midget2000x Samba Member
Joined: January 29, 2012 Posts: 6 Location: Bellingham
Posted: Thu Feb 23, 2012 5:28 pm Post subject: Large-quantity water storage ideas for Eurovan |
I have an '02 eurovan weekender that I use quite a bit for kayak fishing trips. Since I usually have a kayak on top, I rarely pop the top. I sleep below. In fact, I even removed half the top bed so I can have more headroom in the van.
One problem I would really like to solve is large quantity water storage. When I am camping out I don't always have access to running water. I usually just fill up as many containers as I can find before I go. But they just clutter up the van and it's usually not enough.
This may be kind of crazy, but I was thinking I could use the extra headspace I gained by not having the top bed for water storage. Perhaps building a removable platform that rests the same as the bed did, but instead holds large quantity of water.
The platform isn't the problem...it's the water. I was thinking something like a camelback bladder, but huge. Does such a thing exist? I would then run a hose with a closeable valve from it. I could use it for drinking water, dishwashing, and even quick showers if it was big enough. Gravity would provide the pressure. I'd obviously need to be super extra careful not to puncture it.
Anyone improvised a large-quantity water storage scheme? |
banditwolf Samba Member
Posted: Thu Feb 23, 2012 6:06 pm Post subject: |
I've seen companies that make custom bladders for home rain water collection. I'm sure one of those could make a custom one for you. Possibly a small size may be around that would work for you. _________________ 1973 Super Beetle l 1981 Trans Am |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 5743 Location: I'm sig line free
Posted: Thu Feb 23, 2012 9:20 pm Post subject: |
How about a water bed mattress ?  |
Posted: Thu Feb 23, 2012 10:58 pm Post subject: |
| iowegian wrote: | How about a water bed mattress ?  |
brilliant! |
Semper_Dad Samba Member
Joined: May 14, 2005 Posts: 2611 Location: HELL Paso, TX
Posted: Fri Feb 24, 2012 12:09 am Post subject: |
Don't think it would be a smart idea to put a large quanity of water that high up. It will change your whole center of gravity and easier to tip over. Then there's the hammer effect to deal with when coming to a quick stop.
You are better off using smaller containers (no more than 5gal) and stack them on the floor. Once at your campsite you can put them outside.
Just how much water do you need? 2 gallons per day should be enough. 45 gallons of water going to weigh near 360lbs. _________________ 74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
Washington State 181 (Thing) Registry - current tally: 58
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 98 181s in the world |
Bruce Samba Member
Posted: Fri Feb 24, 2012 1:01 am Post subject: |
| Semper_Dad wrote: | | Just how much water do you need? 2 gallons per day should be enough. 45 gallons of water going to weigh near 360lbs. |
375lbs of water on board is a significant amount of extra weight (+~15%) to carry in an already underpowered vehicle. _________________
| Glenn wrote: | | ..... and like them better than Bosch. |
Posted: Fri Feb 24, 2012 1:36 am Post subject: |
| I was thinking less than 10 gallons |
djkeev Samba Member
Joined: September 30, 2007 Posts: 7906 Location: Central Morris County, NJ
neil oleary Samba Member
Joined: November 18, 2011 Posts: 4 Location: Tempe, AZ
AlteWagen Troll
gavin.dude Samba Member
Joined: December 29, 2011 Posts: 283 Location: Cobb, Ga
Posted: Fri Feb 24, 2012 3:16 pm Post subject: |
Cant you just get water out of the river? _________________ 73 SB, Hormiga |
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7718 Location: Hablamos Ingles, So. Cal.
Posted: Sat Feb 25, 2012 9:40 am Post subject: |
