So... I Got a Real Car, and I Really Have No Clue
Goto page Previous  1, 2
Bobnotch
Bobnotch is offline
PostPosted: Thu Mar 01, 2012 10:37 am    Post subject: Reply with quote
You might try this place for a manual.
http://www.discountautorepairmanuals.com/
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
70 140
70 140 is offline
PostPosted: Thu Mar 01, 2012 6:29 pm    Post subject: Reply with quote
Trying to add discs to the rear won't be as easy as you think, especially on a drum brake ABS car. My guess is that the proportioning is done in the M/C and you would probably need to replace that as well.
Busryder
Samba SuperHero
Busryder is offline
PostPosted: Thu Mar 01, 2012 8:22 pm    Post subject: Reply with quote
Hello,
That is probably the most detailed answer yet... would this stuff be on a donor vehicle of the same year, but in six cyls? It seems that that is where I have found them on the same year Camry's in the yard I was in.
And out of pure ignorance: Are rear disc brakes not ABS?
I only ask because I really do "have no clue".
Anyway.... I found a pdf wire/rely/connector/etc manual recently, and it is 350+ pages long! Just the wire diagram alone.
So I am beginning to understand what you mean by being 'not as easy as you think'... someone, please, convince me that this is impossibly difficult.
Thank's for the answer 70 140, really...
Lind wrote:
Apparently I was just the lucky asshole that showed up at the right time.
I am a Dick, hear me roar- Laughing
Me, an OVP Lifer...
bugger101
bugger101 is offline
PostPosted: Mon Mar 05, 2012 9:17 pm    Post subject: Reply with quote
no rear disc can have wheel speed sensors but they might be different Question And the abs module would be different also(programmed for a heavier car). Other than that I have no idea there might be Proportioning Valve along the line somewhere. if you can get all the parts for cheap I would go for it and try it.
75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus
1949 ford f-1
2006 Lincoln navigator
automotive student
ford line tech
Page 2 of 2
