270#8146270 |
pallen Samba Member
herbsflat4 Samba Member
Joined: February 20, 2012 Posts: 159 Location: Greenville, SC
Posted: Wed Jun 05, 2013 9:36 am Post subject: Hey |
I don't know anything about sand dune driving but the new tow points look good. Engine still running good? |
pallen Samba Member
pallen Samba Member
karu Samba Member
Joined: November 11, 2008 Posts: 229 Location: Cross Lanes, WV
Posted: Sun Jun 09, 2013 3:56 pm Post subject: |
Beautiful work! Looking forward to seeing your buggy finished. |
pallen Samba Member
pallen Samba Member
Posted: Fri Jun 21, 2013 10:09 am Post subject: |
So I went after my gas tank issues. I was having some small leaks when filling up all the way. I found it was probably 90% due to a leaking fuel sender seal. But I also found some pinhole leaks where I drilled the mounting holes. To fix it I nothced the holes out and welded them closed.
After a lot of pressure checking with soapy water and shop air. I think its pretty much sealed... I coated it with 5 coats of Master series silver, so I hope its sealed for good now....
I aslo reinstalled the sender with some sealer betweent the gasket and on the bolt threads.
Its been sitting for a week to let the MS fully cure so I will see how it works this weekend. _________________ Buggy Build > http://www.thesamba.com/vw/forum/viewtopic.php?t=499786
pallen Samba Member
Skulptorchaz Samba Member
Joined: June 11, 2013 Posts: 839 Location: S.E. Indiana
Posted: Sun Jun 23, 2013 6:45 pm Post subject: |
Great build Pallen. Your thread was just suggested to me for the fuel door. (I had to go thru the whole thing tho!!!) Great stuff and timing is everything!
I want to do the same fuel door. Joe Cool mentioned it can be an issue if you "spill" so I guess I will just have to be careful. I love the clean look.
I just cleaned out my tank and am going to seal the inside. Yours is already done but if for some reason you have to take it out again, I might suggest coating the inside. There are products like "Crème" and "Red Coat" that I use and have had in Hot Rod and Harley tanks for over 20 years. They keep the tank from rusting and plug pin holes. I have welded several tanks for people and always use it. I use Red Coat lately.
Again, excellent build and thank you for all the pix and info!!!!!!!!
Chaz |
pallen Samba Member
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Tue Jun 25, 2013 4:56 am Post subject: |
You sound absolutely devastated, like the kid who just finished flushing his pet goldfish with tears and immediately turns with a smile and asks for a puppy. Hope I can take a hit like that with a smile when it happens to me. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Tue Jun 25, 2013 6:07 am Post subject: |
pallen wrote: |
Welp transmission broke... I guess a 60 year old stock trans can only take so many launches from a 2L engine...
Any guesses on what broke?
It rolls, spinning sound when clutch is out...
Off to build a transmission shopping list..... |
Mine lasted 9 miles with my 2276. I now PREACH to those who want big engines, build the close ratio tranny first....... Cheaper that way too!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Tue Jun 25, 2013 7:43 am Post subject: |
Nice build, pallen!
I would recommend, however, that you find another routing path to protect the oil lines to the filter. They look all too happy to find something to snag on...
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
thejackalope Samba Member
Joined: November 14, 2012 Posts: 55 Location: Orlando
Posted: Tue Jun 25, 2013 9:45 am Post subject: |
Looks like this buggy will be seeing some trails! |
